Question about Acer 22" X223w LCD Monitor
It says "no signal" even tho' i've installed monitor
    Brigadier General:
  • 7,191 Answers
"No signal" error may be due to various reasons which include:
1. The cable is not attached securely to the VGA socket on either the computer or the monitor end. Remove the cable and reconnect it securely.
2. The cable or the cable pins are damaged. Check the cable for any visible damage or bent pins.
3. The video card or the on-board video of your PC has malfunctioned. Connect your monitor to another source to rule out this cause.
Also, please let us know your PC configuration, make and model and also the operating system. Thanks.
Posted on Sep 04, 2009
How to reset tablet
Tablets have a weaker transmitter, so even though you might have good signal, your device may not be able to transmit back to the wifi radio.
move closer to the wifi radio, or install another wifi radio in the area you need faster coverage.
Aug 20, 2014 | Tablets & eReaders
My Insignia Monitor doesn't work with my laptop, I've tried everything, from pc settings to cables, etc, i only receive a NO SIGNAL ad
Usually you have to toggle the display output on the laptop. The FN key + one of the F# keys with a monitor icon on it. Toggle it until it outputs to the monitor. Your getting "no signal" because no signal is being sent to the monitor or you have the monitor on the wrong input if it has multiple inputs.
Dec 24, 2012 | Insignia Computers & Internet
Hi, I've just purchased a Hanspree SV32AMUB for my Dell monitor. The TV doesn't pick up the signal even though the PC is connected to the HDMI-1 port, and I've set the input to HDMI-1. C
I assume HANSPREE SV32AMUB is an external monitor and you want to watch what is on your laptop PC transferred to your TV. If this is the case Toggle the Fn key on your laptop.
EXPLAIN IN DETAIL WHAT YOU HAVE AND WHAT YOU WON'T TO DO. I'M A LITTLE CONFUSED
Apr 07, 2012 | Computers & Internet
My computer won't read the new camera I've got. Even after installing all info from cd. Have tried camera and it works on tv. It won't let recognise the device on problem either. What can I do?
A camera that works connected to a TV without software is not the proper device to connect to a computer. Check again with your packaging and instructions.
Having a camera working on the computer and then porting the video signal to a TV monitor is the preferred arrangement.
Install the software, reboot, then connect a PC camera, it should be recognized and be testable on Skype, etc.
Sep 12, 2011 | Dell Dimension 3100 PC Desktop
Acer x136w monitor, no signal. Connected parralel conector to back of computer. no signal..tried everything I know to do. Even stupidly pirchased driver whiz. nothing. ready to through monitor into th e...
No signal message on your LCD monitor screen means that your monitor is not receiving any signal from your PC graphic card. This problem "no signal" have nothing to do with the drivers installations. Have you check whether your graphic card is faulty or your cable connection properly connected/secured? ie VGA (D-sub). As far as I know there are no parallel connectors for PC Monitor connectors only, VGA(D-sub), DVI or HDMI cable interface.
Try to connect your monitor to another PC, just to test whether the LCD monitor is functional.
Hope it helps.
Mar 19, 2011 | Computers & Internet
Trying to hook up laptop with haier tv using vga
Dod you use HOTKEYS on the laptop to tell it to send the signal the VGA outlet of the laptop? The hotkeys function can be set to turn off the laptop screen and only have external monitor to be the only display or it can be set to have both of them on.
Nov 03, 2009 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
We had an xm radio installed in our 2010 prius after we bought it. It was ''satellite ready'' but needed the radio. We signed up for xm radio and tried to get the signal. The radio was tuned to channel...
go to who installed you sat radio have them pull the antenna and receck the the receiver number it sounds like you have the wrong reciever number even one digit off and it will never conect even tho you have preview and sat radio paired with an antenna will recieve preview
Jul 10, 2009 | 2009 Toyota Prius
Problem with powering the monitor up. It just flicks off.
The operating system would not stop it from powering on.
It should power on even if disconnected from a computer.
You are probably in need of having the powerboard redone. Possibly a failing inverter.
If you know how to take it apart and can get some pictures to me at bammbamm@ptd.net , I may be able to see the problem.
Jun 20, 2009 | Samsung T220HD LCD Monitor
Need the polarity of the adapter for polyview v17e moniter
i'm guessing you don't have the original adaptor to test it... sometimes polarity is printed onto the case where the adaptor plugs in... get out your magnafying glass to see it tho.
Jan 02, 2009 | Polyview V17E 17" LCD Flat Panel Monitor
Acer 22" X223w LCD Monitor Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
