Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
When pushing foreward the vacuum is hard to push and if pushed on to hard it will turn over on itself.
  • 3 Answers
My dyson dc17 animal had become nearly impossible to push on carpets.
sure enough i found that my roller was warn down to nubs (vacuum is probably 8 years old, and gets used nearly every day)
I replaced the roller and WOW! it feels like its self propelled now. HUGE DIFFERENCE.
thanks for the help!!
Posted on Nov 08, 2012
  • 144 Answers
Check the brush. That could be the problem. Check the belt also. Your brush roller may need to be lubed or even replaced.
Posted on Sep 04, 2009
It is hard to push the vacuum
sounds like it's a self-propelled vacuum and the switch that controls the wheels may be broken. Turn vac over and look on the bottom for wheels and see if they are turning when you lower the handle.
Aug 14, 2014 | Vacuums
Why is my oreck xl 21 hard to push on carpet?
sometimes the little rubber wheels in front wear out of round and bind. Try those first (if they're the tiny ones you must buy a pack of 20 from oreck directly) and Orecks are known for being hard to push when bag begins to fill up.
May 03, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Oreck xl
It's hard to push because it's literally sucking itself to the floor. Adjust the height control to raise the level and allow more air to get in around the edges, should relieve the vacuum pulling it down. Possibly somthing is wrong with the height adjustment control, allowing machine to sit too low to ground. Hope this helps.
May 11, 2013 | Vacuums
I have a Simplicity 7 Series Commercial vacuum that does not pick up well when pushing the vacuum foreward. Picks up just fine when pulling it backwards. Have installed new belt, roller brushes, and brush...
Make sure the bottom plate is installed properly. If it is not seated well the brush roll may not be engaging fully with the carpet. Make sure the wheels on the bottom plate work properly.
Feb 10, 2011 | Simplicity Vacuums
I have a dirt devil featherlite plus and all of the sudden it started pushing hard and smells hot. I cleaned the roller, changed the bag, checked the belt. The belt is a little wore, but not bad.
If it is pushing hard then you still have a belt problem. It may not be broken but the belt is stretched out too long and will not turn the roller brush fast enough to make it push easy.
Nov 27, 2009 | Dirt Devil M085500 Featherlite Plus Bagged...
Oreck upright hard to push
If hard to push, only a few things to check:
(1) Rear wheels will get hair or thread wrapped around axles, dust, etc. and be hard to turn. Make sure each wheel turns easily.
(2) Small wheels on newer models (since about 1997-98) toward front are worn, missing or have same problem as item 1.
(3) Brush roll not turning. The brush roll actually helps pull this unit along the floor, as it rotates in the "forward" direction. If the belt broke, and you do not realize it, it may suddenly seem harder to push.
Oct 11, 2009 | Oreck XL2000 Bagged Upright Vacuum
I have a Bissell Pro Heat 2X carpet cleaner and the brushes spin, then stop. I turn it off and when I re-start, the brushes do not spin until I push foreward. The it spins and stops again. Both belts are...
The reason for the brushes to stop when it is above any surface is there is a switch in the handle that stops the brushes so it dont burn your motor up it may have a faulty switch.
Jul 14, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
My dyson vacumn is hard to push on carpeting. How do i fix it?
This happens when the bristles in the brush roll get worn down too short. Put in a new brush roll and the machine will pull itself over the carpet, so you hardly have to push at all.
May 19, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My vacuum has good suction but i can hardly push it across my carpet. any answers????
is your brush roller turning,that would cause it to be hard to push .the brush roller helps it walk across the floor.if your brush roller isn't turning then your belt is broke or the brush itself siezed up.unplug the vacuum and try to turn the brush roller .if it turns real free then your belt is broke.before you replace the belt always clean the motor shaft ,the old rubber from the old belt melts onto the motor shaft .if you don't clean it your new belt won't last very long.please leave feedback
May 04, 2009 | Kenmore Vacuums
Hoover upright windtunnel isnt propelling itself anymore
If the V belt is loose with the handle down, then maybe the idler wheel under neath the belt isn't contacting the belt, may be jammed down, just push on it to see if it moves up and down. Belts don't last very long, you may want to replace both of them.
Dec 29, 2007 | Vacuums
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
525 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
