Question about AMD Athlon 64 LE-1640 Processor ADH1640DHBOX - 2.60GHz, 1MB Cache, 1000MHz FSB, Orleans, Retail
My core speed drop always to 999,99 then 2000 then 1999 then 2500 and 2700mhz whats the problem ?? plzz help ??
    Scholar:
  • 87 Answers
The CPU you have is an energy efficient cpu. It will throttle back to save power. It does this on demand so it will change constantly. What you are seeing is normal.
Posted on Sep 12, 2009
    Sergeant:
  • 270 Answers
Some tips to increase your system performance
If you have an old and slow computer, do following to increase your system speed:
1- Disable Scan Disk
Click Start menu > Click run. In the run dialog box type: msconfig to open System Configuration Window. Then open "system configuration programs". In the General Tap click on Register and then check "Scandisk after error by shutdown disabled" to disable ScanDisk.
2- Disable auto start programs
Open System Configuration (msconfig) . click on the "Startup" tap and in the application list , Clear the check box for a startup item to disable it on your next boot.
3- Disable Windows Startup sound
Go to Start > Settings > Control Panel and then click on " Sounds and Multimedia" icon to open it. In the Sound tab disable Windows Startup sound.
4-disabe unused programs
Go to Start > Settings > Control Panel and click on "Add/Remove Programs" and uninstall old and useless programs.
5- Delete offline e-mails
Yes, offline e-mails especially e-mails with attachments can slow down your pc. Delete these e-mails.
6- delete temporary internet files
Temporary internet files can slow down your pc. In internet explorer click on tools menu and then select Internet Options and the click on " Delete Files and Delete Cookies" buttons to delete these files.
7- Defragment your Hard Drive
Defragment your hard drive every 10 days. To defragment your Hard Drive, click on Start menu > Programs > Accessories > System tools > Disk Defragmenter.
8- update your Windows
Turn on your Windows Automatic Update to have recent updates for your Windows.
do it in your system.Thankyou
Posted on Sep 11, 2009
The heat is blowing cold
cab heat? what year, no year, no exact answer.
so drop to generic.
1: engine must reach and old 180F, if not NO HEAT !
2 the blower must blow full speed on high , does it?
3: the water valve must be open if car has one, (look)
4: if the core and valve are not packed up then the core makes heat
5: if and only if the damper is not blocking the core shut.
just 5 steps and checks and bingo , the reasons.
no year, no joy.
Jan 09, 2014 | Honda Pilot Cars & Trucks
Where can I download free Pentium Dual-Core Processor E5500 2.8GHz 800MHz
i want to free sound driver & graphic card driver for intel dual core processor e5500 @ 2.8GHz
Plz plzz help me......
thanks
Jan 04, 2012 | Intel Pentium Dual-Core Processor E5500...
I have been given a acer aspire L320 BUT THERE IS NOT A PROCESSOR IN IT. what i want to know is what processor fits.it
The Acer Aspire L320 can take 3 different processors
1. Intel Core 2 Duo
Dual Core chip with speeds from 1.8Ghz to 3.3 Ghz
2. Intel Celeron D
Dual Core chip with speeds from 1.6Ghz to 2.7Ghz
3. Intel Pentium 4
Single core chip with speeds from 1.3Ghz to 3.8Ghz
The Core 2 Duo 3.3 Ghz is the most expensive and Pentium 4 1.3 Ghz the cheapest.
Some more information is available on the Intel website, links are below:
http://www.intel.com/products/processor/core2duo/mobile/index.htm
http://www.intel.com/products/processor/pentium_dual-core/specs.htm
Hope this helps. Thanks for using Fixya.
Jul 13, 2011 | Computers & Internet
I’ve have problems with getting sufficient heat from my 2002 Jeep Liberty - Took the 2002 Jeep to dealership - First they wanted to replace the thermostat [$200], I explained it was replaced in November...
Here's the way I usually approach problems such as this. First I'll hook up a scan tool that allows me to see the actual engine coolant temperature is [not just what the gauge says] as the vehicle is being driven down the road at highway speeds. The coolant should be near the 192 - 200 degree range to get the best heat out of the heater. If the coolant temp is below that level then the amount of heat you'll get will drop according. IF the coolant is reaching full temp but the air coming from the heater isn't very warm then you could have a restricted heater core or a temp control door in the ductwork that isn't working properly and is allowing cold air to sneak past the heater core. Usually if you have a water pump impeller problem you'll also have an overheating problem as the pump often isn't able to move enough water through the radiator to keep the engine cool. Hope this gives you a starting point and good luck!
Dec 22, 2010 | 2002 Jeep Liberty
No heat in 99 ford windstar
Check the coolant level. If it's low, what you describe will happen. There is not sufficient coolant to flow through the heater core at idle. At 60mph the water pump is spinning quickly, managing to get some coolant through the heater core, so you get heat until the rpm's drop at idle. If it is due to low level, keep an eye on it to see if it drops again, as you may have a leak.
Jan 06, 2010 | 2001 Ford Windstar
AMD 64 x2 dual core processor 3800+ speed problem.
increse your RAM to a heigher one.it is necessary to load large graphics.or insert a graphics card
Aug 19, 2009 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Open Questions:
See all AMD Athlon 64 LE-1640 Processor ADH1640DHBOX - Questions
AMD Athlon 64 LE-1640 Processor ADH1640DHBOX - 2.60GHz, 1MB Cache, 1000MHz  FSB, Orleans, Retail Logo
238 people viewed this question
Top AMD Computers & Internet Experts
David
David
rafnix
rafnix
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
