Question about HP Officejet 5610 All-In-One InkJet Printer
It says scan failure, cycle power and try again. what should I do?
  • info57979 Sep 04, 2009
    Thank you,
    I tried all the sollutions given, but it keeps saying:
    scanner failure cycle power and try scanning agai.
    At this moment I can not make a copy and I can not send a fax.
    Thank you again for your help
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 54 Answers
1. Visit the below document and perform the steps provided in the document.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00787271&cc=us&lc=en&dlc=en&product=441125
2. if issue still persists,
Disconnect the power cable from power source without turning off the product.
press and hold Ok and Cancel button while inserting power cord into printer.
Posted on Sep 04, 2009
  • mostlyhappy Oct 14, 2010
    Item "2." worked for me. On a C4100 with the same "sudden for no reason" no scan or copy issue. I assumed the instruction, sreenu-ysr, meant to leave the plug (power socket) left in and the USB plug to the printer to be taken out and re-inserted during the hold OK and Cancel simultaneously. Well, that's worked for me :)
    I'd looked at a registry amendment, which didn't seem to apply according to what my registry showed, and a reinstall of the disk seemed to make no difference. How wonderful that your solution seems to have worked (for me at least). I thank you. If there was a "bowdown" or "round of applause" smiley, I'd happily use it :)
3 Suggested Answers
komguy
  • 2306 Answers
SOURCE: Scanner Failure
Scanner failure means the scanner is not making enough light to see the home position. It happens when the scanner lamp ages or is covered with dust. Cycle power is just power off and on again, and see if it goes away.
Posted on Jul 02, 2009
Riztech
  • 731 Answers
SOURCE: Scanner Failure Cycle Power and try
Please try below resets one after the other if issue is not solved by 1st method.
Power Drain:
  • Turn OFF the printer, disconnect the power cable from backside of the printer and from wall outlet.
  • Press and hold the Power button for 60 seconds.
  • Connect the cable and turn ON the printer.
Partial Reset
  • Remove the power cable from back side of the printer while its ON.
  • Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
  • If printer turns OFF, press power button to turn it ON.
Semi-Full reset
  • Remove the ink cartridges.
  • Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
  • Insert the ink cartridges.
NVM Reset
  • Press and hold "OK" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
Regards
Riztech
Posted on Jan 11, 2011
Scanner Failure Cycle Power and try scanning again. I have changed both cartage but the problem is same. Plz tell me factual position of the problem and its remedy. Umar Hayat
Scanner doesn't require a good cartridge, just a compatible one. Problem is software. Uninstall the software for it and do a clean install. I assume that you are speaking about a printer/copier/scanner for your computer.
May 30, 2017 | The Office Equipment & Supplies
My HP Photosmart C5240 will print from computer but will not scan or make copies.
Is there any error message displayed on the control panel of the printer just like one of the following:
Scanner failure, power off and on
Scanner System Failure
Scanner failed, cannot make copies or fax
Scanner failure. Unable to scan, copy, or send a fax
Scanner failure, cycle power
You may want to try following these steps:
1. Check if the scanner light does turn on when you initiated the scanning process, if not you need to reset the product.
2. Try using your other electrical outlet because your AVR or Surge Extension may not be providing enough voltage for the printer.
3. Try using dirty cycle, meaning you need to directly cut the power of your printer by pulling of the power cord from the rear side of your printer and wait for about 30 seconds before inserting again and turn it on.
If all these steps do not improve your printer functionality, you may want to call the HP online help and ask for replacement.
Job Espinosa
Feb 15, 2011 | HP Photosmart C5280 Printer
Calypso washer stops/runs every 5 - 30 seconds in the middle of any washing cycle. No error codes. It just stops and than runs again all the time and cannot finish any washing cycle. It is 8 years...
I had the same problem. The washer control board has an intermittent failure. If you unplug power for about 30 minutes then plug it back in you will get a PF code (power failure). Ignore this code and push start again. It may run till it finishes the cycle or it may start cycling again right away. A new board costs about $180 at repairclinic.com
Aug 21, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
When I try to scan something on my HPofficejetJ5750 all in one I get an error Cycle Power and try scannin again what does this mean?
This is covered in the following support document from HP: (start troubleshooting at the top of the page, quit when problem resolved). Failing these solutions, your OfficeJet 6110 may need service/repair.
HP Scanner Failure, Power Off/On
Jan 04, 2010 | HP OfficeJet 6110 All-In-One InkJet...
The error message says "cycle power try scanning again". What should I do?
To "cycle power" means to first turn the printer off, and then to turn the printer on.
To "try scanning again" should be self-explanatory.
Nov 05, 2009 | HP Officejet 5610 All-In-One InkJet...
Scanner Failure
Jul 02, 2009 | HP Photosmart C6180 All-In-One InkJet...
Cycle power and scan again
just go ahead and try to connect with different wall outlets
:just check if power adaptor is warming up
:the problem is that it is nt able to provide enogh boost of power to help it scan
:after that take out the power cable
;press the power button fr 30 secnds
:while u are holding the power button
plug back the power cable
:u will able to fix the problem
Jun 28, 2009 | HP Officejet 5610 All-In-One InkJet...
power cycle means to  disconnect the power cable from the back of the printer whlie the printer is turned on,and than wait till 10 secs before repluging in the cable again.. do this step and it will resolve the probelm!
Feb 03, 2009 | HP Officejet 5610 All-In-One InkJet...
Scanner FailureTurn power off then on again Message Window pops up continuously
Below is the document that i want you to follow.
CLICK HERE ===>> DOCUMENT
Pleae let me know the result after performing the steps.
thank you so much.
adonscott
Jun 26, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
1,032 people viewed this question
Seeker5211
Seeker5211
