Question about Black & Decker Black and Decker & Grass Hog Electric Trimmer
THE LAWNMOWER SUDDENLY STOPPED WORKING - ELECTICAL CORD AND OUTLET ARE GOOD. WHAT HAPPENED AND WHAT CAN I DO BOUT THIS?
Cannot start
IS IT GAS OR ELECT?MAKE SURE PROPER FUEL OIL MIXS IS CORRECT//CHANGE OR CLEAN SPRK PLUG WITH SMALL WIRE BRUSH,CAREFULL NOT TO PUSH TOO HARD DOWN CAUSEING SPRK PLUG GAP TO CLOSE!!IF ELECT CHECK ELECT CORD MIGHT HAVE BURNED OUT WIRES INSIDE PLUG,OR SWICH MIGHT HAVE WORN OFF INSIDE CONNECTION..
May 25, 2013 | kawasaki Garden
Device appears to have no power. Power cord looks good, it was working the day before then suddenly stopped working... no lights indication of any power making it to the device.
This unit will not operate if it is plugged into a power strip - it must be plugged directly into the wall outlet. An extension cord may be used.
Aug 16, 2011 | Honeywell (18155) Air Purifier
10 year old Toro 2017 lawnmower, suddenly stopped while cutting grass. Oil quite low. Cannot pull cord more l than few inches.
When you pull the cord does it hit a hard stop and not go any further or does it get really difficult?
Aug 02, 2011 | Toro Lawn Mower With Toro Power Tools
When I pull the red lever on the electic mower, the lawnmower will not start and the GFI to my house is being popped?
just for a quick test -- run power to the mower using a different outlet,,, GFI outlets are well known for having a bad trip circuit in them,, they go bad all the time. so if your mower does in fact work on a different outlet with no problems then the issue is your GFI outlet and you will need to replace it.
if the mower is infact tripping the next circuit then the problem is with the mower motor windings or a short at the switch or two wires shorting out. check all wires and make sure connections are good.
c...
Jan 30, 2011 | Black & Decker Black Decker 18" Lawnhog...
Not working  I hit the switch and there is no sound of a motor.  Nothing is happening.  It was working seconds earlier and suddenly it stopped.  The plug was in and I replugged it into...
If it was just a broken belt you would still hear the motor running. most likely its in your cord or switch. check the main cord, connections to the switch, and also the motor supply cord that goes from the handle to the vacuum head.
Feb 26, 2010 | Oreck XL Ultra Bagged Upright Vacuum
Microwave oven suddenly stopped working, no display,not outlet
Hi, you must check the inside fuse. If is burned out, please consider that something happened, you must check further beyond to find the causes.
Nov 13, 2017 | Kenmore Microwave Ovens
My phone is dead
Reset Procedure for Cordless Phones
Question:
What is the general reset procedure for cordless phones?
Answer:
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances.
<KEYWORDS="RESET, call,? can?t tone, dial no flashing, unavailable, range, of out working, not up, messed>
May 05, 2009 | Uniden Cordless Phone
Black & Decker Black and Decker & Grass Hog Electric Trimmer  Logo
132 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
