Question about Gigabyte Computers & Internet
Internal error have been trying to install my aircruiser router on my dell pc and am having trouble getting past the first setup screen Its asking for my ip adress, gateway adress and also dns1 and dns2 numbers. i have managed to imput all the numbers except the dns2 number. the dns1 number was there already. i click on finish and it says internal error??? someone help please, do i have to put in the last dns2 number or is it something else
  • megax01
    megax01 May 11, 2010
    what exactly are u trying to do? are u sharing an internet connection with the router? or just setting up a network?
  • 139 Answers
SOURCE: cannot connect second computer to my networn
I have listed several things here that you can use to find the problem. Sorry this is so long...network problems can be very tedious to find.
First check your version of Windows:
Double click on "My Computer", then click on "View System Information" to make sure you have at least Service Pack 1...or better yet....Service Pack 2.
Next check your Windows XP network settings:
Click on Start....Control Panel....Network Connections...Local Area Connection...Properties(button). Scroll down the list to find Internet Protocol(TCP/IP) and click on it to highlight it. Now click the properties button below the list. You should now be able to click the small buttons to select both of the "Obtain....automatically" choices for IP address and DNS server. Click on "OK" to close each of the windows.
Now you can test your computer to see if it is "talking" to the router: Click on Start...Run...and type "cmd" in the small box and click "OK". This will open a black command window where you tell the computer what to do. Type the command "ipconfig" and press return (enter). This will list your ip address, subnet mask, and default gateway. Make a note of the default gateway address so you can use it for the next test. If the IP address begins with 192.168...then your computer is probably communicating with the router okay. If your IP address is blank or starts with 169...then your network connection to the router may NOT be working.
The final test!!! Use the default gateway address from the last step to do a "ping" test. In the black command window...type "ping" followed by the default gateway address. For example: IF the default gateway happens to be 192.168.1.1....then type the ping command this way: ping 192.168.1.1
If the result is a list of replies from the gateway address...great!! Your network connection is working. If the ping command results in a list of "request timed out", or something else, then your network connection needs more help.
The ultimate test is to try using the Internet with your browser.
If this works, next try typing your gateway address into the brower address bar. It should connect you to the router setup page.(?)
Let me know the results of each of these tests, and I'll be happy to assist you further, if needed.
Posted on Jan 12, 2008
stif_NEC
  • 441 Answers
SOURCE: http://192.168.1.1 is not working anymore? i cant set up the router
Try resetting the router, press the reset button at the back for 10 seconds, after that release the reset button and then unplug the power of the router, then wait for 10 seconds and then turn it back on.
After that try accessing the IP of the router 192.168.1.1 (if this did not work try 192.168.0.1,this varies on the model number of the router). Or follow the same steps you have done previously.
Posted on Aug 16, 2008
  • 192 Answers
SOURCE: cannot access belkin 54g wireless modem settings
Try geting a routher that featres wirless and eathernet so you do not have to have two boxes. You will have to know its ip adress enter it internet explore and then you will be able to protect it through there.
Posted on Jan 04, 2009
  • 1214 Answers
SOURCE: Dir 655 will not install
You should not need to enter any of that information.
The router will find the internet on it's own, once the ethernet cable is connected and the router is turned on.
Press the reset button at the back of the modem for 20-30 seconds, this resets the router to square 1. Power down, wait 30 seconds, then power back up. You should have internet connection to the router, which can be tested by connecting another ethernet cable from the router to the ethernet connector on your computer.
Reply back what your objective is in getting to the routers setup page.
Posted on Feb 04, 2009
SOURCE: Trying to get internet radio on my wireless sound system.
Start your PC; press START - RUN and in the box, type CMD and then press enter. A Window will open. Type here IPCONFIG /ALL and then press enter. You will see then some numbers including DNS Servers and Default Gateway (usually they are one and the same if you are using a router) PROXY set to NO. Should work then. Failing this, navigate using your web browser to http://www.kitz.co.uk/isp/dns.htm where you will find a list of all DNS servers - scroll down to BT and choose some from that list.
Posted on May 16, 2009
Administrator password
You may have to contact Dell directly if its a hard drive or BIOS password.
I do know using a Windows 7 install disc will repair this error (if you can get past the password). Just insert and choose repair. gl
Jun 10, 2013 | Dell Inspiron 8500 Notebook
PC boots up then screen goes blank
You are asking for trouble by placing programs that Windows uses on the other drive. You are better off using the 1 TB drive as a system drive. Sounds like your OS is corrupted.
Feb 19, 2012 | Dell Dimension 8400 PC Desktop
When trying to reinstall windows xp, the process keeps failing during setup saying, "The file comct132.dll was not copied correctly. The file Setup on your hard drive is not a valid Windows XP system...
Click start/run Type: cmd
In the Command window type:
SFC /scannow Note the space between SFC and /scannow
You can copy/paste: SFC /scannow
Hit the Enter button
keep your xp cd handy in case you're asked to chuck it into your cd rom
The above should replace missing files and get you to the place where the install can proceed.
Let me know. __________________
If this doesnt work,yes hard drive needs to be replaced.internal hard drives are system specific.u need to contact dell tech support to get the right specifications
Sep 17, 2010 | Dell Dimension 4600 PC Desktop
Dell 4700 bios a06 2.8 ghz 64 bit bus=800mhz pentium 4 2.8 ghz microsoft xp pak 2 moterboard light= green abcd lights=green reset bios to factory settings computer keep shutting down.. windows dialog box...
You have a rootkit virus, the only answer is reformat the drive and start fresh, sorry.
After a fresh install is done immediately install service(can be downloaded free from microsoft.com) pack 3, because sp2 is vulnerable to a host of trouble.
Apr 17, 2010 | Dell Dimension 4700 PC Desktop
Belkin Setup Assistant will not run. The application opens, but I cannot get past the first screen that says "Run the Setup Assistant Now" and "Go to the main menu for all choices". When I click 'Go',...
Could be a Security or firewall in your PC ; or a previous registry that is corrupted with this same software that you have , better off getting a Registry cleaner first. CCleaner.com
Mar 15, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Unable to setup N Wireless Router in Apartment
Hi.
you do not have to run tye setup disk..
go to command prompt and do ipconfig
find the default gateway,launch internet explorer and in the address box type in the default gateway make sure the router is hardwired as sometimes it does not work on a wireless conection when you configure it.
If you get the router's console page it means that the router is getting detected(you can also ping the gateway on the command prompt to check the same)
on the console page you can fill all the settings and save them..the router will reboot and then you shold be able to use the router with proper internet and wireless settings.
http://www.ikarmatech.com
cheers.
Sep 11, 2009 | Belkin (F5D8231-4) Wireless Router...
Aquiring network address
Hey there,
in connecting wirelessly to the router, we need to make sure the encryption on the router.
Access the router setup screen, check the IP address first of the computer.
Open IE type there 192.168.1.1 username is blank and password is admin.
once it is on the setup screen checked the wireless tab and look for wireless security, verify it and try to connect again.
in your wireless computer, right click wireless connection and go to view available wireless network, try to connect - input the network key if in case it is not asking you for it, click the changed the order of the preferred networks and then removed all the preferred networks there, then try to connect again and you will now be asked for a network try to connect and you should be connected then.
Jun 24, 2009 | Linksys WRT160N Wireless Router
Inspiron 710m won't boot...goes right to black asks for password
go to youtube.com and search how to get past windows password screen for dell inspiron 710m. you will follow instructions from there. ok this is so you will learn how to do it all the time when you have trouble. i learn from searching and reading.
Jun 04, 2009 | Dell Inspiron 710m Notebook
BLACK SCREEN AFTER START UP IN XP PRO
Hi you may try follow:
1) go bios setup screen set default configuration and save it and test same error go next
2) take out wireless card and test same error go next
3) reinstall winxp at same HD test same error go next
4) change a HD and install winxp test
nothing solved above is motherboard hardware trouble, need to repair
Dec 21, 2008 | Dell Latitude C840 Notebook
Computers & Internet Logo
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
