Question about HP G70-250us Notebook
CD stuck inside the laptop, not in the CD/drive
I loaded a CD in the CD drive that was apparently not seated correctly. When I went to eject the CD there was nothing in the drive. The CD is stuck inside the laptop. How do I get it out? What do I need to do to remove parts to remove the CD?
Thanks,
Gary
    President:
  • 1,187 Answers
If the CD is just a "copy" that can be re-created, then:
1. power OFF laptop
2. straighten-out on end of a paper clip
3. locate the tiny hole on the CD drive
4. push the stylus (the straightened-out paperclip) STRAIGHT into the hole with a strong push.
5. The stylus may need to be longer or stronger.
This always works...
Posted on Sep 04, 2009
  • 477 Answers
Under the laptop remove a screw or 2 and you should be able to remove the cd rom.
download the manual to your laptop here, to be on the safe side
Cd drive keeps ejecting
Does the it eject as soon as you close it or is there a delay?
Things to check in the meantime - The button on the drive itself (you may even have an extra on on your laptop too) to eject the drive isn't stuck or jammed in some way.
There are no foreign objects preventing the tray from closing properly.
If there is a disc in the drive it is seated in the tray correctly.
Jan 09, 2013 | HP Computers & Internet
Loaded a cd to upgrade firmware, firmware would not load. eject button would not eject. read manual, says to push eject at the same time you plug in the electric cord,still would not eject. Any...
Please try in this way.
Disconnect power.
Connect power back, and keep REPEATEDLY pressing the eject button while you connect. If still no ject press power on button while you keep hitting the ehect button. You need to press eject on the unit, do not use the remote.
If that does not work, then the unit must be taken apart.
Dec 09, 2010 | Cameras
CD has physically stuck inside side loading (no tray) DVD drive on Laptop. Eject buttons both on media panel and via Function F10 are attempting to eject CD but it tries to move then refuses to eject. As...
The front of the CD Driver you can see a very small hole…use a safety pin and open it then insert the pin in that hole and push it in that will force the door on the CD to open …Let me know if that work for you and please do not forget to rate my service so I can keep providing this service to everyone and improve on it. God bless
Sep 21, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dell xps m1330 dvd drive will not eject cd inside
Im a dell tech, and i hate those cdrom styles, but, that is what the consumer wants, so we make them. Try starting the machine, then press F2 to enter the BIOS. once in the bios, press the eject button. listen for any noises, (an attempt to eject). if you hear a sound, it means the drive should be capable of ejecting the disc, and perhaps the disc has not seated correctly. If the disc will not eject, you must contact Dell. This is from the DELL dcse site: " Optical Drive The XPS M1330 has a slot-loading optical drive instead of a conventional tray-loading module. There is no mechanical eject mechanism for the drive to eject stuck discs. This means you must replace the drive if a disc gets stuck in the drive. After replacing the drive, disassemble the old drive to remove the disc for the customer."
Jul 21, 2009 | Dell (0F146) Internal DVD Drive
Dell Studio 17 Stuck Disc in drive
if you look close infront of the cd-dvd playerdoor there is a little hole if you stick a paper clip in there it will eject it.
Jul 10, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
CD Mechanically stuck in Drive Dell Studio 17
turn on the PC and insert a pin in the small hole on CD drive.it will be ejected.
Cd drive will not eject or run any software
Place your laptop on a flat surface always. It give some tilt on already cramp space on the cd drive.It could make disc hit something inside to make it stuck so it will not spin and read. It also misaligned mechanism inside the drive to make a full eject.
Apr 08, 2009 | E-Machines emachines (emachinees) CD-ROM...
Cd stuck inside laptop
There is a small hole, usually near the eject button. Unbend a paper clip and carefully push the paper clip into the hole, try to keep it straight. drive should pop right out.
Feb 20, 2009 | Gateway MT3705 Notebook
turn off the laptop and turn it on again as soon as you see the windows startup push eject button see if it open if not then the CD rom is jammed inside
Sep 16, 2008 | Computers & Internet
Curtis DVD player - Stuck in Load Mode so won't open - dvd inside - correctly seated - but may not be compatible. I just burned it & was testing it.) Have tried the paper clip in the tray release...
Do the following
Unplug power cord.
Wait two minutes and plug it back.
Keep repeatedly pressing the eject button while you start the unit, before it starts reading cd inside. Do this a couple of times.
If you cannot eject the disk in this way you will need to take unit apart.
Unit won't start until the disk is inside, as it tries to read the disk , disk is faulty and unit get stuck.
Aug 26, 2008 | Televison & Video
HP G70-250us Notebook Logo
278 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
