Question about HP Photosmart C5180 All-In-One InkJet Printer
Letters have shadows
Black is not fully black and letters have shadows
HP C4280 printer always prints with a shadowed letters, especially with the black ink. i think it started when i was installing a new cartridge and i didn't insert it at the correct angle, so i may have...
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Nov 08, 2010 | HP Photosmart C4280 Aio Printer
2002 Honda SHADOW SABRE It wont stay running unless it's
More information is needed - aftermarket pipes? any carb work been done to it? is fuel fresh? air filter condition? how are the plugs burning? oily black, white/tan?
Jul 10, 2010 | 2002 Honda VT 1100 C2 Shadow Sabre
I have a yellow shadow line around my black letters. Is there an alignment that an in house tech can adjust?
normally there is a description in the user's manual for the alignment (convergence) of this machine.
Mar 08, 2010 | NEC VT470 Multimedia Projector
Letters blurr in spots and black boxes leave a shadow on the screen
[u][b]LCD Monitor Shadow Effect[/b][/u]
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
[u][b]Solution: [/b][/u]Keep the two cables - (power cable and moitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
Nov 23, 2009 | Acer P221W LCD Monitor
My hp officejet v40xi printer is printing my black and white documents with a shadow behind its lettering. I've ran the align process several times. The funny thing is that when it prints the instructions...
check your printer settings on the device you are using and make sure you have shaddow off or 3d off. the extras only work from the device you use, printer page from printer is basic settings.
Jul 07, 2017 | HP OfficeJet V40 All-In-One InkJet Printer
Shadows
Thank you.
Feb 07, 2009 | Acer X193W LCD Monitor
Blue shadows on my philips projection tv
You have possibly contaminated fluid in your blue picture tube if it has a hazy look.Blacks and whites look bluish and whites have a blue bloom to them.The other problem could be bad convergence amps.This would be double image around letters on the screen.
Jan 13, 2009 | Philips Magnavox 51MP392H Rear Projection...
Picture off and shadow of back images.
Hi Grim159
I've had this once on a Epson Projector and the only way I could this right was by replacing the Mainboard.
Hope this is of help.
Apr 22, 2008 | Philips ProScreen 4600 Impact Multimedia...
HP Photosmart C5180 All-In-One InkJet Printer Logo
75 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
