Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
John deere 850 compact
I have replaced the starter,replaced battery,fuses, etc - engine will not turn over, and yes the trans is in neutral and the clutch is in.All of the lights, etc work, so power is there.
It's full of oil and fuel
The tractor will readily crank when you pull it with a chain. Is there a safety switch on the trans somewhere or something that is stopping it from cranking?
  • 279 Answers
There is a switch under the seat. Just to test and not to run, you can take a jumper cable and go around the switch. If you find this works, go get a new swtich. It is very important for safety...Good luck...Lee
Posted on Sep 04, 2009
John Deere Z225 starting problem. The solonoid only clicks when I turn the key.I replaced the battery, the starter, the ignition switch and the starter solonoid!
With everything you have done only 2 things come to mind.
1) Safety switch open or not functioning.
2) Engine seized.
May 03, 2017 | John Deere Garden
Clutch doesn't engage on my 850 jd
Here's the link and I'm sure you will get the solution of your problem.
JOHN DEERE 850 COMPACT UTILITY TRACTOR SERVICE REPAIR MANUAL DOWNLOAD
Apr 29, 2017 | John Deere Garden
Tractor won't start new battery John Deere 4400 does not even turn over
The tractor has a neutral safety switch ,be sure you are in neutral or park , be sure pto is disengaged has a safety switch on pto . Has a operator present switch under seat cushion that is activated when setting in the seat. All these work together to complete circuit to engage starter. Check it out
Jan 10, 2017 | John Deere Garden
Where is the fusible link in a John Deere LX 255 lawnmower?
First thing to check is make sure you blade switch is in off position, brake/clutch is down and locked. There is a 20amp fuse in a fuse holder by the battery in engine compartment. Is it not turning over or not starting?
May 08, 2015 | John Deere Garden
John deere 5075E TRACTOR WON'T START BUT BATTERY GOOD AND MAKES ACLINKING NOISE FUSES ARE GOOD TOO
I Am Guessing Clicking Is Starter Drive. Can Be Several Causes. Not Enough Amps From Battery--Dirty Connections--Power And Or Ground--Loose And Or Defective Starter--Seized Engine.
Feb 27, 2015 | John Deere Garden
John deere 250 skid loader - purchased new in late 2001. every time i turn the switch to start the engine, it blows the fuse.
Apparently you have a short in the starting circuit. I would try disconnecting the start wire from the solenoid, and see if it still blows fuse. If it does it's in the control circuit. If not it's the starter solenoid.
There should be an operator present switch under the seat, that sometimes short out from an accumulation of dirt and debris that get moist.There is also a neutral safety switch and/or relays.
Oct 17, 2010 | John Deere 4020 Gas & Diesel Tractor...
A,b,g Tractor Carburetor Float Dltx10: i had my john deere riding mower running then shut...
My John Deere only starts with a hammer. I have the Kawasaki engine and it is famous for bad starters, so I carry a hammer and tap on the bolt when I want to start it. So, you either have a bad solenoid in your starter, or the contacts are dirty, battery connections are dirty. Or the battery is dieing. Check it out. Hope this helps.
May 07, 2010 | John Deere A,b,g Tractor Carburetor Float...
1989 JD 2155 2WD tractor, cannot start engine, have replaced starter switch, nothing happens, battery good. What should I check next?
Have you tried crossing the large post of the starter with the small terminal that has the engagement wire going to it[with the machine in neutral and the range lever in neutral if course].If this will make the tractor turn over then the problem is likely the neutral safety switch located under the panel that is covering the transmission just rear of the sticks.
Jan 03, 2010 | John Deere 420,1020,2010,2020,2510,2520...
1987 john deere 750 compact tractor 4 wheel drive, wont start
percussive maintenance my friend. Try banging on the solenoid and starter with a hammer while in the start position. Also, if you have a voltmeter, you can see where voltage is getting to and that will help you as well.
Jun 09, 2009 | Diesel Garden
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
521 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
