Question about Whirlpool Washing Machines
Leaking from a washer/dryer in condo
I have a Swirepool 27 inches electric stacked washer/dryer in my condo. Recently, I felt the floor is wet and I believe it is leaking from the washer. It it no way I can see where it's coming from, because it is no space to check (inside the closet). How can I un-install/remove the washer/dryer for a further investigation/inspection? Please give advise. Ken
    Problem Solver:
  • 18 Answers
Just turn off the water, remove the hoses and unplug it, then bring it out away from the wall. You should be able to tilt the machine and see it from underneath to detect the source of the leak. Also, find how to remove the front of the washer without dimantling the machine and run it without the front panel on there. That is the best way to track down your leak. It could be a seal under the tub, a hose coming from the tub to the pressure valve, a hose from the water pump or the pump itself. The pump is at the bottom, so it will get wet regardless of where it is leaking from. Make sure you dry out everything before you start to look for the leak.
Posted on Sep 06, 2009
  • aldensteve Sep 06, 2009
Stacking washer and dryer still vibrating and walking during spin cycle even though stacking kit is attached
Assuming that you've installed the stack kit according to instructions, you should check the following:
1. The dryer should be securely attached to the washer and not wiggle or move. The washer must always go on the bottom of the stack.
2. Washer should be level and have all four level legs making solid contact with the floor, no wobbling.
3. Make sure the drain hose is not pinched or restricted (or there is not debris in the drain pump) as a slow pump out will accentuate vibration problems.
4. Make certain you've removed all of the washer packing bolts before using the machine (see owners manual for description.)
5. The floor must be solid with no "springy" or "spongy" feel. No matter what you do to the laundry set it will vibrate on a less than solid floor. This occurs on upstairs installations or other wooden floors, especially in an older home. Sometime the floor can be braced to stiffen it. Also, vibration pads are sold that might help minimize the vibration. The walking is a symptom of vibration.
Experience shows that most problems of this sort result from incorrect installation and/or flooring issues, not the laundry. You should not attach it to the wall. It is possible the washer has a problem in which case a technician would need to check the unit. They can check the suspension and drive system for proper operation.
Aug 24, 2014 | Samsung Front-Load Washer and Dryer stack...
I have a 27 inch stacked washer/dryer unit, and want to disconnect the buzzer from the dryer, as it is way to loud !! so how do I due this ?? thanks Peter F.
pull the control panel off and behind there will be a black box with 2 wires disconect them and tape them up . also the box does not come through the front
Oct 25, 2010 | Kenmore 98702 Stacked Washer/Dryer
The floor in front of the washer/dryer is getting wet
Most likely it will be a bad tub seal and bearing. This is a very labor intensive job I would probably call a tech.
Jan 29, 2010 | Kenmore 94862 Front Load Stacked Washer /...
Separating a washer dryer combo
This is a one piece unit. It does not come apart. Use and appliance hand truck with straps to secure. You will need at least 2 people to get unit out, heavy. I used to deliver appliances.
Jul 03, 2009 | Frigidaire FEX831CS Top Load Stacked...
Washer fills during spin cycle
Replace the timer, you can find the product name model and serial number on two place. Either the back panel or on the lid underneath. Please rate if this helped thank you
Feb 12, 2009 | Whirlpool LTE5243D Top Load Stacked...
Water fills the washer during spin cycle
defective timer...a model # should be under the lid...or open dryer door and on front dryer panel right hand corner..onthejob
Jan 16, 2009 | Whirlpool LTE5243D Top Load Stacked...
Electrical how to make it to 120v.
The drive motors for the washer and dryer run off 120 VAC, but the heating circuits require 240 VAC in order to work. You will need to have a 240 VAC outlet installed in order for the appliance to run properly. There is no conversion for this. This is the way the appliance was made.
Oct 07, 2008 | Kenmore 98702 Stacked Washer/Dryer
Both broken?
sounds like an electrical issue for sure, too coincidental that both would stop functioning at asime time, they are independent units and should work separately . i would check your breakers, perhaps it has partially tripped
Apr 12, 2008 | GE WSM2780W Stacked Washer / Dryer
I have an oil leak on a stacked washer and dryer
oil leakin on floor is a result of a bad transmission seal, yoiuneed to replace teh tranny and clutch assy,(generally covered for extended period of time through the manufacture(check you owners manual for possible coverage
Dec 10, 2007 | Kenmore 94802 Front Load Stacked Washer /...
Open Questions:
Washing Machines Logo
85 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
