Question about RTO Fuel Pump Carburetor Transmission Tester Gauge Tool
My gauge is not reading the gas inside the fuel tank
  • 60 Answers
It sounds like a bad sending unit. i would try replacing that
Posted on Oct 18, 2009
When truck is in motion going down the road gauge is all over from empty to full when stoped it reads properly
Your gas tank has a float inside that is kart if tne. Fuel. Pump assembly that indicates the amount of fuel in the tank..it sends a message to the gauge...sounds like the float is sticking when the gas is sloshing around when moving..causing a false read being sent to the gauge. Most times the tank has to be removed to replace..good luck..
Mar 02, 2015 | Cars & Trucks
I have a 2002 lincoln ls that has gas guage reading only a quarter tank when full. I know there is 2 pumps on this car, one is the primary pump under passenger back seat and a jet transfer pump on drivers...
Fuel pumps outside the gas tank have nothing to do with fuel gauge readings. There is a fuel level sender unit inside the tank with a float which supplys variable ground circuit to the gauge. If you can find the wire to this unit, you can ground it to see if the gauge now goes to full. If so, sender unit in tank is bad, or has bad wiring/ground.
Jan 30, 2015 | 2002 Lincoln LS
We can't put more than $20 in the tank before it starts to over flow, with the gas gauge on empty when we start pumping. Then the gauge reads 3/4 tank. When it runs down to half it jumps straight down to...
Your fuel pump assembly located inside the gas tank has a float that measures how much gasoline is in the tank. False readings means the fuel pump assembly needs to be replaced.
Jun 27, 2014 | Cars & Trucks
Ford focus fuel gauge not working
it might be the floater inside the gas tank or the sending unit which sends the info to the ecu and tells you how much gas you have replace that and it should work, sometimes it can be a faulty cluster gauge too
Aug 02, 2012 | Cars & Trucks
2002 Saturn VUE Gas gauge reads empty with a full tank of gas. What is problem?
possible blowen fuse or a bad sending unit inside fuel tank also check the connections at the tank
Jul 27, 2012 | 2002 Saturn VUE
2007 Subaru WRX Fuel gauge does not work porperly. When the tank is topped off, the fuel gauge reads full, but after much driving the gauge only drops to 3/4 a tank and slowly to half of a tank on the...
hi it can really only be two things, first is the fuel sender on the pump inside the tank it could be stuffed or sticking causing a false reading, second it can also be a faulty fuel gauge on the dash.
Apr 15, 2011 | 2007 Subaru Impreza WRX Sport Wagon
My 2008 chevy malibu fuel gauge dose not read only some times when its a full tank the gauge is dead but about 1/4 tank it reads but gos in and out ?
this is caused by a defective gas gage sending unit, the sending unit is part of the fuel pump module inside the gas tank, the gas tank must be removed to replace the fuel pump module that also contains the sending unit.
May 30, 2010 | 2008 Chevrolet Malibu Classic
2006 GMC Envoy XL gas gauge reads empty after filling continues reads empty and the light is on then the check engine light came on what can be the problem how ca i fixe it to save mesome $$$
It is most likely your fuel level sending unit has gone bad. It sits inside your fuel tank to tell the fuel guage how much gas you have in the tank.
The sending unit for the gas gauge is in the fuel tank and part of the fuel pump module, it is not sold seperately. Price is around $350.00, 2 hours labor to install the part.
Feb 18, 2010 | 2006 GMC Envoy
Fuel Gauge Sticks
Replace fuel float sensor inside the gas tank.
Oct 10, 2009 | 1999 Pontiac Montana
1999 GMC Sierra fuel gauge is erratic
the fuel level sensor inside your gas tank might be defective
you need to drop the tank and check the level sensor
Apr 02, 2009 | 1999 GMC Sierra
RTO Fuel Pump Carburetor Transmission Tester Gauge Tool Logo
57 people viewed this question
Top RTO Measuring Tools & Sensors Experts
jdthefixer
Steve
Tim Venetis
Are you a RTO Measuring Tool and Sensor Expert? Answer questions, earn points and help others
