Question about Radio Communications
We need a wiring Diaghram for a Realistic TRC 495 Echo Mic.
Do you have any Wiring For a TRC mic.
  • George cv
    George cv Jan 17, 2009
    would you have the pic code for the mic of a uniden grant?or is the same for all cb radios?/??
  • Dean Dishman May 11, 2010
    should be a 5 pin all realistic cb 's should be the same
    1- Shield
    2- N/C
    3- Transmit
    4- Audio
    5- Receive
    Astatic (4 wire)
    1- Shield
    2- N/C
    3- Red
    4- White
    5- Black
    Astatic (6 wire)
    1- Shield & Blue
    2- N/C
    3- Red
    4- White
    5- Black
    Yellow NC
    1- Shield & Red
    2- N/C
    3- Blue
    4- White
    5- Black
    Yellow NC
  • 1,274 Answers
You can download it at ....hope this helps....
Posted on Mar 12, 2010
1 black and shield 2n/c 3 white 4 red 5 blue.. this is for turbo ec2018 echo mic to a trc-495 base
Posted on Oct 15, 2012
Mic wiring diagram for a realistic Navaho TRC -490
Check out this website It should help you out. Also, your D-104 should have the amplifier in the base. You'll see a hole in the base with an adjustment beneath it. You will have to adjust your transmit level with this. Make sure that you have a battery installed!
Dec 13, 2017 | Astatic Radio Communications
I want to wire my superstar dm452 power echo mic to my realistic trc 465 am ssb and need to know what color goes to what pin?
its a 5 pin which all radshack radios are and they are all,99% anyway, wired the same . So take an old radshak mic apart at the plug and see how it is wired then experiment from there.
Apr 07, 2015 | Workman Publishing Workman DM-452-5 model...
Realistic mic wiring
why not just buy a cobra mic,it would be easier.
Jan 06, 2014 | Cobra Radio Communications
Need mic wiring diagram for trc-446
you may have to order one from radio shack because the wireing diagram is for that radio and mic only . You cannot use another mic on that radio , only the one that comes with it . If you are patient enough and have another mic with the same controls you could wire it up. it has to be ( I think a 6 pin ) ???
Nov 10, 2013 | Radio Shack 40 Channel Cb Radio Model...
Six wire mic to a trc 495
Realistic radio mics are all , except for a few , wired the same. All you have to do is look up the wiring for the realistic 5 pin din plug . One of those wires in the mic is not going to be used the thing is which one . Connect the wires as they are mentioned in the diagram then if it doesn't work connect the last wire.
Oct 26, 2012 | Radio Shack Radio Communications
Trc 520 mic wiring dia
not sure what type pinout you have but if its a din plug any realistic mic should work.
Feb 22, 2012 | Radio Shack TRC-521 CB Radio
I need to know what colers go where on the mic pin for a trc 447 thank you
I don't know which mic you're trying to wire to this radio. The colors of the wires in the mic cable may change from one mic to another, so relying on the color is not reliable. Usually you refer to these connections as Pin1 to a Signal or Function; or Jack Pin1 to Plug Pin3. No one assumes a color will always be used to connect Pin1 to TX (transmit).
With that said, I found an answer on FixYa from someone that answered the question some time ago like this:
4.)CH.Down / Shorted to Ground
6.)Ch.Up / Shorted to Pin 4
Be extremely careful when wiring this radio! pin 4 and pin 6 carry voltage shorting these to the wrong place can result in serious damage to your radio.
Lastly, since I doubt what was provided above is going to help you very much - you can review all the info ever printed by Realistic on your radio, here. There's a wealth of info on this page and you should be able to find what you're looking for in it. You're looking to find the pinouts of the radio to the pinouts of the mic.
If you ever have to disconnect a multiconductor cable from a connector, and you don't have the time or means to write the colors down, it is better to simply cut the cable - leaving all the colored insulation of wire ends soldered / still secured to the connector. When you are ready to do the replacement of the connector or cable, you've got the wiring order in place still, and can make the new connections one at a time at your leisure.
Aug 11, 2010 | Radio Shack TRC-447 CB Radio
Need a new mic for TRC447 radio Shack CB. Has a 6 pin connector
Hi Old
here is the link to wire up a different mic look on pg. 51 of this pdf.
hope this helps save this radio from the trash!!!
Aug 05, 2010 | Radio Shack TRC-447 CB Radio
Mic wiring diagram
Want to wire cobra mic to a uniden washington radio
Nov 20, 2007 | Radio Shack TRC-447 CB Radio
Radio Communications Logo
544 people viewed this question
Top Radio Communications Experts
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
