Question about Vivitar ViviCam 35 Digital Camera
Help i took some photos came home & plug the usb cord into the camera then plugged it into the computer next thing the camera had no images i didn't delete any photos how can i recover my pics for free
    Brigadier General:
  • 11,967 Answers
Use a separate card reader to download your pics.
Posted on Sep 04, 2009
HOW DO I DELETE PHOTOS?
1. Most cameras today use a removable memory card of some kind. If you can get it out and have a computer with a card reader on it you can plug in the card directly with a PC. Go to My Computer - Open (Name of Card) - Open Folders until you find your images. Next, select the pictures you want to delete by highlighting them and dragging to the Recycle Bin. (Remember you can drag your mouse to highlight lots of pictures at a time.) Best not mess with the other folders if there are no images in them though, because they contain the information to run the camera. Your card should now have only the images you want. Safely Disconnect the card from the computer. Reinstall the card correctly in the camera and you are ready to go.
2. If you don't have a card reader on a computer then use the USB cable you said you have and attach the camera to a USB port on your computer. Follow the steps above for opening the Memory Card in the camera.
All the above assumes the camera is in good working order with fresh batteries or a power supply. Most USB ports don't output the power necessary to run a camera.
Good Luck.
Mar 02, 2015 | Cameras
Cybershot DSC-P8/P10/P12 problem
The camera may have encounter some damage on that incidenst , what you can try first here is to remove the battery for about 24 hours and after that check if you still ahve teh same problem, but if you're concern in transferring photos to your computer you can still do that using a card reader where you can put the memory card and conenct to the computer....
Oct 24, 2008 | Sony Cyber-Shot DSC-P8 Digital Camera
USB will not recognize Nikon D40 Digital Camera
You asked about the USB connection between your camera and the computer. First, be sure you are using an approved USB cord that came with your camera. Nikon gets a little finicky if you use an off brand. Next, be sure your USB outlet is working on your computer. Plug something else into it to be sure it's functional. Next, reboot your computer and shut off your camera. After reboot turn your camera on to see if the computer now recognizes your camera.
It would help to know what software you're using for the post processing. Some software has an option to disallow uploading of duplicate photos. This could be the case if you've already uploaded these same images previously. You might want to check for that.
Jun 30, 2014 | Nikon D40x Digital Camera
I took my camera on holiday, started taking pictures then discoverd i didnt have the sd memory card in !!! i did take around 8 pictures which are now in the cameras memory. is there a way i can transfer...
Absolutely. With the memory card in the camera, press the Playback button to get into playback mode, press the MENU button to bring up the menu, and select "Copy." The first selection copies from the internal memory to the memory card. On the next screen select "All images" and then select "Yes" on the confirmation screen.
For more details see page 82 of this manual: http://www.fixya.com/support/p445079-nikon_coolpix_l2_digital_camera/usermanual-2B19FE3-pdf
Oct 14, 2013 | Nikon COOLPIX L2 Digital Camera
How do i upload photos from camera to computer
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
If you insist on using the USB connection, you can still use Picasa to copy your photos.
Jun 11, 2012 | Sony NEX3 Digital Camera
When I plug my camera into the computer using the USB cord that was given, the computer says that the camera or scanner cannot be detected. I have used the same cord with the same computer many times...
Its not always a solution but you can try using a *DIFFERENT* usb port on the computer. Windows sees each USB port as a separate thing and treats them differently. It sometimes works.
You could swap the cable if its standard. Cables do break now and then so it is a possibility. Its usually easy to find a second cable for a test.
You can check control_panel -> system -> Hardware -> Device_manager -> Imaging
[Camera name]
See if its happy. if its not, right click-uninstall it, see if it reinstalls ok next time you plug
the USB in.
Its all 15% success solutions which adds up to 45% so its probably not the answer, sadistically speaking.
Jun 25, 2011 | Nikon D60 Digital Camera
Win XP Home will not recognize my Canon A1100 is when it is connected via USB. Camera on or off when connecting makes no difference. If a still image is selected for preview & connecting via USB, no...
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Dec 06, 2010 | Canon PowerShot A1100 IS Digital Camera
Need USB cord to transfere photo to computer
You don't need a USB cable.
Dec 07, 2009 | Kodak EASYSHARE M1063 Digital Camera
Pictures not loading to computer
It sounds like you don't have software on your PC that will recognize the camera when connected. I am going to recommend that you do not use the camera to upload photos. It is better practice to use external (SD) memory cards and remove them from the camera to upload. You can use a USB SD reader or purchase SD cards with a built-in USB interface. You should be able to see a new drive when connecting the SD card to your computer; then all you need to do is copy over the images. One advantage is that you will save camera battery while uploading because you dont need the camera at all. It also allows you to take images with you without taking the camera, i.e. school or work. I hope this helps...californiajones7889e54.jpg67432f4.jpg4db3d64.jpg
Mar 09, 2009 | Kodak EasyShare C875 Digital Camera
How can I transfer pictures from my olympus fe280 to my computer?
Hey emedic121,
The first thing you should do is to install the Olympus master software that came with your camera on your computer. Next you need to connect the camera to your computer using the supplied USB cord, and then you should start up the software by double left clicking on the software icon. Lastly you should download your image files from the camera to your computer, and then disconnect your camera from the computer. You can also use a memory card reader that plugs into a USB port on you computer and download your images using that. More detailed instructions start on page 35 of your manual. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 05, 2008 | Cameras
Vivitar ViviCam 35 Digital Camera Logo
35 people viewed this question
Top Vivitar Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
