Question about Kenmore Dryers
Doesn't dry clothes
Tumbler spins and we see flame light at bottom of dryer. Vent is clear and not kinked. Filter is clean. But it takes 2-3 60 minute cycles on Normal to dry clothes
  • 331 Answers
Did anyone assist you on your heater problem?
Posted on Sep 12, 2009
DRYER HAS NO HEAT. TUMBLER TURNS OK. LINT FILTER CLEAN.
Make sure the dryer exhaust tube is clear of lint and not kinked. Next thing I would check are the thermal fuse and thermostat. Check this out: http://removeandreplace.com/2013/09/21/fix-clothes-dryer-heating-drying-clothing/
May 05, 2015 | Washing Machines
I have replaced radiant flame sensor, high limit thermostar, cycling thermostat, coil kit, and blower wheel on maytag dryer ldg9206aae, and still it takes forever to dry and is not hot enough.
if the flame is lighting like it should and you changed out all those parts did you clean out the lint filter duct and clean out the vent line?try removing the vent line from the back of the dryer and run it,if the flame stays on longer and it heats you have a blocked vent line,if the air can't move and that's all a dryer does the clothes can't dry
Apr 10, 2013 | Dryers
My dryer will not dry effectively, it is very slow to dry even on the high heat settings, any ideas?
i looked up your model number and you have a gas dryer not electric,if the vent line is clear and the metal duct that the lint filter slides into is clean i would say you have bad gas coils located on top of the gas valve,when the coils go bad they will work correctly for the first 15 to 30 minutes,when they heat up they fail and the flame won't ignite,so do this remove the screws that hold the bottom panel on,remove the panel and vac out any lint you see,if you have a shop vac you can set the vac up to blow and blow off the motor and blow all the lint forwards and vac it up,do this with the dryer unplugged,remove the lint filter and take out the screws that hold the metal duct in place and clean the duct out,put it back together except for the screws that hold the bottom panel in place but just stick the panel in place,put some clothes in and start the dryer,after around 20 or 30 minutes remove the bottom panel so you can see the ignitor,if the ignitor glows orange but the flame doesn't ignite and the ignitor goes out then you have bad gas coils.you should take the bottom panel off and remove the lint filter duct and blow and vac it out once a year,also if you vent line is long remove it from the back of the dryer and blow it out with a leaf blower,make sure nothing is blocking the outside vent like a cage or a piece of screen so the lint can blow out and not get blocked.the part number for the coils is 279834 and they are around 25 dollars,unplug the dryer,remove the bottom panel,remove the two phillips head screws,remove the cover,slide the coil up and off of the post,unplug the wire and connect it to the new coil,watch out on the big coil,there's a spacer that has to stay on the post,sometimes it gets stuck in the old coil when you remove it,let me know how you make out.
Mar 19, 2013 | Kenmore Elite HE4 Electric Dryer
My Maytag gas dryer model LDG9801AAL has irregular heating. The flame is not 100% bluish even after I cleaned the igniter glowbar. I already changed the dryer sensor but the flame keeps getting shut off...
if the flame is liting the ignotor is good,if the flame goea out after a minute or so then you have to clean out the dryer,unplug it,clean out the duct that the lint filter slides into,clean out the cabinet where the motor is and if the vent line is a long run i use a leaf blower to blow it out,pull it off the back of the dryer,stick the leaf blower into the vent and blow all the lint outside.one more thing if the flame lites and after 10 to 30 minutes thee flame doesn't lite anymore you have bad gas coils you can remove the cover down on the bottom right side of the front panel to check this,also you should clean this dryer at least once a year so you don't have a fire and your clothes will dry on time,pull the vent line off the back and see if it runs any better but you still have to clean the lint filter duct too,the block could be in there,bad air movement will cause this to happen.let me know how you make out.
Sep 25, 2011 | Maytag Dryers
Gas lights up for about 5 minutes and then burns out. Try to turn on dryer again, but flame won't light. I let dryer sit for aout 30 minutes and turn on again - flame starts up, but will only last...
If the flame is shutting of before it reaches the operating temperatures the likely failure is a restricted venting system. There is a high limit thermostat that will cause the flame to shut off if there is a lack of airflow due to a restriction in the vent system. Remove the lint filter screen and clean in with soap and water. The filter may appear clean but it could have a clear film of fabric softener residue covering it causing a restriction in the air flow too. After cleaning the filter reinstall it before running the next test.
For testing purposes only, disconnect the dryer vent hose from the back of the dryer and put a normal load of clothes in the dryer and start the dryer. If the clothes dry in the normal amount of time that would confirm a restriction in the vent hose or the venting system. NOTE: Do not leave the vent hose disconnected after running the test. Reconnect the vent hose.
You will likely find the clothes drying in the normal amount of time indicating a restriction in the venting.
Aug 02, 2011 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
It takes 2 or 3 cycles to dry clthes, has been going on for some time
That's typically an indication that air is not moving through the dryer. Check the dryer screen, make certain that it's clean. You may need to remove the back and clean out any dryer lint. If the dryer vent is long, it may have filled up with lint, restricting air flow. You may need someone to clean that for you.
Feb 06, 2011 | Dryers
My maytag dryer is taking more time than usual to dry up clothing. Can anyone help identifying the problem and possible solution? Thank
you have to clean out the dryer and the vent line,unplug the dryer,remove the lint filter and then you need to remove and clean out the duct that the filter slides into,then vac out the cabinet where the motor is,go outside and check the vent,make sure it's clear,then remove the vent line from the back of the dryer,if it's a long vent line i use a leaf blower to blow out the line.also if you have a gas dryer,check it after 15 to 30 minutes to make sure the flame is still igniting,if the gas coils are bad they will fail when they heat up,when they heat up the flame doesn't lite until the coils cool down and your clothes will be warm but wet.you should clean the dryer once a year if it's gas and once every two years if it's electric,gas dryers have an open flame and the lint can catch fire easier than electric dryers,do this and your clothes will dry on time,no fires,save energy and money on your bill.good luck
Oct 10, 2010 | Maytag Dryers
Roper rgx5634kq2 gas dryer. Starts out lighting like it should. It runs for a minute or two then flame goes out, then after a minute it comes back on. It will do this cycle a few times and then it will...
it's not the thermal fuse,the dryer wouldn't run and the ignitor wouldn't glow.sounds like you have bad gas coils,if the dryer runs for the first 15 to 30 minutes normally and then no more flame the coils are failing,when they are bad they work until they heat up and then nothing,when they cool down they work again,common problem,also you should clean out the dryer once a year ,clean out the duct that the lint filter slides into,if your vent line is long take it off from the back of the dryer and blow it out with a leaf blower,make sure the outside vent is clear first,you can have a fire and then you can pop the thermal fuse,clean it and your clothes will dry on time,let me know what you find
Aug 25, 2010 | Dryers
Whirlpool condensed tumbler dryer
check ur dryer vent in the back u might have pushed it back too far and kinked the hose ar u might have a buildup of lint in the dryer vent pull the dryer out and take the dryer vent off and run a load of clothes like this if it works look for a lint buildup in the hose or u just had the hose kinked
Feb 26, 2010 | Whirlpool LER5636P Electric Dryer
Kenmore Electric Dryer 68731
If still heating, clean out vent and check for kinks. Also, REMOVE PLUG FIRST!! Remove back and remove four screw holding filter duct assembly at bottom left. Pull duct toward rear and reach into bottom of duct and remove lint. Also, wash out filter screen.
Nov 17, 2007 | Kenmore 659 Electric Dryer
Dryers Logo
35 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
