Question about Epson Stylus C46 InkJet Printer
Both green power botton and red reset botton are blinking
When I switch on the printer type Epson Stylus C46 both leds (red and green) are blinking
Epson R230 with green led and red led blinking
This is general error of the printer. When you have to change the new mother board you should be initialized it then it can be ready mode. When you try to initialization you need printer printer adjustment program. You can batter find out from google & write down EPSON Stylus R230 Printer Adjustment program or ink reseat program.
Jun 12, 2013 | Epson STYLUS R230 InkJet Photo Printer
The red LED continiously lights cann't print, both LED constantly lights.
This means that your waste pads are full and the printer needs to be reset with software email me and I will send you the software
Aug 20, 2012 | Epson Stylus C46 InkJet Printer
Hi, I just installed a given Stylus C46 and the green (power) and red (ink) led light alternativly. I try to print something and nothing happen... What can I do ?
Dear friend,,
It's because of the EEPROM Error.Try the following program.
http://www.mediafire.com/?xydczelivyi
download it.Run ADJprog.exe.select printer model Epson c46,destination asia,Port usb or Something you've connected.Click ok.Select Cosumables maintanece counter click reset.
Hope it'll help
Mar 07, 2011 | Epson Stylus C46 InkJet Printer
Red and green lights flashing on epson c46. what do i do?
I guess your printer need to reset the counter ink pad, for reset the counter you must have a adjustment/reseter software, and for your printer type please download <a href="http://www.ziddu.com/downloadlink/7587521/sscserve4.3.exe">here</a>
I hope this link can solve your problem
Dec 16, 2009 | Epson Stylus Photo 1290 InkJet Printer
Epson Sylus c45 problem....
you can download Adjustment program of Epson C45 From "Indoresset"Webside.
The printer have to reset wast pad counter.
Thanks
Oct 27, 2009 | Epson Stylus C46 InkJet Printer
Epson C46 green and red lights flashing, saying parts need servic
Care to read this link
http://tricks-collections.com/2008/06/reset-epson-stylus-color-printers/
Goodluck
By the way emptying the waste bin needs disassembling of the unit then washing the ink foam.
Jul 19, 2009 | Epson Stylus C46 InkJet Printer
My epson stylus c 45 does not operate both red and green keeps on blinking
Hi and welcome to FixYa,
Almost always, your describe concerns and considering the age of the unit indicates that the Epson printer has reached its " end of life " (most likely) or there is an internal fault (least likely). Initially, I would suggest to download and install ' SSC Service Utility for Epson Stylus Printers '. Its purpose is to bypass the counters and reset most Epson printers. The reset would force the printer to revert to factory defaults. The printer would be " fooled " into thinking that it is new (again).
Good luck and thank you for using FixYa.
Jun 25, 2009 | Epson Stylus C46 InkJet Printer
Epson C46 colour printer green and red lights are flashing....but
Basically your printer says that you need to replace the waste ink pads. If this happens for the first time to this printer you can just reset the counter using SSC Service Utility (http://www.ssclg.com/epson.shtml) or if it happened more than once you shoul first replace the ink pads and then reset the counter or the printer may overflow. That's it.
Jun 15, 2009 | Epson Stylus C46 InkJet Printer
Red & Green led is blinking continiously after carriage initial.
The Waste Ink Pads are deemed to be saturated and should be replaced. You can overcome this problem temporarily bu using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and reset the Protection Counter. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C46 Service Manual.
Jan 09, 2009 | Epson Stylus C46 InkJet Printer
Epson stylus c46 printer
u put the cartridge and press red button
Jul 15, 2008 | Epson Stylus C46 InkJet Printer
Epson Stylus C46 InkJet Printer Logo
94 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
