Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
I have a HP Pavilion tx 1000. Blank screen, LED lights on.
I have a HP Pavilion tx 1000. If I leave the computer running and come back 15 minutes later, or anytime the computer goes to sleep, it shows a blank screen and I cannot click on anything or get it to wake up...but all the LED lights are on and the computer is whirring.
When I boot the computer up, it often takes 3-5 times before I can get it to go all the way to the Windows screen (each time it makes it to the blank screen where it does nothing, I have to hold the on/off button to get it to shut down, then try to start it again).
What can I do to correct this issue?
  • jessgree Sep 07, 2009
    however, it does not help with the boot error...as I have the same issue there...
  • 477 Answers
Hello, seems like your sleep mode doesent work as it should. Try to download all windows updates and look for a fix on microsoft sites.
But the best solution is to inactive the sleep mode setting and use the Hibernate options(if you want a fast start) but I suggest that you turn off windows with shutdown, its the safest and best way to have your computer to work properly.
To inactivate sleep mode.
windows xp
go control panel and power options
Change the system standby to never.
also choose power schemes battery, and change the system standby to never.
also the harddisk to never.
This should solve your problem.
To activate Hibernate you need to click on hibernate tab and bock the square.
hibernate= saves all your work to harddrive to restart your computer where you left off.
sleep mode= saves your work to RAM memory=takes a little bit energy.
Posted on Sep 04, 2009
Testimonial: "already, my computer is not freezing:) thanks for the tip."
  • 40 Answers
Avert it to go on sleep mode, I think that's the best way to resolve this. Windows often has difficulty to manage sleep mode on laptop. If your running on Windows XP : Go to Control Panel - Display - Screen Saver tab and Power... ajust the delay to the appropriate amount of time for each item. I usualy put Never when the PC is not feed by the battery.
    Problem Solver:
  • 15 Answers
Have a TX1000 with same problem.
found this on youtube http://www.youtube.com/watch?v=rFlx3frXNy8
and tested it just for fun.
Guess what....it realy worked...my TX 1000 are back :-)
Posted on May 20, 2012
    Novelist:
  • 136 Answers
For the "sleep" issue, do this:
Start Button ----> Settings ----> Control Panel ----> Power Options ----> First tab is "Power Schemes"... either change the scheme (they are pre-set for both running on A/C and Battery, or change manually). Click Apply and OK.
For the re-boot issue, try clearing out your cache of old temp files, temp internet, etc (use CCleaner, found at http://download.cnet.com/ccleaner/?tag=mncol . Also use the Registry feature to clear old registry values that are no longer used (click "scan for Issues" and then "Fix Selected Issues". You will be asked if you want to backup your registry, be SURE and do this!
Hope this helps!
-- RT
    Problem Solver:
  • 19 Answers
Try this program. they have a free 30 day trial.
http://www.tune-up.com/products/tuneup-utilities/
do the one click fix under the "Clean up Windows" Tab.
This will take a long time the first time you do it but it should help you out.
My best guess would be registry issues in tandem with a bad boot sector for windows.
If it dosn't work,
Reply to me at Dhuhwhat@hotmail.com Title it Fixya. I had this same problem on a HP i had 3 or 4 years ago
Pavilion dv3 power on and off continous and screen blank
Computer Keeps Rebooting - cannot access Safe Mode
1. Boot up with Windows installation CD 2. It will give you the option to use RECOVERY CONSOLE 3. Type chkdsk to check disk - this fixes bad blocks and moves data to another area. 4. When completed, remove Windows installation CD and reboot computer
Mar 01, 2013 | HP Pavilion Dv3-1075us Notebook
I have no display on my HP tx 1000
this is a common failure for those who have this tablet pc. this fail is because gpu overheating so you can't get display on your screen only black blank screen with all light indicator on.
I have the same problem and I can fix by myself with little cost. all you need is aluminum foil and oven to bake your motherboard.
1. first you have to dissemble your notebook
2. take your motherboard out.
3. take everything that stick on your motherboard i.e sticker, cables, battery, rubber (everything .. that easy to melt)
5. place aluminum on your oven surface. place your motherboard and bake it about 200 degree celcius for a 7-10 minutes.
ok I found better tutorial for how to bake your motherboard.
http://www.associatedcontent.com/article/5790852/how_to_reflow_your_laptop_motherboard.html
Oct 04, 2010 | HP Pavilion tx1000z Notebook
My HP Pavilion M90 monitor won't turn on. Every time I press the on button I hear a clicking sound from the back of the monitor. It sounds like it's trying to power up but it doesn't do anything. Is there...
Hello
Do a hard reset on the laptop by removing all cords and connections from the computer, including the power cord. Turn the computer over and slide the tab next to the battery, then lift the battery out of its compartment.
Eject any SD cards currently inserted in the SD card slot by pressing on them, then remove them from the slot completely. Hold the computer's "Power" button down for at least 15 seconds, then plug the power cord into the computer and turn it on.
Watch to see if the LED lights near the "Caps Lock" and "Num Lock" illuminate. If the lights do not turn on and the computer's screen remains blank, inspect the power cord and AC adapter for damage and replace them if necessary.
Leave the power cord plugged into the computer and snap the battery back into its slot. Allow the computer to sit for at least 30 minutes, then unplug the power cord and press the "Power" button again to see if the computer will turn on.
Plug the power cord back into the computer and try to turn it on again. If the computer turns on, replace the battery with a new one. If the computer still does not turn on, take the computer to a repair shop.
Oct 04, 2010 | HP Pavilion M90 Monitor
My hp pavilion dv9700 screen stays blank when opening it up. The led lights are on and the computer is running but the screen does not come back on. If I wiggle the screen at the left hinge when the screen...
most likely you have a loose connection between your motherboard and lcd screen or the video card is dying you can test it by puting another monitor on your laptop if it works fine then it the connection. if the problem still exist its the video card
Jan 06, 2010 | HP Pavilion dv9700t Notebook PC
Hp tx 1000 black screen please hel
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Nov 28, 2009 | HP Pavilion Tablet Notebook
HP Pavilion laptop screen has gone black/blank
No it suggests you have a bad screen and it needs replaced
Jun 22, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
I have a HP Pavillion TX 1000. Did everyone heard
It is highly improbable that heat from the CPU can crack a LCD screen. Even if the fan was faulty the CPU would have shutdown (thermal overload) before it would affect the LCD screen. If you apply pressure to the face of the LCD screen or twist the screen or impact the screen with a hard object, any of these will cause the LCD screen to crack.
Jun 11, 2009 | HP Pavilion tx1000z Notebook
Hp dv5 laptop screen randomly goes blank.
Check your power management settings. Reset to suit your usage. This should fix it.
Mar 16, 2009 | HP Pavilion dv5000t Notebook
Pavilion dv 1000 won't reboot, stand by nor turn off
I had this kinda problem solved on a Acer 5920 LAptop. The webcam driver was the culprit. Remove the cam driver for the same, the windows driver will take over and then i guess it will work fine. I figure its a driver issue or a TSR program not quitting. If this fails try uninstalling recently addes program or driver.
Jan 05, 2009 | HP Pavilion dv1000 Notebook
Hp pavilion dv6000 screen goes blank 5 minutes after startup
i cannot install win xp on my hp pavalion it is already contain win vista and hard disc is SATA type give me a solution
Sep 08, 2008 | HP Pavilion dv4000 Notebook
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
1,636 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
