Hello. The burners on top work, but the oven does not. Any ideas. I looked in the manual and it says to lift the top and re-light it. I can't get the top up though. Help!!
Hello. The burners on top work, but the oven does not. Any ideas. I looked in the manual and it says to lift the top and re-light it. I can't get the top up though. It is a GE XL44. Help!!Hello. The burners on top work, but the oven does not. Any ideas. I looked in the manual and it says to lift the top and re-light it. I can't get the top up though. It is a GE XL44. Help!!
You can't post conmments that contain an email address.
Just remove the medal things from on top of the stove itself and any other thing that might be in the heat area. Then you should be able to lift the top part of the stove up from the front where near the top, there should be a small gap. Start from that point and lift and it should come up. Then look for a pilot light as described in the manual and relight it and your stove should work.
Try and light oven manualy first if it does not light check to see if gas has been turned off to oven mistake Check if fitted timer is on manuel or pilot is blocked and needs cleaning
Step 1
Open the oven door. At the top, left-hand corner of the open oven, locate the model number tag.
Step 2
Check under the burners. Lift each burner on the stove off to see if the plate is underneath. Do this if the plate is not located on the inside of the oven.
The temperature sensor in the oven needs to be replaced. Here is the part to order. As far as the top element, lift the top up and look for lose or broken wires on the element. Keep me posted.
You may have a pilotless ignition.Check around door frames for model #plate. Also , open broiler door ,turn on oven and look inside . If you see an orange glow appear after awhile, that is the electronic igniter and you have an electronic ignition(no pilot).In this case the top burners use a spark ignition system.If you don,t hear clicking when you turn on a burner your ignition module might be bad. Easily fixed though.
is it electronic iginition? are you asking about top burner pilots? if so there are under the top in the middle beteen each side of the burners 1 pilot does burners on right and 1 on left. oven pilots are underneath you have to remove bottom door look in there at back and look up and you'll see it. if its a electronis ignition range you have no pilots!! glow coils and sparkers....
The lower burner in the top oven does not work, although the broiler does work. The broiler and lower burner in the bottom over both work. Could it be the burner element or would it be the relay board ?
If you have the glass cooktop slide-in model, the problem is most likely the burner "ribbon' under the glass top for the small burner has come loose. I fixed mine with only a phillips-head screwdriver, needle-nosed pliers, and a 1/4" wrench (1/4" socket on the end of a nutdriver works better). Here are the steps I took to fix it: 1) Slide the oven out from the counter so the sides of the oven are clear of the counter top. 2) Remove the phillips head screws-1 on each side of the oven near the top/rear. These will be the only phillips-head screws you will need to remove. 3) Open the oven door and remove the 4 hex-head screws at the top/front/inside the oven- there are 2 on each side which follow the opening of the door. Then close the door. 4) Pull off the burner knobs by gripping them and pulling straight up. Don't worry, you will not break them but you will need to give them a good tug. 5) Remove the burner retaining nuts that are under the knobs-you may need a wrench to loosen them but only tighten them by hand when reinstalling. 6) Pull the face of the control panel away from the oven slowly until you see a ribbon connector on the right side and then disconnect the ribbon and remove the face plate from the oven. 7) Remove the 4 hex-head screws from the face plate bracket (the plastic part that was holding the face plate) and pull the bracket toward the front of the oven until it flops over and rests on the oven door handle. 8) remove the 2 black screws holding down the glass top-one on each side of the oven-the screw heads face the front of the oven. 9) Disconnect the two wiring harnesses attached to the cook top. Don't worry, they only fit one way so you don't need to label them. 10) Lift the cook top until the wiring harnesses are clear of the holes and place it upside down on a flat surrface. 11) Remove the two retaining bracket screws and brackets from each side of the non-working burner. 12) Slowly lift the burner and flip it upwards until you see the ribbon coils. It should not be necessary to disconnect any wires. 13) Look at the ribbon coils very carefully to see if any of them are disconnected from their main connection points. If so, feed the ribbon back inside the pinch point (you may need a small screwdriver to open the pinch point first) and then use a pair of needle-nosed pliers to pinch the ribbon to hold it in place. I had to use a voltage meter set in the OHM position to find where mine were disconnected. Once you pinch the ribbon end back into place, put everything back together in reverse order. If your burner still does not work, your burner knob switch may be bad. I hope this helps. Good Luck!
Hello, open the oven door and stick your head as if into the oven...look up and you will see screws securing the top. Remove the screws and raise the stovetop. The burners are now visible. All that is required is to unscrew the support for the burner and pull the coil out of the socket. Installation is the reverse of removal.
Hello. It is a GE XL44.
