Question about Elna Heirloom Edition 6005
When I turn on my machine the needlehousing judders and stops at extreem left position and ERROR #1 comes up on screen
The temperature in the room the machine was at 28c and humidity was at 85%.
Switched aircon on and went out to dinner. Came back two/three hours later. Temperature was down to 23c and humidity to 30%.
Plugged machine back in and it worked straight off.
Seems the machine does not like high temp and high humidity.
Posted on Sep 05, 2009
Control Panel shows the following error message: ][ How can I re-set it?
] [ = usually means that your bobbin winder is on. Move the bobbin winder post/shaft from the right position over to the left to switch the mode back to sewing, then try making your stitch selection again.
Jan 12, 2016 | Singer 7256 Fashion Mate Sewing Machine
Reset button on Esante ESe2
1. Turn the power on while holding down the [Start/Stop], [Reverse stitch], and [Needle position] buttons.
2. Touch the positions marked with crosses (+) on the touch panel in order from 1 to 5.
NOTE
• Setting is successful if a single beep sounds when "5" is pressed.
• An error has occurred if two beeps sound when "5" is pressed. Repeat from position 1 again.
3. Turn the power off and then on again. Check that the screen display matches the positions on the touch panel
May 17, 2015 | Baby Lock Esante
How do i do a screen calibration on a PC-8500 sewing/embroidery machine?
C. POSITION OF TOUCH PANEL
STANDARD
The deviation of the liquid crystal display and touch panel should be within 1 mm when the touch
panel is pressed.
ADJUSTMENT
1. Turn on the power switch while holding down the start/stop button, backtack button, and
NP button simultaneously.
2. While holding down the start button, press the + positions 1, 2, 3, 4 and 5 on the screen in
order. If the buzzer sounds once when 5 is pressed, the position is okay. If the buzzer
sounds several times, the position is erroneous; therefore, adjust again. (When pressing
the screen, use a pencil (or match) with a round tip.)
3. Turn on the power again, and confirm that the screen display and touch panel positions
match.
Nov 18, 2014 | Brother PC-8500 Pacesetter Embroidery &...
Pc-8500 how to calibrate touch screen
ADJUSTMENT
match.
How do i do a screen clabration on a brother pc-8200 sewing machine? Thanks for the help
try this
While pressing the start/stop, reverse stitch and needle position buttons, turn on the power to display the screen
for the touch panel adjustment mode.
2. While pressing the start/stop button, touch the touch panel at the positions marked by crosses (+) in order from 1 to
5.
(When touching the touch panel, use an object with a rounded tip such as a pencil or matchstick. Never use a
hard or sharp-pointed object.)
If the buzzer sounds once when cross number 5 is touched, the adjustment has been made correctly.
If the buzzer sounds twice when cross number 5 is touched, an error has occurred. In this case, touch the
crosses on the touch panel again in order from 1 to 5.
Never press the thread cutter button during this time. (Doing so may cause a malfunction.)
3. Turn the power off, then on again and check that the screen display and the touch panel positions are aligned
Jun 30, 2010 | Brother PS-1250 Pacesetter
When using a usb design and very occasionally when using a built in design the screen switches off without warning and the machine either judders to a halt or just goes on madly stitching in the same place...
This is probably one of those dreaded instances of a problem that the technician cant reproduce. It sounds like a main board issue that is not consistent and therefore the tech doesnt know which direction to take. If you purchased the machine at a dealer store you normally have a 1 year free service period and the part should be a warranty item. Ask them for help in resolving the issue.
Jun 19, 2010 | Janome 200E Computerized Sewing Machine
Machine is telling me E6 error but there is no thread tangled
If your thread is not tangled .The E6 will come up also if the top thread is not threaded properly. Is your thread breaking at all ?
Dec 13, 2008 | Brother CS-6000
My touch screen doesn't always work. Sometimes I have to touch all around the square and even then, it won't come on. At times, it stops working when I want to change patterns. It seems to work most of the...
Yes, I have a solution for this problem. Your screen needs to be recalibrated and you can do it yourself. Don't you wish they would just tell you this stuff instead of charging you an arm and a leg? Here's what to do: Before turning on the machine, press the start/stop button, the reverse button, and the needle position button all at once with one hand (one finger on each button). Hold them down and turn on the machine. What will come up is a recalibration screen. You will see the numbers 1-5 with a little plus sign beside them. Find a small blunt object (I used the tip of a mechanical pencil with the lead in instead of out) and while holding the start/stop button, touch the plus sign beside 1-5 in numerical order. Then, turn the machine off and on again in the normal way. This should recalibrate the screen. Pass it along, people! This is something no one should have to pay for!
Nov 03, 2007 | Baby Lock Esante
Sewing Machines Logo
164 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
