Question about IBM ThinkPad T30 2366 Notebook
My IBM Thinkpad with windows xp when turned on has many colors streaming on the screen. It will not load and what worries me is losing music, video & picture files. What can be done to retrieve the data? I have a new computer but cannot access the files on the thinkpad.
  • 700 Answers
Might be video card problem or something that is connected with your video is getting fault, dirty or loose contact is a big candidate. If you can test it using external monitor if it have external monitor port try that first. If external monitor works then back up your files immediately using external media. CD, dvd, flash drive or in another external hard drive.
Second option is to take out the hard drive and hook it into a USB hard drive adapter or a USB enclosure. And retrieve your files if you want on another working computer.
Then the laptop should go to a repair. If you are not so sure of doing this, have your friends that have knowledge on this assist you or bring it to a reputable shop.
Just for an input.
Posted on Sep 04, 2009
My ibm thinkpad t23 will not go pass blue windowxp screen need help
There are many possible reasons for a blue screen at windows xp.the most likely ones are:damaged windows instalation - in which case you will need to reinstall windows.damaged physical drive - in which case you would need to get a new hard drivethe OS cannot access memory - could be RAM memory or HDD.
I'm guessing you would just need to re-install the windows. You are most likely to lose all data.
Feb 18, 2012 | IBM ThinkPad T23 Notebook
Thinkpad screen colors Inverted/Distorted in 256 color mode
not a epert just trying to help,, i dont know what windows you are using xp or higher will not work good with that low of color,, hope this help you
Feb 25, 2010 | IBM ThinkPad T43 Notebook
Can IBM 380XD ThinkPad Laptop,loaded with WINDOWS XP
Yes, your laptop support Windows XP, so there should not be any problem in installing Windows Xp softwares.
Jan 01, 2010 | IBM ThinkPad T30 2366 Notebook
IBM Thinkpad has many colors and will not load
You may have a loose video connection ot faulty video card.
Connect an external monitor to the video port of the laptop, power up the monitor first then the laptop, the video data will automatically to the external monitor if the video card is OK. If it works, then backup your music, photos and video etc.
Then power down and reseat the video cable/connector.
If the you do not get a video image on the monitor then the video card or the video RAM is faulty. The video RAM uses part of the main RAM module, reseat the RAM module/s, if this doesn't work get it tested at your friendly computer shop. If the RAM tests OK then the video card is faulty and is part of the motherboard, it cannot be fixed and a replacement motherboard may not be a cost effective solution.
In this case, remove the hard disk and put it into an USB hard disk adapter case and connect it to a working computer's USB port and you will be able to copy/backup your files to CD/DVD disks. You can also use this as an external USB hard drive for backups and file transfer, don't forget to remove the Windows folders from this drive as it is no longer needed and it will free up disk space.
Sep 04, 2009 | IBM ThinkPad R50e Notebook
IBM A31 2652 Video garbled video at boot
This is very possibly a hardware problem, namely a crack in the motherboard. Sorry, no easy or cheap fix for it if that's the case.
Feb 18, 2009 | IBM ThinkPad T42 Notebook
Thinkpad t20 problem stuk in 16 bit colors
You need a video card driver, but didn't specify which video card you have. Looks like this -might- be the right one:
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-4JRNJB
Jan 19, 2009 | IBM ThinkPad T20 2647 Notebook
How can i load awindows xp on ibm 600e
I have done this many times.
To install XP on an IBM 600E , you needd to upgrade the RAM at least to 256MB.
Then use a Windows install disk to install XP.
After installing Windows you will have to update drivers from IBM website here: Lenovo Support & downloads - Drivers and software - ThinkPad 600 ...
There is no driver for 600E video adapter on XP, video performances will be limited.
Oct 12, 2008 | IBM (05K3469) Modem
Booting problem
apparently the boot setup screw up.
my best suggestion is to restore windows after you found a way to save all your files....
Apr 12, 2008 | IBM ThinkPad i Series 1412i Notebook
IBM ThinkPad T30 2366 Notebook Logo
67 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
