Question about HP Pavilion dv1000 Notebook
I need to restore my laptop to the factory settings. I have the recovery disks that came with it. What are the steps I need to take when using the operating system restore disc? I'm not familiar with computers, so please be specific. Thank you
  • 477 Answers
Hello
First
what disk do you have?
one should be OS disk and a other should be drivers and software or a recovery disk.
if you have a label recovery disk start with that.
if you have an OS + driver disk start with the os disk.
put it in cd and press a key when it says so.
here is a very good guide to follow
after you installed the os then run the driver recovery disk just click next, its not that hard.
Posted on Sep 04, 2009
  • 928 Answers
Ok, first insert de recovery disk in the laptop. Restart the computer, while rebooting, press delete, or f2, or both at the same time, the laptop will let you know by a message in the bottom "press f2 to enter set up". Now you are entering the Bios, read carefully and scroll to Advance ???? ( I don't remember the name of it) and hit enter. Look for First Boot device or drive or whatever it says, and choose CD/DVD. Not all Bios are the same so must read the instructions in theleft panel. And for your second Boot device choose the HDD. Hit the escape button.Now, to exit and save you must press f10, the computer will reboot it self and it will prompt you if you want to boot from cd drive (To boot from cd press any key) so you press enter, and after that just follow the instructions that it display while the installation.
    Problem Solver:
  • 19 Answers
Hi this should be a easy start for you to get use to computers.
Be certain that you want to go back to factory.
First make sure you have all your music, pictures, and all that good stuff backed up on a flash drive or disc's. After that just put the recovery disc in the drive.
Most recovery cd's can be put in the drive and follow the on screen instructions.
Or simply put it in the drive and restart the computer. If all else fails and you can't get it to load. "Check your BIOS(the little press this key to enter setup that flashes when you first turn on your computer" look for boot order and turn your CD drive first. then it will have no choice but to load the cd.
    Novelist:
  • 136 Answers
Be sure to save to an external drive (like a flash drive stick or burn a disk) any files you wish to keep, insert disk and re-boot. The PC should boot from the recovery disk automatically, and follow the prompts from there.
If the problem(s) persist, and you have the original installation disk, you may want to start fresh by re-formatting the drive (involves "fdisk" and "format", do not attempt without further instruction, will be glad to help if you want to do that!)
Hope this helps!
-- RT
PS - Don't forget to vote!
  • 125 Answers
If you put the first disk in it will auto start and prompt you through the process.
RESET TO FACTORY SETTINGS
What type of Laptop ? and operating system on it ?
Restoring your laptop to factory settings can take up to an hour to perform, depending upon the type of laptop and operating system on your machine. Prior to performing a system recovery, you should remove any external peripherals, such as ExpressCards, PC Cards, and USB-connected printers and hard drives. Turn on the laptop. Press the "F8" key until the "Advanced Boot Options" screen appears. Select "Repair Your Computer" using the arrow keys. Press the "Enter" key. Choose your "Language," then "Next." Login with an administrator-level username and password. Click "OK. Select "Dell Factory Image Restore," then "Next." Tick the check box next to "Yes, reformat hard drive and restore system software to factory condition." Click "Next." Click on "Finish" after the computer has concluded the factory restoration. b> Restore on an HP b> Insert the HP recovery disk. Restart the computer, and press the "F11" key. Press the "F" key to "reinstall factory settings." If your computer's operating system is damaged, you may only see "perform a full system recovery" as an option. In this case, press "R." Insert any disks if prompted by the restoration program. Otherwise, permit the computer to restart as needed. b> Restore Via Disks (Generic) b> Insert the "Recovery Disk" or "System Recovery Disk." If you have more than one disk, make sure you insert "Disk 1" or "Part 1." Press any key to boot from CD if prompted to do so. Choose a "Full System Restore," "Restore Factory Settings," or another option worded similarly. Confirm that you want to perform the restoration. Press "Next," "Yes," or "OK," as needed. Press "Finish" or "Restart" when prompted by the computer. Hope this helps.
Dec 23, 2012 | Computers & Internet
I have an acer aspire 4736g, i need to restore my notebook to factory default, i wait for the acer logo to appear on the lcd screen. then i press the "Alt" and "F10" keys at the same...
Instructions
Things You'll Need:
Acer PC or laptop
Step 1:
Click "Start" menu.
Step 2:
Click "Programs."
Step 3:
Click "Acer Recovery Management."
Step 4:
Click the "Restore" button on the bottom of the dialog box that opens.
Step 5:
Click "Restore System to Factory Default."
Step 6:
Click "Yes" in the warning dialog box which asks if you wish to continue the recovery process.
Step 7:
Click "Start" to restore the computer to the default factory settings.
Tips & Warnings
If you are unable to access the Start menu, use the recovery CDs that came with the computer or visit Acer's website (see Resources below).
Always make a back-up CD before restoring a computer to factory defaults.
Resources
Acer Website
Mar 01, 2011 | Acer Computers & Internet
How to restore my laptop to factory settings
If you are using Acer computer then you can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction.
NOTE: This will erase all the datas on the computer.
You can also create a set to Recovery disk from the recovery partition, to do so
Start Menu> All Programs> Acer erecovery management> Click Create Factory Default Disk, if you receive any error code or unable to burn the disk, please contact Acer Technical support at 1 800 816 2237 and order for an Recovery Disk.
Thanks and regards,
Jitha
Feb 06, 2011 | Computers & Internet
How to format acer aspire 5315 without disk? its so slow!
Formatting without disc is slow on all laptop brand.
If you want a fast formatting use the installation disc.
Thanks.
Jul 26, 2010 | Acer Aspire 5315 Notebook
Restore factory settings to acer aspire laptop
Restore and recovery
The restore and recovery features allow you to restore or recover the system
from a factory default image, from a user created image, or from previously
created CD and DVD backups. You can also reinstall applications and drivers for
your Acer system.
1 Press <Alt> + <F10> or select Acer eRecovery Management from the
Empowering Technology toolbar to start Acer eRecovery Management.
2 Switch to the restore and recovery page by selecting the Restore button.
3 Select the backup point you would like to restore from. You can also
choose to recover the system from a factory default image, recover from a
previously created CD/DVD or reinstall applications and drivers.
4 Follow the instructions on screen to complete the process
Jul 15, 2010 | Acer Aspire 5050-3242 Notebook
Cant restore factory settings Acer Aspire One A110-Ab 8.9" 1.6 GH
Unlike other laptops, Acer laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer laptop to factory setting.
Step 1: Before starting your Acer laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer laptop to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer laptop is reset to factory settings.
Tips: You can also create a backup copy of your laptop data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
If you have any other issue with your Acer laptop/desktop/Notebook, feel free to get expert technical assistance at
http://www.vtechsquad.com/acer-support/
Jul 13, 2010 | Acer Aspire One Netbook 8.9" Notebook
How do you Reboot a computer back to factory setting
Instructions Things You'll Need:
  • Factory Settings CD
    How To Use the Restore Factory Setting CD
  1. Step 1 Make sure to transfer all of the files you want to keep to a USB memory stick or burn to a CD.
  2. Step 2 Put the "Restore Factory Setting CD" into the CD drive. This CD was packaged with your computer.
  3. Step 3 Confirm you want to restore the factory settings. The computer will begin restoring all settings. Don't disturb your computer, as this process can take several hours. .
  4. Step 4 Reboot the computer to complete the process.
  5. How to Reboot Using the Computer Start-Up
  6. Step 1 Turn on your computer. Right away there will be a black screen. You can restore factory settings without a CD, too. This will reset your BIOS.
  7. Step 2 Press "F1" when the black screen appears to enter the setup configuration mode. You will be presented with a menu.
  8. Step 3 Select "Restore Factory Defaults." That's it. Your computer will do all the work for you. Like the CD, this process may take several hours.
Jan 27, 2010 | Computers & Internet
I need to set acer aspire 3000 back to factory settings without disk
Step 1 : Click “Start” menu.
Step 2 : Click “Programs.”
Step 3 : Click “Acer Recovery Management.”
Step 4 : Click the “Restore” button on the bottom of the dialog box that opens.
Step 5 : Click “Restore System to Factory Default.”
Step 6 : Click “Yes” in the warning dialog box which asks if you wish to continue the recovery process.
Step 7 : Click “Start” to restore the computer to the default factory settings.
Jan 16, 2010 | Acer Computers & Internet
How do i restore to factory settings without disk?
I assume you mean factory installation. You need the disks. Unless there is a recovery partition, unlikely on this model. Alternatively you could find an oem windows xp home or professional depending on what coa sticker is on the laptop and install that.
Jun 16, 2009 | Dell Latitude D620 Notebook
Restore to factory default
Perform a system recovery:
Acer computer's do not ship with recovery CD's - there is a program that allows you to burn the disks or recover.
3 ways to recover:
1. If in Windows - Start - Programs - Acer empowering technology - Acer E-recovery management -
click on Restore at bottom then "Restore to factory default settings"
2. Or click on Burn disks instead of Restore
3. If unable to boot into Windows then tap Alt/F10 during boot right after Acer splash screen when starting up the computer.
4. This will start the Acer E-recovery program - choose Factory Default Settings and follow instructions.
For Acer end user technical support, spare parts and service: 1.800.816.2237
Dec 16, 2007 | Acer Aspire 5610-4648 Notebook
HP Pavilion dv1000 Notebook Logo
412 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
