Question about Cameras
My Canon G9 requires that I input the date/time every time I turn it on. I think the internal lithium battery is dead, but the manual does not cover it replacement.
  • fen_nel Sep 04, 2009
    I agree with your solution, but I cannot find the lithium battery. The manual does not address the problem except to say that the built-in lithium battery should be recharged. I have followed the directions for doing this, but it is obvious that the battery is dead. The problem is how to find it to replace it.
  • fen_nel Sep 05, 2009
    This problem started about two weeks ago when I was one week into a two week vacation. Since I used the camera every day, I would install a newly charged battery while I recharged my second battery. This was usually done each evening after I edited the pictures I took that day. This usually ran the battery down so I would install a newly charged battery in the camera for the next day and recharge the rundown battery so that I would have a back-up the next day. This procedure put a battery charged 24 hours earlier into the camera each night. It would remain off for the evening, usually at least 8 hours.
    Since 24 hours might be too long to keep a full charge, I charged one of my batteries this morning and installed it in my camera immediately when the green light came on. I then waited four hours and turned the camera on. It asked for the date/time which I entered and then turned the camera off. The camera again asked from the date/time when I turned it on again. Obviously the internal battery is not being charged. I think that replacing it might solve the problem, but I do not know how to do this.
Hi there
The button cell lithium battery will require replacement. You should be able to locate it under a flap. It may be behind the main battery, so remove that first. Once you remove the button cell battery, note its number and buy the replacement.
This will resolve the problem with the date and time loss.
Please do not rate this reply unless I have answered your question or your reply will not be returned to me. Thanks.
Posted on Sep 04, 2009
  • Anonymous Sep 04, 2009
    Thank you for your reply.
    The main battery should be OK. I have done some further research on this issue and you are right, the button cell battery inside is a rechargable one. It should recharge itself if the main battery is fully charged. Charging of the internal battery should take up to four hours.
    Please try inserting a fully charged main battery and leave the camera turned off for 4 hours. The internal cell will charge automatically even with the power off. If it does not recharge after four hours and still loses the time, please let me know.
    Thanks
Every time I turn on camera it ask to set date,
The Time/Date battery is a small round lithium battery the size of a dime in the battery compartment. You can get the numbers off it and buy one at Walmart or Ebay.
Instructions for replacing it:
http://www.manualslib.com/manual/275745/Canon-Powershot-Sx10-Is.html?page=267
Jun 06, 2014 | Canon PowerShot SX10 IS Digital Camera
I have to reset date time etc everytime i turn camera on
If the Date/Time menu appears when the camera power is turned on, the date battery charge is low and the date and time settings have been lost. Please purchase a lithium coin battery (CR1220) and replace it as follows.
1. Confirm that the camera power is turned off.
2. Slide the memory card slot / battery cover lock and open the cover.
3. Hook your nail onto the date battery holder and lightly pull up.
4. Remove the battery holder in the direction indicated by the arrow. a570isbackupbatremove.gif 5. Remove the battery by pulling it up in the direction indicated by the arrow.
a570isbackupbat.gif 6. Insert a new battery with the (-) side facing up.
7. Replace the battery holder and close the memory card slot / battery cover.
8. When the Date/Time menu appears set the date and time.
Feb 05, 2011 | Canon PowerShot A590 IS Digital Camera
Doesn't remember time and date
Keith, it sounds like the camera internal battery for the memory is dead. Normally they will last several years, however I have seen them go bad in one to two years. These batteries are not easily replaced on the Kodak models and requires disassembling the camera and soldering in a new battery. My recommendation would be to keep good lithium or rechargeable batteries in the camera, removing them only when they need replacing, or if the camera is going to sit unused for more than a couple months.
Apr 21, 2010 | Kodak EasyShare C613 Digital Camera
Will not turn on, and battery is good
Lots of people go through this on the G9. Certain screws inside often come loose inside and short out the camera leaving it with no power. A great place to service these is: www.camerasandparts.com All they work on are the Canon Powershots and they do excellent work. It's $89 through them for the parts / labor to fix this, and they service up the camera at the same time when it's being repaired, plus they cover the shipping going back. On the G9's, they also do some correction inside the camera so that the screws don't come loose again inside and cause this problem. If you need to have it fixed, they're the place for this G9 problem.
Jan 07, 2010 | Canon PowerShot G9 Digital Camera
How do I set up a Canon G9 to display date and time on image.
Press the "play" button to view your photos. Then, press the "display" button until the time/date show up.
If you want them to print out the time and date on the photos, you do this in the "Print Settings" menu. Just press the "menu" button, and then go to the second tab that looks like a printer, then scroll all the way down to "Print Settings..." Press the "Func/Set" button, and then scroll down to where it says "Date: On/Off". Use the directional buttons to select "On" or "Off" and then press teh "Menu" button again.
Mar 12, 2009 | Canon PowerShot G9 Digital Camera
Minolta Maxxum 7D Lithium Battery Replacement
You need an NP-400 Li-ion lithium battery - I suspect ebay or Amazon can fix you right up.
Jun 13, 2008 | Konica Minolta Maxxum 7D / Dynax 7D...
Canon A450 internal battery problem?
There are cameras with 'fixed' internal batteries to maintain date/time they are long lived and not usually replaceable.
If this is such a model and it is new then a replacement should be forth coming from the vendor or Canon.
The vendor is the first stop then Canon support
Dec 07, 2007 | Canon PowerShot A450 Digital Camera
Whenever i turn on my camera i have to enter the date and time again. This sucks. Help Me! I think that covers it.........
Most (all?) digital cameras have an internal battery that resembles a watch battery. This battery is responsible for maintaining the system settings i.e. date and time. Your's is likely dead. Some of these batteries can be accessed without cracking open the body others can't. Check out your manual to see if you can get to it and replace it - that should fix your problem.
Sep 18, 2006 | Sony Cyber-shot DSC-W50 Digital Camera
Cameras Logo
134 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
