I had this ame thing happen and it was easy to fix.. I backwashed the filter.. I was told if the filter or pump is plugged the heater wont fire up . Its a protective device to keep the heater from burning up with no water running thru it.. I see your post was back in Sept . maybe you dont need this answer anymore..
A few things dictate when the main burner turns on. One is a thermocouple not getting hot enough, the other is a bad thermostat ot thermostat wire, and another is the gas valve. First look at the gas valve located on the heater and make sure it is in the On position and not in the Pilot position. Remove your thermostat and jump the two wires together. The heater should light. If not, go back to the gas valve and find the wires up to the thermostat, the should be attached to terminals marked TH and MV or something similar. Jump the terminals. The heater should start. If not, you may need to replace the thermocouple.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Lite On Laars Lite 2 Heaters:
have a problem with a laars boiler the pilot keeps going out. the thermostats only work on max as...
(More)
have a problem with a laars boiler the pilot keeps going out. the thermostats only work on max as well. have serviced the boiler and replaced the thermal coupler. the unit is about 10 years old and is used for radiant floor heat
laars lite 2 pool heater heats and then stops I checked the temp sensor and it is fine. Is this the...
(More)
laars lite 2 pool heater heats and then stops I checked the temp sensor and it is fine. Is this the temp controller?
I am winterizing my Laars Lite2 pool heater and have what may seem to be easy questions but... What...
(More)
I am winterizing my Laars Lite2 pool heater and have what may seem to be easy questions but... What Do I grease the drain plugs with before I put them back after draining heater?. Should it be Silicone based? Also where do I blow the compressed air to dry out heat exchanger?.. Thru the drain plug holes? Thanks
I have a Laars LX400 heater. Yesterday the heater would not start - Hi Lim SW error. I replaced...
(More)
I have a Laars LX400 heater. Yesterday the heater would not start - Hi Lim SW error. I replaced both of the limit switches. Now when I start the heater, there is no sound for a minute or so and then I get "Air Flo SW" error.
