Question about HP Officejet 6310 All-In-One InkJet Printer
The plastic tab stuck in picture card slots
There is a foreign object in one of the picture card slots and now printer won't print. Can I take it apart and get the plastic out?
What could the Grinding noise be that is coming from Ricoh Aficio MP C2550 for each page copied/printed?
Check for:
-broken plastic gear on right side of copier
-paper or foreign object in paper path
-paper or foreign object near fuser
Oct 15, 2014 | Ricoh Aficio Mp C2550 Copier With Feed,...
Flashing paper and power buttons
This error means jammed paper or a foreign object is blocking print head movement. Turn off the printer, press the adjust lever down to the lowest position, and pull out the jammed paper. Open the cover and remove any jammed or torn paper, or foreign objects. Then do one of the following:
Sheet Feeder: Return the adjust lever to the position. Turn on the printer, reload paper, and press the paper button.
Manual Feed Slot: See page 15 of your manual for loading instructions.
Roll Paper: Cut off the printed portion with scissors, then remove and reload the roll paper
Mar 08, 2014 | Unknown Epson Stylus Photo R2000 Ink Jet...
Getting message that I have a paper jam but there isn't on to be fpund
Try checking the printer for foreign objects that might be interfering with the paper path. Tilt the printer sideways and try shaking it a bit. After that, try printing. If the issue persists, clean the rollers of the printer.
Dec 13, 2012 | Lexmark X4850 WIRELESS All-In-One InkJet...
Printer only takes paper from one end resulting in a paper jam
I would not have believe this if I have not actually experienced it. Today, my Canon PIXMA MP470 started feeding my paper crooked, to the right where the feed roller is located. Did some research and found numerous people discovered foreign objects inside their printers. Since I had tried numerous other solutions, such as maintenance cleanings from the printer control area. I decided to unplug the printer, turn it upside down and shake it, hoping to dislodge a foreign object. It didn't work. I then took compressed air and sprayed vigorously inside the printer, and tried it again. It didn't work. I then took some card stock (the type used for making greeting cards), put it into the printer and began printing a word processed document - just something to get the card stock to enter the printer. I manually forced it into the printer as it started to print, then after the card stock was about two inches into the printer I manually pulled the card stock back, and THERE IT WAS! My memory card insertion slot protector from my netbook! Thank you Jesus! It is a small piece of black plastic that had fallen from the top of my printer, where I had foolishly placed it while I was using the memory slot in my netbook. Printer works great again! I hope this helps someone!
Jun 15, 2012 | Canon PIXMA MP470 All-in-One Printer
A key bunch fall in the paper loding slot and stuck inside cannot take it out tell me how open the cover?
If you are willing and physically able, carefully turn your printer upside down. Any foreign objects should freely fall out of the feeder. You may have to slightly shake the printer if the key won't fall out.
Jun 21, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
MY EPSON DX3800 PRINTER WILL NOT PRINT CONSTANTLY FLASHING LIGHTS TELLS ME TURN OFF REMOVE FOREIGN OBJECTS THERE ARE NO TRAPPED FOREIGN OBJECTS IV TRIED UN/RE INSTALL NO JOY PRINTER MINT CONDITION IM NOT...
Your printer detects the head is not moving or being blocked.
Usually the problem is caused by the ink cartridge cover not fully closing, remaining paper, ink buildup on the metal rods on which the carrier slides or the encoder strip being dirty, damaged or missing.
the encoder strip is a clear plastic film with markings on it running trough the printhead carrier.
you can find a picture of such an encoder here taken from another model printer
Dec 26, 2010 | Office Equipment & Supplies
My mp760 says incorrect print head or remove foreign object from printer but i can't see anything stuck in there.
Make sure that there is no piece of paper stock between the print head and the side of the printer, the print head is the assembly that runs left to right during printing, you may find a paper or other object blocking the assembly from complete the travel to the right or the left. If all clear you need to replace the print head assembly.
Good luck.
Nov 23, 2010 | Canon PIXMA MP760 All-In-One InkJet...
Paper is getting stucked in the canon printer
Just clean the print head and also ensure that the paper is placed proprely and no other piece of the paper is inside it . Most probably cleaning the print head willsove yur problem
Thank U
Please rate my solution as it wil cost u just one click
Nov 05, 2009 | Electronics - Others
Paper jam every time you try to print
remove existing paper..check for black sensor. clean pickup roller
your question is as evasive as my answer.
Jul 09, 2009 | Dell 1700 Laser Printer
HP Officejet 6310 All-In-One InkJet Printer Logo
26 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
