Question about Gateway Computers & Internet
Gateway 704GE Is the optical drive IDE? I think SATA is too new for this model.
    Problem Solver:
  • 19 Answers
Ok this should be easy enough for you to figure out. your computer is a desktop correct?
If not then ignore this.
Open the side cover. usually 3 screws on the right hand side of the back. and look at the optical drive. The cable coming out of the back<Flat Ribbon type cable and you got IDE>< A SATA cable is about the width of a pinky finger if that> Hope it helps. And i'm pretty Sure it's IDE but just check insid and get your answer.
Posted on Sep 04, 2009
I installed a sata dvd drive in my dc5100 sff the boot order recognises it as an ide drive
i dont think it matter if your system detects it as sata or ide, both interface will work in installing OS, the important thing is you changed your boot order. originally it was supposed to boot in 1st drive whichever it is hard drive or dvd drive. go to bios then follow the instruction in how to move the order of boot sequence, mine is SHIFT key then PLUS.
Feb 28, 2014 | HP Compaq dc5100 Small Form Factor PC...
How to connect a cd rom/dvd
If your CD / DVD is powered on Ok then you are missing the data cable connection which will be either a SATA (small connector) or IDE (much larger connector) both of which plug in to your motherboard....Look at the CD / DVD and try to identify which type of connector you are missing then look for an unconnected cable of the same type within your case.
Dec 17, 2011 | Gateway LX6820-01 Desktop PC
Hello, What is the largest hard drive I can upgrade too for my Biostar 330G? Can I use a SATA and install a IDE hard drive as my slave backup? Thank you. Remi
As I recall, this model has one IDE channel on, which typically powered an optical drive. The manufacturer claims that it supports one IDE drive, in theory, you could set the IDE HDD on the second connector of the IDE cable (secondary slave), however, it may be that the Bios will not recognize this.
My own thoughts would be, as this has 2 SATA ports, to leave the IDE connection alone and for the Optical drive and put another SATA HDD on the other SATA connector.
If you need to use the IDE drive, you can get an IDE to SATA adapter and that would enable you to use it connecetd to the SATA connector
As to capacity, I'd assume it would run any size of HDD
Jun 23, 2011 | Biostar iDEQ 330G (IDEQ330G) Barebone
What kind of optical drive uses the gateway 3610gzits sata or ide
Look on this page: Gateway 3610GZ. It's not on the specifications page, as you would expect, but if you go to Components > DVD drives > Main View it says Enhanced IDE (ATAPI) I would double check before buying a new one, though. Just take the drive out. There are usually only 1 or 2 screws holding it in on the bottom, and the drive should slide out the side.
Dec 23, 2009 | Gateway 3610GZ PC Notebook
How do i change my sata controller to use ide?
Buy an IDE controller. Then install it.
OR
Buy a SATA hard drive and install it. SATA drives are faster. If you need to get data from your IDE drive to a new SATA drive, try using a IDE slave cable. These connect an IDE drive to one of your USB ports and allows you to use the drive just like an external hard drive or USB thumb drive. Pretty cool stuff. Have fun.
Oct 17, 2009 | Gateway DX4720-03 PC Desktop
ASUS P5QC does not detect any devices... I have a HD and a DVD hooked up. The jumpers are set to normal but they are connected to the MB with one cable. Does it need to be a master slave setup?
Yes, since you are using two IDE drives on One flat ribbon cable, you need to set the harddrive as a Master drive, and the optical, (DVD), drive as a Slave drive.
When two IDE drives are installed on one cable, BIOS needs a way to find the drive that has the O/S, (Operating System), then the optical drive.
Would recommend you buy a SATA optical drive, as soon as you can afford it. SATA DVD burners aren't that expensive.
Your motherboard is set up for SATA, and SATA is WAY faster than IDE. (IDE is also referred to as EIDE, ATA, and PATA)
Then of course a SATA harddrive, and a fresh genuine copy of Windows in the future.
SATA doesn't care where you plug in a drive, and doesn't care which drive connects to what SATA header. It will find that drive. You can connect any SATA drive, to ANY SATA header on the motherboard.
Having two IDE drives such as an IDE harddrive, and an IDE optical drive on the same cable, S-L-O-W-S your computer down! BIOS has to look to see which drive has the O/S first, then it will look for the optical drive.
Thought I would include two links that tell you, and show you how to set jumpers on the jumper pins, on an IDE harddrive, and IDE optical drive,
1.Harddrive:
http://www.youtube.com/watch?v=WwbboeMO7b8&feature=related
2.Optical drive:
http://www.youtube.com/watch?v=lldXwgPabhE&feature=channel
Should my solution have helped you, feel free to rate it.
Jul 13, 2009 | ASUS P5QC Motherboard - Intel P45, Socket...
Installing SATA optical drives on a Gateway 835GM Pc with an Intel [Big Lake] 945G Motherboard.
Enrico,
I would just physically remove the drives and the connecting cable(s) and reboot your computer. Look in the device manager and make sure they are gone. They should be gone, but if not, you can then remove them from it.
There is no certain slot to install the new drives, just use the next 2 slots. You can set the SATA Bios setting anytime. I think most defaults are set to Auto anyway.
I would leave the jumpers on CS.
As far as drivers, I would assume there will be software with drivers enclosed with the new drives. Windows will recognize the new drives, and when it asks about drivers, there should be a "Have Disk" selection if you get a CD with the drive. (If no CD, have it install/search for the best drivers.)
There will no doubt be installation instructions enclosed with the new hardware too. Read it thoroughly. It may answer much of what you ask here. Good luck.
Jan 10, 2009 | Gateway 835GM (835GH) PC Desktop
CD/DVD Burners for Gateway 835GM PC
Your system has 4 SATA controllers which I mentioned on your previous question. Yes, they will work.
SATA drives are faster than the IDE interface drives.
Here is your motherboard:
The SATA connectors are those 4 approx. 1" vertical black connectors about a 3rd of the way down. The IDE connector is the horizontal one right on top of them.
As long as the SATA controller is set to Automatic in the BIOS, you should not have any problems. Also, the new drive should come with a SATA cable.
Jan 08, 2009 | Gateway 835GM (835GH) PC Desktop
Gateway 710 x
Not really sure about "flogs"? .... but I think you bought a SATA drive instead of an IDE drive?
Yes you can get adaptors ... here's one supplier if found through Google: http://www.8starshop.com/en/ide-to-sata-serial-ata-bilateral-hdd-converter-adapter.html?language=en&currency=GBP
Dec 26, 2008 | Gateway 710 X PC Desktop
Connecting new hard drive
If the old one is still conected you can connect it the same way if not here is how to::
Well firstly they are 2 types IDE (large connector) and SATA (small connector)
IDE
of an ide cable has 3 jacks 1 for the main board and 2 for IDE drives
2 drive must be set to master and the other to slave
Set the drives by using the jumper on the back the instructions are written on the drives
Connect the Ide Cable and then the power and turn you system on
IF ITS SATA
connect the sata cable to both hard drive and main board
connect the power cable and your done!!
NB:: sata ports are labeled SATA 1 SATA 2 etc
IDE are LABELED IDE 1 IDE 2
Ide is a large grey cable black connector SATA is usually orange or red and small
Oct 26, 2008 | Gateway (M520HD80G) Hard Drive
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
