Question about Sewing Machines
Can I adjust the needle bar on a necchi esperia? My needle is hitting the plate to the right by just the tiniest bit. Is it suppposed to do that? It isn't interfering with sewing, but it is clicking just a small bit.
  • 1 more comment
  • bmoyer1 Sep 04, 2009
    It is a new needle. I actually tried a couple of different ones.
  • 125 Answers
It may be that your needle is just bent a bit. try a new needle or take that one out and have a look at it
Posted on Sep 04, 2009
  • colinjhought Sep 04, 2009
    I don't know of any adjustment (I was thinking maybe the arm is actually bent caused by a needle impact). you could try enlarging the hole in the plate or looking for a bend in the arm
Pfaff tiptronic 2020
It adjusts the needle plate position front to back.
Mar 25, 2016 | PfaFF Sewing Machines
Feed dogs are hitting the needle plate
Needle is bent replace with new needle. You may need to adjust feed speed so that needle doesn't bend. Good luck
Jun 06, 2015 | Sewing Machines
Necchi sewing machine
There are a number of things that could cause this.
Needle installed with flat in the wrong direction.
Excessive thread tension,top or bottom.
Lack of lubrication. If the machine can do anything more than a straight stitch the mechanism can gum up and not move the needle correctly.
Here is a link to threading directions.
Necchi 3537 Sewing Machine Threading Diagram
Aug 03, 2014 | Necchi 3537 Mechanical Sewing Machine
I have a Singer Quantum XL-1. After replaceing the needle bar stopper, now the machine will start to embroidery, but when the need goes to the right, it stops going up and down. Is there something that...
Hi
Take off the bulb cover and check that the buffer at the end of the on the curved spring above the needle bar. It deteriorates like the needle bar stopper you just replaced. If it is still there and in good condition then your machine probably now needs adjustment/service.
Sep 22, 2013 | Singer Sewing Machines
Needle hitting stitch plate on my Viking Lilly 545 recently had it serviced, was sewing fine
try a new needle
if the needle is still hitting the needle plate, then it's possible that the machine is out of time and needs to be adjusted, or there is something wrong with the needle bar.
Nov 13, 2012 | Husqvarna Sewing Machines
I own a Necchi model 535f......I have had it cleaned and oiled in the last 4 years....I can't get my fabric to feed through my machine
The feed dog & the presser foot have to work together to feed the fabric thru the machine
The feed dog should be seen when you look at the needle plate, if not the feed dog setting should be checked--the feed dog lever may be to the right of the bobbin area
Open the light bulb door also called the Lamp Cover door or Face Plate,, there should be a knob at the top round or star shaped,, that adjusts the needle bar that puts pressure on the presser foot,, it may have numbers or letters, mine is a star shape & has numbers on it & is set between the 2-3
Adjust it a little at a time & then sew to see which setting is best for your machine
Oct 21, 2010 | Necchi Sewing Machines
Needle hits needle plate with heavy fabric
that is your problem, your needle bar is centered too far to the back. There are 2 little bolts (Below the presser foot lift on the back of the machine) that must be loosened while the needle bar is repositioned aligning the needle bar assembly.
Mar 23, 2009 | Bernina 1008
Kenmore sewing machine 385.1960180, problem with needle centering
That sounds like it's definitely an internal adjustment. The machine will need to be opened up and the left/right adjustment taken care of. Is this machine one that you can open the top easily, or is it the type that has the front and rear shell?
Feb 20, 2009 | Kenmore 15516 Mechanical Sewing Machine
Needle continues to hit plate
Sounds like the needle is not inserted correctly, take it out and make sure it is in the right spot and the right way around, (has Flat on one side)
Aug 18, 2006 | Bernina Artista 180
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
