Since you have neglected to tell us the make and model of the tripod, this can only be a generalisation - broken down into easy steps for you.
1) unclip the Q/R plate from the tripod head.
2) screw the Q/R plate to the base of the camera, using the tripod threaded socket.
3)re-attach the Q/R plate to the tripod head.
BTW, when using the camera on a tripod, use a remote control to prevent camera movement.
SOURCE: Nikon Coolpix 2100/3100/3200 battery compartment door latch broken (again)
I just purchased a new battery door for $15 with shipping from nikon. They sent a simple assembly diagram and I was able to replace the door in 30 minutes. I used a dremel to cut the old door off, but you dont have to do that. I got a little impatient.
Just buy the plastic piece and u can reuse the metal parts for your old battery door.
SOURCE: Vivatar Tripod V3000 Camera Attachment Adapter for Nikon D80
Try www.tripodquickrelease.com They have that exact model listed and the plate sells for $16.99
SOURCE: I attach Nikon CoolPix S550
Some Macintosh computer systems support using a digital camera using SD/MMC card in two modes: 'Digital Camera' mode and 'Disk Drive' mode. At times, when try to use the camera using SD/MMC card in 'Digital Camera', it is not recognized by iPhoto or Image Capture. To solve such behavior, you might need to reformat the digital SD/MMC card and use backup to restore the lost files. But sometimes, you observe certain issues while restoring from backup or the backup is not available. To cope up with such situations, you should use Photo Recovery application to recover the lost files efficiently.
For an instance, consider that you perform following sequence of steps:
Similar behavior is also observed if you use FireWire or USB card reader to connect the SD/MMC card to your Macintosh computer and try to switch to 'Digital Camera' mode.
Solution
To prevent such errors from occurring, you should continue using the camera in 'Disk Drive' mode. You can then successfully access it through iPhoto or Image Capture. However, to solve the existing problem of the SD/MMC card, follow these steps:
Note: A digital camera using SD/MMC card uses different protocols in different modes so that to communicate with the Macintosh system. But it can only be accessed through Desktop, when connected in 'Disk Drive' mode.
After reformatting the SD/MMC card, sometimes you observe that backup is not valid and couldn't provide the required results. In such situations, you are suggested to use Digital Photo Recovery products to recover them. Photo Recovery utilities are competent tools to scan a logically crashed media using powerful scanning algorithms. Also, they provide interactive user interface that allows easy implementation
