Question about Fuji FinePix S3 Pro Digital Camera
Blank lcd screen when camera is on
When i turn on my camera, i see a bright white screen, the lens still opens, i can still take pictures and view on computer, but NOTHING is on my screen. i tried playing with buttons over and over, i hear beeps, like its going through all the menus, but i still cant see anyything, from what i can tell everything else seems to be working. help! i am not able to preview my photos via the lcd screen, before i shoot. after taking a photo it shows, but i want to be able to shoot by my lcd screen not my view finder...help!!
  • 1 more comment
  • Anonymous Jan 01, 2008
    When we turn on our FinePix A800 in camera mode it just displays a
    white screen. When you turn to video mode it just displays a
    black screen. This is kind of baffling to us because it worked
    perfectly well for a couple of months.
  • Anonymous Jan 22, 2008
    Same as you. Screen for my camera does not work. And I bought it just 10 months ago!
  • smithcurtis Mar 05, 2009
    I have the same thing happening. The lcd screen is white. Any help would be great.
Same thing happened to me. All I saw was a white screen. So I took apart the back to have a look. I used http://www.lifepixel.com/ir-tutorials/fujifilm-s3-pro-digital-infrared-conversion-instructions.htm as a ref. I took the LCD screen out and put it back. The cable was not connected properly. Now It Works Great.
Hope this helps
Posted on Jun 27, 2009
No solution for your first problem but it's normal that you cannot view your photo on the LCD screen before actually taking it. Due to the way a reflex camera is built, you can't have a live view on your LCD. The Fuji S3 Pro has this type of preview as also most recent camera (Nikon D300, Canon 40D...).
Posted on Mar 05, 2008
The sony cybershot screen is bright white with unclear images.
It is problem of lcd screen that will be replaced to get correct picture view.
Local camera repair shop will replace it or if you have expertise then can replace lcd screen by yourself.
Let me know if you need part number of lcd screen for DSC-S930 camera.
Thanks.
May 23, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
My lcd screen will not show the picture. The
First try pressing the DISP or DISPLAY button to make sure that you didn't accidentally turn off the LCD. But if that's not the case...
Try taking and downloading a picture taken while the screen is blank. Is the picture also blank? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Read the users comments there also for more tips.
Jan 31, 2010 | Canon PowerShot SD1000 Digital Camera
Problem with canon a420 digicam
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Note that your camera will not be able to take 15 second exposures, as per the above "fix". Instead, place the camera in manual mode, turn off the flash, and take the exposures in a darkened room. This should give you a couple seconds, just enough time to open the battery door while the red and yellow lights are flashing.
Sep 21, 2009 | Canon PowerShot A420 Digital Camera
LCD screen is blank and pictures are also blank
Jul 24, 2009 | Canon PowerShot A620 Digital Camera
My S2 IS all of a sudden cannot see anything out of either the lcd screen or view finder. I can see all of the settings on those but just a blank screen. Yes, my cap cover is off. Any thoughts?
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 08, 2009 | Canon PowerShot S2 IS Digital Camera
White screen on my camera and can take picture picture is black colour
hi
i think the LCD has been set to a very high brightness set the LCD brihtnes lower from the settings..
better more is to reset the camera to the default settings this would set the aperture, shutter, Exposure, LCD brightness and other settings to defaults and this would save from any unwanted changes than required
cheers
pls rate if it was any help
May 17, 2009 | Samsung Digimax L60 Digital Camera
The picture we have taken was white/grayish screen- no images..
I got it repaired at canon service center in India for Rs 1900.
Next camera I will insure !
Jan 19, 2009 | Canon PowerShot A460 Digital Camera
Black blank screen
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Oct 20, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Blank camera screen
I hope you sent it back to Fuji before your guarantee ran out.
Sep 07, 2006 | Fuji FinePix E550 Digital Camera
Fuji FinePix S3 Pro Digital Camera Logo
277 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
