Question about Canon PIXMA MP160 All-In-One InkJet Printer
MP160 I need to re-install my driver so I can
MP160 I need to re-install my driver so I can print and scand again.
The dest top shows an icon and it says to re-install my driver. I un-istalled my printer. Now I cannot install my driver again.
Although I bought a new printer cable to use with my Canon MP160, the printer only scans, it won't print. I tried turn off,rest, then on again; reset, start (both black and color buttons) and cannot get...
The best thing that you can do here is to uninstall and reinstall your rpinter software from your computer to make sure all settings are correct and printer software are properly installed on your computer....
Oct 15, 2008 | Office Equipment & Supplies
I have problem with my scanner. when I want scan whith that show this message: Cannot communicate with the printer. Open the print queue and uncheck Pause Printing in the Printer menu.
hi, uninstall your printer and do as describe here--
  • Just connect your printer data cable into the USB port of the Computer
  • On your printer
  • Then Right Click on My Computer select Manage then Go to the Device Manager and Click on Update Hardware Option
  • After updated you see a Icon as yellow Question Marks with The name of your Printer.
  • Just Right Click on it and select Update Driver
  • Do as per the given Direction.
After successfully install your driver you just restart your computer. Your printer now installed with your PC
May 22, 2011 | Canon PIXMA MP160 All-In-One InkJet...
I have a NortonInternet Security account 6W33XT2W I have not been able to get any response. Also no icon or shortcut on my dest top.
Quote:
"I have a NortonInternet Security account 6W33XT2W I have not been able to get any response. Also no icon or shortcut on my dest top."
First of all try to see if this Norton Internet Security is Current. And Your Activation Key is Current.
And if its really Current, Install it again. and Prompt the Activation Key (Serial Code).
Sep 01, 2010 | Computers & Internet
Hii..... My canon mp160 printer isn't working please help , It is making number 2 then E error , and all the icons are lighting , I installed it on my PC but the printer isn't working
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Aug 21, 2010 | Canon PIXMA MP160 All-In-One InkJet...
I cant print it is showing e5 on printer screen
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokio-3
Jul 30, 2009 | Canon PIXMA MP160 All-In-One InkJet...
My Canon MP160 doesn't print emails to the bottom of the email. When it does print a word doc, it prints multiple copies and I have to manually cancel the printing. Now it is printing in gibberish. help
hi,
prito-i-232
May 18, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Contecting my printer to my lap top
It would seem that you posted twice. In any case, for your Canon Pixma MP160 Multifunction Printer drivers, pls start here.
Just a start, do postback how things turned up or should you needadditional information. Good luck and Thank you for using FixYa.
Nov 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon mp160 drivers
hi,
prito-i-25
Jun 04, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
old marine
old marine
