Question about Onkyo TX-SR605 Receiver
Zone 2 During initial setup I was able to activate Zone 2 speakers. Now that all components are connected, and running, I am unable to activate Zone 2 speakers. I go to setup menu (No. 7 - hardware), but Zone 2 is not highlighted for activation.
  • 1 more comment
  • dante64 Dec 31, 2007
    I have the same problem with a 705. Would love a solution.
  • gg66 Dec 31, 2007
    Same problem. Can't change setting in to activate.
  • Anonymous Mar 20, 2014
    connectivity to speakers
The above suggestion may be the cause of the problem. Zone 2 can only play analog, so if you have HDMI connection you cannot output to zone 2.
I resolved my own problem. This is a 7 channel system. Zone 2 needs 2 channels. In my case I bi-amped both front speakers (ran two speaker cables to each). So Zone 1 was using 7 channels, 5 speakers plus 2 added cables for fronts. Zone 2 could not work.
In set up 2 Speaker Settings, select first menu item then scroll to second option on this, change setting from bi-amp to Normal.
Posted on Jan 07, 2008
  • 4 Answers
I am sure this isn't it, but if all components are connected digitally Zone 2 won't work. It only allows analog connections, so anything attached via HDMI, etc. will not be able to be output to Zone 2.
2 Suggested Answers
  • 14 Answers
SOURCE: Zone 2
restore the receivers to factory settings by pressing and holding the dvr/vcr button then press the stand by button. this would erase all assignments made so you would need to redo the assignments of your sources to the receiver, then activate zone 2 by going in to the hardware setup(7.2)
Posted on Mar 04, 2009
How do I get sound to the second speaker zone?
The 5007 has 7 amp channels, so you can set up your main zone to be 5.1 channels and zone 2 to be the remaining 2 channels. Check the manual to see which speaker terminals on the back are connected to which speakers. You will need to go into the setup menu and set the amp for 5.1 + 2 channels. Then you will need to run speaker wires to Zone 2.
I recommend using banana plugs to connect the speaker wires to the 5007. They make a much neater install and eliminate shorts between connections. Sewell Direct makes nice plugs for a very reasonable price.
Mar 07, 2015 | Marantz SR5007 AV Receiver
ZONE2 RXV673 DOES NOT WORK
Look in the speaker setup menu. The zone 2 speakers usually default to surround back, and you must go into the setup menu and tell it you want to use zone 2.
Dec 22, 2012 | Yamaha Audio Players & Recorders
Message volume fixed
Zone 2 Setup on the RX-V773 using the ZONE2/PRESENCE Extra Speakers The RX-V773 extra speaker terminals can power one set of speakers for Zone 2 or Presence speakers. If the extra speaker terminals are utilized then the RX-V773 cannot be set for Bi Amp (Surround Back/BI-AMP terminals). Setting the Extra Speaker Terminals Note: The RX-V773 remote control will be used to access the On Screen Menu of receiver. 1. Press the On Screen button on the remote control to enter the On Screen Menu. 2. The On Screen display should be displayed on the TV/Monitor. 3. Press the Arrow Down button on the remote until Setup comes up in the screen. 4. Press the Enter Button on the remote control. 5. The Setup Menu will come up across the TV/Monitor screen. 6. Use the Arrow Left & Right buttons on the remote to navigate to Speaker. 7. Press the Arrow Down button on the remote to select Manual Setup. 8. Press the Enter Button on the remote control to enter Speaker Manual Setup menu. 9. Speaker Manual Setup menu with Power Amp Assign highlighted will come up. 10. Press the Enter Button on the remote control to enter Power Amp Assign menu. 11. Speaker Manual Setup, Power Amp Assign menu will come up with Basic highlighted. 12. Press the Arrow Down button on the remote to select 7ch+1ZONE. 13. Press the Enter button on the remote to select 7ch+1ZONE. 14. Press the On Screen button to exit the on screen menu. To control Zone 2 using the RX-V773 remote, the switch at the upper left side (above the BD/DVD Scene button) of the remote must be set to Zone 2. To see the operations on the front of the Yamaha receiver you must press the Zone Control button on the front of the receiver. Note: Only analog signals can be sent to Zone 2. If you want to output the sound from Zone 2, connect an external component to USB Thumb drive, USB iPhone/iPod, Network, AV 5-6 or Audio 1-2 by analog connection. For AM/FM radio the antennas must be attached.
Aug 19, 2012 | Yamaha RX-V773
Our 2nd zone won't work, we get the error saying check SP wires. The wires seem connected correctly. We also can't change the volume on zone 2. The Yamaha unit is working otherwise.
U cant get an amplified out put form ur av receiver for zone 2. speaker a A and B is the same out put of frond left and right. it is not ZONE 2 output. U can get only a pre output for zone to from this receiver. U nee a separate stereo amplifier for using zone 2 .put an amplifier in the other room, connect the zone 2 pre out to it. And do the following setup in ur av receiver .
The receiver shows check speaker cable because its amplifier minimum impedance is 8 ohms . when u connect other speaker in speaker the total impedance will come under 4 ohms. Speaker b is not ZONE 2 in this amplifier
1. press the input selector button A or B to select the source component you want to setup.
2. press and hold LEARN (on remote) button about 3 seconds by using a boll pen or similar object ( SETUP and the selected component name appear alternately in the display window.)
3. press up or down arrow to select "zone2"
4. press LEARN to complete the Zone 2 setup.
5. press source select up arrow to display Zone2 in the window.
6. press an input selector button to select input source u want to listen to in the second room
7. u can control the component by using the component control area button
ok
Dec 26, 2010 | Yamaha RX-V2200 Receiver
My ONKYO TX-SR601 receive will not let me play my zone 2 speakers. I get a message saying '' Powered Zone 2 is not activated. How do I activate Zone 2? Thanks. Tom
Have just got a 607 myself, but it may apply to your model too.
Press the RECEIVER button followed by SETUP. On the TV screen a menu should appear and select SPEAKER SETUP then SPEAKER SETTINGS and set the powered Zone speakers to ACT.
SETUP will then return you to normal. Note: some other surround speakers will be switched off when ACT is on and ACT won't come on if Bi-amp is used.
Jun 13, 2010 | Audio Players & Recorders
I have a Yamaha RX V665 and I am unable to change the volume
The volume keys should be working by default, but you may have volume punch through turned on (meaning the remote is sending signals for TV or CABLE volume function no matter what mode you are actually on). To unlock volume control for AUX mode, do the following:
1. Press and release AUX
2. Press and hold SETUP until the remote blinks twice
3. Type 993
4. Press and release VOL-
The remote should blink four times to confirm unlock.
Jun 07, 2010 | Yamaha RX-V663 Receiver
Zone 2
Jan 19, 2009 | Onkyo TX-SR606 Receiver
No sound from rear speakers
Hello, the setting must be "Not Activated" That is for zone 2 setup. If you are setting up 5 speakers the rear speakers should be connected to surround not surround back. Thank you Onkyo USA.
Mar 25, 2017 | Onkyo TX-DS898 Receiver
Zone 2 problem
I know this is old and im sure you have it solved by now, but it might be a good idea to check the amp setting of Zone 2. Is it switched to Internal or external? I remember something strange about this amp in that when you change from using the rear surrounds and go to use them in Zone 2, it resets the amp setting or something like that. Hope it helps if you still need it.
Sep 15, 2008 | Yamaha RX-V659 Receiver
Onkyo TX-SR605 Receiver Logo
1,706 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
