Question about Whirlpool Dryers
Dryer will not start but has power at plug - Whirlpool Dryers
  • 304 Answers
The problem you describe is usually caused by a thermal fuse intended to shut the dryer down and keep it off because of a problem with air flow.
The following process will allow you to test the thermal fuse and replace it if you find it open.
Unplug unit and turn off gas if gas model. Check to be sure you have 240 Volts at wall outlet.
Most parts likely to fail on electric dryers are inside the rear cover. Heater is on right inside can, safety thermostat on lower left of can, High limit thermostat (non-resettable) higher left of can. On the blower housing to the left are the operating thermostat and, in some models, a thermal fuse (white plastic). ALL can be continuity checked easily. Always disconnect wire on one side of what you are testing. One will likely be open. Replace the component that fails the continuity test.
The thermal fuse or high limit thermostat failure generally points to a reduction of air flow due to SOME blockage either inside the dryer or in the vent pipe leading out of the house. If you find either of these parts bad be sure to check the vents after replacing parts to ensure the same parts won't fail again.
Posted on Sep 04, 2009
Roper dryer #RES7648JQ0 will not start
Your dryer very likely wont start due to a bad Thermal Fuse. This video I have attached shows how to replace the thermal fuse. I know the video says Whirlpool dryer, Whirlpool is the maker of the Roper brand and it should be exactly as shown in the video. The video shows using a jumper wire to bypass the thermal fuse if you have such a jumper wire it is effective to check if the fuse is the problem,if not just temporarily connect the 2 blue wires together and test if the dryer starts. BE ABSOLUTLY SURE BEFORE EITHER USINGA JUMPER WIRE OF CONNECTING THE BLUE WIRES TOGETHER ***DISCONNECT THE POWER TO THE DRYER*** USE JUMPER,OR CONNECT WIRING THEN RECONNECT POWER TO DRYER so it may be tested to see if the dryer starts.
http://www.youtube.com/watch?v=Qi9wEXNCnJk
I base my diagnosis on my 30 plus years as a appliance service technician.
Thanks,Gene
Oct 01, 2013 | Roper Dryers
Dryer not powering/turning on
Investigate these areas if your dryer is not starting: Proper Voltage from the House Your dryer may not be receiving adequate voltage to start. Make sure your dryer is plugged in. Also, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Or check to make sure no fuses in the fuse panel are blown. Try plugging something else into the same outlet. If it won't work either, then there is likely something wrong with the power outlet. Any of these could be the reason power is not getting to your dryer. Also, refrain from using an extension cord to plug your dryer in. Door Switch If your dryer's door switch is defective, it will not allow your dryer to start. Test your dryer's door switch. If it is defective, replace it. Start Switch A dryer cannot start if its start switch is defective. Test your dryer's start switch. If it is defective, you will have to replace it for your dryer to start again. Thermal Fuse A thermal fuse is a heat-sensitive fuse attached to your dryer's exhaust duct (in most models) that is designed to blow if the dryer overheats. A blown fuse would cause your dryer to not heat, or to not work at all. Open up your dryer's cabinet and locate its thermal fuse. Test the component. If it has blown, replace it. Thermostat A defective dryer thermostat could be what is preventing your dryer from starting. Open up your dryer's cabinet. Test each of your dryer's thermostats. Replace any that have become defective. Timer Motor Your dryer's timer will not function properly if its motor is malfunctioning. Open up your dryer's cabinet and locate its motor. Test the component. If it is not functioning as it should, replace either the motor itself, or the entire timer assembly. Motor A burned out motor could be what is keeping your dryer from starting. Test your dryer's motor and if it is defective, replace it. You will have to open your dryer in order to gain access to its motor. For more info see the following link: http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Aug 05, 2012 | LG DLG2532 Gas Dryer
No power
check the thermal fuse in the back of the machine,, remove the back you'll see it
Jun 05, 2011 | Dryers
My dryer dont star no power at all
PLUG A LAMP INTO A PLUG MAKE SURE YOU HAVE POWER,THEN TRY DRYER SWITCH STILL NO POWER TAKE DRYER SWITCH APART AND BYPASS BY CONNECTING TWO WIRES. STILL NO POWER BYPASS DOOR SWITCH. STILL NO POWER CHECK TIMER THEN START CAPICITAR ON MOTOR, IF MOTOR IS HUMMING REPLACE IT. GOOD LUCK
Sep 28, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Dryer does not start. Power is verified at timer,
Cheak your safty thermostat at rear of dryer it is located on the blower housing 2 small blue wires go to it.Remove the wires and bypass thermostat.VERY CARFULL MAKE SURE POWER IF OFF FIRST.After bypass plug in and see if it starts.
Mar 13, 2010 | Whirlpool LEB6200 Electric Dryer
Dryer wont start
Hello. i can help you. begin by checking the power.
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
If that doesnt get it working again get back as there are other things that could have gone wrong.
Jun 04, 2009 | Dryers
PF singal on dryer. Can not start dryer something electrical possibe pf power failer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
Jun 03, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer wont start
your dryer may not be recieving adequate voltage to start.
make sure your dryer is plugged in.
also check the circuit breaker panel to make sure all circuit breakers are in the right position.
check fuse box for blown fuse.
try plugging in something else in the same outlet.
also refrain from using an extension cord.
Mar 04, 2009 | Whirlpool GEW9200L Electric Dryer
Nov 13, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
42 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
