Question about Scotsman DCE33PA1BC 15in Built-in Automatic Ice Machine/Maker w/ Drain Pump, Black
No ice we have run the cleaning solution through on a regular basis and vacuum the coils as well. ice volume got less by the day and then just stopped.
  • Scotsman Master
  • 8,220 Answers
Manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Nov 05, 2009
  • 3 Answers
Repalced the evap thermisiter and water fill sensor
Posted on Sep 12, 2009
GE fridge not cold.
If the coil (in the freezer) is icing up then it's not being properly defrosted on a regular basis, ie. 2 - 3 times a day. On older models it's usually just a simple matter of replacing the defrost timer. On newer models, the defrost timer is integral with the 'motherboard', so the whole (expensive Chinese made) motherboard must be replaced because they're not serviceable.
Less likely (but possible) are the defrost heating element and/or temperature sending unit found on or near the coil itself. Least likely is a low refrigerant level, which would indicate a leak.
Mar 27, 2014 | GE Refrigerators
What are the health benefits of carbonated drinks?
Carbonated water is almost as beneficial to health as plain water. When compared to regular water, sparkling water has the ability to cause dental erosion, but the negative dental effects of carbonated water are negligible. However, adding sugar or acid substances to carbonated beverages greatly increase these negative effects. Carbonated water is good for hydration, although fizzy water has less of a hydrating effect than the same volume of regular water. The taste and texture of carbonated water may lead you to drink a greater volume of sparkling water than you would have consumed had only regular water been available. Carbonation is one way to increase consumer interest in drinking water.
Feb 04, 2013 | Wine & Spirits
Cleaning & Maintenance
From general experience (I'm 55) : Depends on where the heat transfer coils are; on the back or the bottom or both. If on the Back: should be cleaned with a brush & vacuum at least every 3-6 months. If on the bottom, about every 2-6 months. Bottom coils can usually be accessed from the front by opening the door/ removing drawers and pulling off an access cover. Bottom coils also usually have a Fan that can get clogged with dust/ mice(Yes! Mice.) that hurts the performance also. May have to pull it out and remove a back cover. For the rest, Check the condition of the door seals and replace any that are not completely closing. Keep the seal surfaces and the insides clean. Defrost regularly (every1 to 2 months) to prevent ice buildup. Some units also have interior fans, that are supposed to function when the unit is attemting to cool.
Mar 25, 2012 | Samsung RF265AA Bottom Freezer French Door...
How do I go about 'cleaning the coils' on a GE profile model - freezer is having trouble holding 0 F and I was told this would help. thanks
It is not necessary to clean the evaporator coil.
The condenser coil underneath may need cleaning.
Use a long handle bottle brush and a vacuum cleaner.
Your refrigerator freezer temp will fluctuate from minus 5 degrees to plus 18 degrees on a regular basis.
It will not be a steady temp.
Jul 24, 2010 | GE PDS22SBRLSS Bottom Freezer Refrigerator
I have ice build up in the coils and the freezer is not freezing , thawed the coils with a dryer but in a couple of days it is back again
Can't locate specific manual for your product but sounds like a defrost problem.
Unit should defrost on a regular basis. Usually controlled by a timer. It should turn refrigeration system off, including fans, and turn on heaters to clear any frost or ice on the evap coils. Cycle varies on usage. Look for timer and see if it is running. Make a mark on it and give it an hour and check again to see if it has moved.
Hope this gets you started.
Mar 03, 2010 | Arctic Air 22 cu. ft. Commercial Freezer...
MSD2656GEQ The coils on the freezer side ices up, then does not cool the refridgerator side
Hi, It's a common problem with no-frost refrigerators, you have a defrost problems, two scenarios. (1) hot air entering freezer/refrigerator, examples. hot summer days, regular openings, high room temperatures, hot foods and broken door gasket, leaving freezer/refrigerator doors slightly open overnight, could cause your evaporator (coils) to freeze/ice up. cases like this, unplug/disconnect your refrigerator, remove produce, clean and let it defrost, for an hour, make sure all ice melted. plug or reconnect your refrigerator let it work/ run empty for another hour, then put back your produce. sure it will work perfect for the next 3-4 days. (2) next type of defrost problem could be faulty defrost heater, defrost thermostat, you will have to open back panel on freezer side to check. check your defrost heaters, defrost thermostat and defrost timer, it's better to change defrost timer and defrost thermostat together, or change faulty ones independently. but before you change any parts, clean and defrost refrigerator first, could just be regular openings, hot days, etc. if after 3-4 days it started to ice up, then check following parts. defrost heater. defrost thermostat and defrost timer, let me know if icing occurs after 3-4 days then we can check those parts i suggested. remember to always disconnect/unplug your refrigerator, before attempting any repairs. good luck
Aug 21, 2009 | Maytag MSD2656G Side by Side Refrigerator
GE ice maker is getting hot
You need to remove the ice maker the function that heats the lower element should last only a few seconds so I believe the ice maker will need to be rebuilt or replaced. Sea Breeze
Jul 24, 2009 | GE Monogram ZDI15C Automatic Icemaker
Leaking & icing on inside coil Rheem Air Conditioner
Dirty coil. Low refrigerant. Bad fan motor.
These 3 things cause the problem described.
I charge $450 to remove and clean the coil. However, I am not in your zipcode.
Jul 05, 2009 | Heating & Cooling
Freezer/refrig not getting cold at all
Your most likely having a start relay problem. You should be hearing two motors the fao and compressor.This is a pretty easy fix. I recommend getting a 3in1 start assist kit less than 20.00. Just go with the diagram on package, it will be upside down fro the picture on package.
Mar 15, 2009 | Refrigerators
Jenn-air JRSD 226 side by side Fridge
Check to see if there is frost on the rear wall o f the freezer wall. If so, the units cooling coils (behind the frost) may be covered with ice. Defrosting is necessary. The refrigerator may not be defrosting at regular intervals a required. Standing open for a couple of days should defrost it but it will still be necessary to find out why it frosted over. There is a defrost control that automatically melts ice from the cooling coils on a regular basis. Maybe this control is not functioning.
Aug 29, 2008 | Jenn-Air JCD2389G Side by Side...
Scotsman DCE33PA1BC 15in Built-in Automatic Ice Machine/Maker w/ Drain Pump, Black Logo
231 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
John Tripp
John Tripp
Tim Whalen
Beto Flores
Beto Flores
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
