Question about Refrigerators
Only thing that works are the lights
I have a KitchenAid KSRS25Q, and we woke up this morning and the refrigerator has stopped working. Appears the only thing working are the lights. I don't see any of the f'ans moving and the evaporator is warm.
  • 11,896 Answers
Check power to compressor. If compressor is not running, check for fuses and relays. You can test each with an ohmmeter set in ohm setting to see if there is ressitance. If fuse and relays are good, then you may need to have the compressor serviced
Posted on Sep 04, 2009
Freezer side not cold enough, similar temperature as Refrigerator side
It could be many things. My first guess would be the defrost. The coil that gets cold in your freezer builds ice on it and the only way to get the ice off is to run a heater near the coil long enough for the ice to melt. All freezers have something built in to defrost and domestic are typically just an electric heater on a timer. When your freezer stops working again, you may want to pull open the panel of your freezer and see if your coil (a heat exchanger that probably looks a lot like your car radiator) is covered in ice. If it is, it could be the timer or the actual heater that is bad.
Nov 12, 2013 | Refrigerators
Water and ice dispenser and panel light stopped working.
02227c0.jpg Look at above diagram. #18 needs to be replace. Trim pops off then there will be several screws. Goodluck...
May 30, 2007 | KitchenAid Superba Architect KSCS25INSS...
My KBRA20ELSS 01 Kitchenaid-mount refrigerator has stopped working. I opened the freezer tonight and the ice had all melted and the food is defrosted! I don't think the refrigerator is cooling either. ...
if both the fridge and frezzer are not working then it can only be one of two things the thermistate has blown or the motor has stopped working start by having the thermistate checked
best of luck
please remember to rank my reply
Dec 01, 2010 | KitchenAid Refrigerators
Freezer is working fine. The refrigerator is not
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 02, 2010 | KitchenAid KSCS25FKSS Side by Side...
We woke up this morning with the lights flashing and the ice maker shoot door clicking every 6 seconds and it won't stop. Any ideas how to reset it or get it to stop?
Your High Voltage control board has gone bad there are capacitors on the board that are bad and you can try to replace them or buy a new HV board.
May 29, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
It just stopped working? Is there a reset button
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
May 07, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore refrigerator not working
Hi!!! Go to the back of the frig and see if the compressor and condensor fan motor are working.If not then you have a bad current relay.easy fix.its located in the compressor where the wires go into..Good luck.Heres a picture of your current relay..
Jan 04, 2009 | Kenmore 57029 Side by Side Refrigerator
Model number: KSRB25FHSS05
hi .thanks for the question .is the fridge on, is it running. if not. it could be in defrost mode .if it is running .pull freezer from the wall, remove back panel ,clean all coils. thanks the appliance doc
Sep 13, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
152 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
