Question about Hotpoint BWM12 Front Load Washer
Hotpoint bwm12 washing machine, selection knob keeps turning. Tried reset but makes no difference.
barkencoa
  • 3463 Answers
SOURCE: MY HOTPOINT BWM12 1200 SPIN
You need to check and clean filter first.
You will find the filter is normally located behind a removable plastic cover at the front right side of the m/c.
Make sure the drain hose is not kinked or restricted..
Make sure you have not selected rinse hold..
Obviosly make sure pump is actually working.
Plz rate this solution .Thanks.
Posted on Dec 24, 2008
  • 100 Answers
SOURCE: hotpoint aquarius wash system plus ultima 1200 wm72
it's a motor problem. could be as simple as the brushes or could be the circuit board at fault.
Posted on Jan 27, 2009
  • 166 Answers
SOURCE: hotpoint washing machine keeps tripping electric
First unplug your washer. Check the ground on the washer and make sure it isn't loose; this would be a good time to inspect the wiring harness for any problems. Next check the outlet (turn off the electric to that breaker first) make sure all the wires are tight and are making good contact; pay special attention to the neutral (white) wire. If that seems fine, and you are comfortable with going into you breaker panel, turn off that breaker and check the hot (the wire on the breaker) to make sure it isn't loose and then check the neutral wire. If either of these wires seem loose tighten them down....a loose wire will move when a load is put on it and cause the breaker to trip. If all seems normal and washer is still tripping the breaker you might want to replace the breaker.....they can go bad. Good luck!
Posted on Aug 26, 2009
  • 51 Answers
SOURCE: WMA 54 Hotpoint Aquarius washing machine lights flashing
the problem here is the machine is not emptying when its supposed to, you will find it is stopping at the rinse cycles. there is a sump underneath the machine that needs to be emptied. From my experiences, 9 out of 10 hotpoints that i would of repaired with the same problem as you are having is usualy caused by using the color catcher sheets, they are a disaster.
appliancesdav@hotmail.com
pallesappliancerepairs.com
Posted on Feb 03, 2010
  • 160 Answers
SOURCE: Hotpoint washing machine model WF620, keeps
depending on which version you have to
Press the 'Start / Cancel' button until ALL the console LEDs illuminate.
then either
1.Press both 'Start / Cancel' and 'On / Off' buttons together until 'd OFF' appears.
or
2. Press 'On / Off' and 'Start / Cancel' together with the top left option button (Spin) until 'd oFF' appears.
Posted on Mar 21, 2010
Can you remove hotpoint bwm 12 washing machine filter
Hi, yes it is. Hotpoint bwm12 is a built-in washing machine, the filter is located at the bottom (black round knob). Undo the filter by turning it to the left (please be sure there's no water inside the machine, or getas much as possible out before opening the filter).
Cheers
Feb 19, 2009 | Washing Machines
Hot point wmlt80, dail clicking and turning, cycle wont start,
Yes, I work for GE what you need to do is to resent the appliance. Something should had happened with the computer of the washer. Just unplugged the machine for 40 seconds. You can unplugged or turn off the circuit breaker for 40 second and plugged back in. Select a normal cycle and let it run.
Jan 15, 2009 | Hotpoint WMTL80 Top Load Washer
MY HOTPOINT BWM12 1200 SPIN WON'T DRAIN,
Dec 24, 2008 | Hotpoint BWM12 Front Load Washer
My washing machine..hotpoint bwm12
If you need a manual type HOTPOINT USER MANUAL in your browser bar.
Click on hotpoint web site and then user manual and download your model.
Dec 14, 2008 | Hotpoint BWM12 Front Load Washer
Dial keeps turning on machine
machine wont operate when dial is at rinse
Jul 17, 2008 | Hotpoint BWM12 Front Load Washer
Hotpoint bwm129 lights flashing
What mode are you starting this machine in ? I know this may sound silly and I'm trying to determe if this is a machine fault code or something else.
Dec 30, 2007 | Hotpoint BWM12 Front Load Washer
Programme dial
IT could be the doorlock remove front of door seal to change it. It is only held on by two screws. good luck ,not much to go on!
Dec 13, 2007 | Hotpoint BWM12 Front Load Washer
Hotpoint BWM12 Front Load Washer Logo
98 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
