Question about Lexmark P4350 All-In-One InkJet Printer
Lexmark p4350 cuts off 2" of right side of document when trying to scan or copy
My Lexmark p4350 won't scan to my computer
I need more information. Have you replaced your cartridges with a non-Lexmark type? Did you try putting the USB cable in a different USB slot? Is the Lexmark power supply working? Did the printer get dropped? Did you try rebooting your system?
Jul 13, 2014 | Lexmark P4350 All-In-One InkJet Printer
Used to work fine, now after scanning a document, preview shows right 1/2 inch cut off. Tried everything...
you might confirued wrong paper setting on print preview of scan document or try to change the size of the paper to A4 or letter
Nov 12, 2013 | Lexmark International Lexmark 5200 series
One side of scan appears super bright to white , like the document is not touching the glass on that side . Why ?
  • Log on to the Lexmark website and update the driver. Also try and run diagnostics and see if that lists a fault.
Jan 19, 2018 | Lexmark P4350 All-In-One InkJet Printer
Lexmark p4350 copy has two horizontal lines on page- clean glass
It could be due to some dirt on the scanner glass. Try to wipe the glass with a lint-free cloth.
Then, try to scan again to verify that the problem is fixed.
Feb 21, 2012 | Lexmark P4350 All-In-One InkJet Printer
Lost CD - how do i download OCR software for Lexmark P4350
To scan documents for editing and saving as PDF files, you will need to install the Lexmark OCR scan software on your computer. The Lexmark scan software (no downloadable version) is only available in the installation disc that came with your printer. If you don't have the disc, please contact Lexmark Technical Support Center for assistance.
Sep 20, 2011 | Lexmark P4350 All-In-One InkJet Printer
I cant use the ocr function
Try to re-install the Lexmark OCR scan software using the installation disc that came with your printer to repair any possible corrupted files necessary for editing scanned documents.
Jun 21, 2011 | Lexmark P4350 All-In-One InkJet Printer
I don't have the CD to my Lexmark P4350 and don't
OCR programs are usually bundled with the driver disk and typically cost money. If the disk is lost, than chances are youll have to purchase an OCR program. One thing that you can try is to contact lexmark customer service and ask to send you a new copy of the disk. Be prepared to fax proof of purchase and pay shipping charges.
If you need further help, reach me via phone at https://www.6ya.com/expert/jarrad_11786570be7a2abd
Jun 09, 2009 | Lexmark P4350 All-In-One InkJet Printer
How can I scan without problems on a lexmark x3470 all in one
Hi..
To scan a document using the Lexmark Imaging Studio on ur Lexmark X3470, follow the steps given below:
1. Go to "Start," "All Programs," Lexmark X3400 series, "Lexmark Imaging Studio."
2. Click on "Scan," "Save edit or share."
3. Under "What are you scanning" choose the option as "photo," "several photo" or "documents."
4. Select the location to save as my pictures or other folder on your computer.
5. Click on "start" to scan.
To make a standalone copy:
1. Load the paper.
2. Select the "Copy quality" you want.
3. Open the top cover of the All-In-One.
4. Place the item you want to copy face down on the scanner glass. Make sure the upper left corner of the front of the item aligns with the arrow on the right of the All-In-One.
5. Close the top cover.
6. Change copy settings as needed.
Press "Black Copy" or "Color Copy."
hope this was helpful...
Apr 24, 2009 | Lexmark X3470 All-In-One InkJet Printer
Lexmark P4350 Series Photo Editor Not Workingq
Does this Printer have a keypad for scanning only, or also through a program on your PC? -ED
Feb 28, 2009 | Lexmark P4350 All-In-One InkJet Printer
Photos
Does this help? You obviously have to insert the media type into the media slot on the far right.(omoademola) Using the top control panel Printing tasks Scanning/Copying/Faxing tasks Troubleshooting
The top control panel lets you print an image from a photo card, scan a document or image, and copy a document or image with the press of a button.
Button/Light: Function: 1 Power : Turns the All-In-One on or off. 2 Copy: light Illuminates when Copy Mode is selected. 3 Mode: Changes the copy, scan, or photo card mode. 4 Scan: light Illuminates when Scan Mode is selected. 5 Photo Card: light Illuminates when Photo Card Mode is selected. 6 Rotate: Rotates the image 90 degrees. 7 LCD Panel: Number of Copies- this changes the copy count. Note: This feature is not active in Scan Mode. 8 Display: Shows copy, scan, and photo card selections. 9 Resize: Enlarges or reduces the size of the image. 10 Page Preview: Shows a preview of the output. 11 Select: Secures an option. 12 Menu: Provides options for image. 13 Arrow : Scrolls left, right, up, or down. 14 Stop/Clear: Cancels a print job or clears a selection. 15 Color Start: Initiates color copy, scan, or photo card output. 16 Black Start: Initiates black copy, scan, or photo card output.
Jan 10, 2008 | Lexmark P4350 All-In-One InkJet Printer
Lexmark P4350 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
