Question about Insignia IS-LCDTV32 32 in. Television
Hello my insignia flat's lighter colors are turnig into pink pixels. any help?
    President:
  • 1,447 Answers
Please change input VGA cable
i hope solve your problem
Posted on Sep 04, 2009
Hello, I have an Insignia 46" lcd TV. Model # NS-46E481A13. I get green pixelation on the dark colors and it is constant. Bright colors work fine though.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Aug 19, 2015 | Insignia Televison & Video
Hello, I have an Insignia 46" lcd TV. Model NS-46E481A13. im having the issue of green pixelation. Bright colors are fine on my tv. It is only the dark colors that get this green pixelation.
Fault to its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Insignia 42 lcd hdtv purple pink screen
If DVD input works likely a issue with the signal.
If using a cable or sat box or even a receiver inline--unplug each and after several minutes plug back up to allow each unit to try to reboot.
If using component connections from box or receiver they may be the issue or not. In that case if a box is feeding signal via component or even HDMI the box (if reboot does not fix this) may be bad.
Another simple test if cable is used with a box is disconnect cable going to the box and connect directly to set--that way you will know if box is or is not the problem.
May 22, 2012 | Insignia 42" LCD Flat-Panel HDTV
Color and picture is distorted. Colors are predominately bright green, yellow and pink. Sometimes color will clear but picture is still fuzzy.
Hi
Thanks for using FixYa.
Please post a comment with the manufacturers name and model no# of the unit so that I can assist you further.
Thanks
Rylee
Sep 21, 2010 | Insignia Televison & Video
The color on my tv is mostly pink. Is this
Try a reset to factory defaults. Show some image with lots of white. If it is still pink, it could be the backlights starting to fail. Or a circuit board. To be sure, you would have to disconnect the LCD panel from the board and turn on the set so that you have a blank white screen....with no signal. A pink screen, backlights are bad.
Apr 23, 2010 | Insignia IS-LCDTV32 32 in. Television
There are horizontal color bands (red, yellow and purple) scrolling from the bottom to the top of my 32" insignia flat creen TV. i've owned the set for a year and it has been perfect up till now. anyguess...
sounds like you have some lines of dead pixels, is this an LCD screan or a plasma screen? if it's LCD then it is dead or stuck pixels, check your owners manual and there should be a section on stuck pixels if its and LCD tv.
May 11, 2009 | Insignia IS-LCDTV32 32 in. Television
32 inch insignia plasma tv
Check all the cable connections while the TV is on, both at the TV, and what the cable is connected to.
I suspect the problem is in the TV, and you'll have to wait for the Geek Squad.
I doubt leaving the TV on caused this, and good thing it happened when it did.
Jan 27, 2009 | Insignia 37" LCD Flat-Panel HDTV
GREEN SPOTS IN PICTURE
Are they spaced evenly?
If so, an IC responsible for control of the individual pixels has failed.
If not - well, I can't think of anything that would cause a random appearance of any color.
Aug 27, 2008 | Insignia IS-LCDTV32 32 in. Television
Pink highlights on LCD screen
IT SOUNDS LIKE THE MAIN BOARD IS BAD. THERE IS 2 DIFFERENT VERSIONS FOR THIS SET .AM02 UNITS OR VERSION 0001 UNITS. THE PART NUMBER IS BN94-00695E. THEY BOTH ARE ABOUT $210 + $50 CORE.
DON..
Jun 02, 2008 | Televison & Video
LCD Monitor Half Screen Pink
sounds like a color balance issue. Check the menu, do a degauss...and then check for the color temperature (reset for default)..
Got backup?
Feb 10, 2008 | Proview PL 566s 15" Flat Panel LCD Monitor
Insignia IS-LCDTV32 32 in. Television Logo
65 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
