Question about Necchi Sewing Machines
Thread not picking up bobin tread - Necchi Sewing Machines
    Scholar:
  • 76 Answers
Not sure which model you have, the best thing is to re thread the upper and the bobbin, make sure you put the bobbin in the right way. if you have the tenson on the front of your machine make sure the thread goes between the disks and correctly goes around the spring tension wire the right way it should be under it after lifting up on the thread.
if the bobbin is in wrong the thread will not be pick up try flipping it and turn the hand wheel by hand to bring up the thread,
Posted on Sep 04, 2009
I need to put bobin in place but Nedle dosent take the tread up
Make sure you are using a brand new needle and that is inserted correctly (there is right & wrong way!).
If it still will not pick up the bobbin thread, most likely the needle/hook timing is off. Take it for service.
Aug 09, 2016 | Sewing Machines
My singer 4423 wont pick up the bobin tread
try changing the needle
rethread the machine top & bobbin
make sure the bobbin is inserted correctly into the bobbin case
if these suggestion don't help,,then the machine needs to be
checked by a sewing machine technican to see if it's out of time
Jul 31, 2012 | Singer 4423 Sewing Machine
It can't pick up the thread out to sew
Make sure that you have a tail on the bobin thread when in place and a tail on the needle thread, hold the needle thread and turn the wheel to bring up the bobin thread before trying to sew
Aug 13, 2010 | Sewing Machines
I have a viking +1 and the thread is gathering in the bobbin area. I have tried seems like everything. Please help.
do you have the treaded seated in the upper tension? you may have the bottom in wrong and have you cleaned the bobin area?
Jul 07, 2010 | Husqvarna Viking 1
Needle not picking up bobbin thread. Seems threaded properly. lsd-1 (classic) Problem occurred after needle hit something perhaps the the cap spring which had some marks on it but no real damage. ...
change the needle, if bent it may skip, use top thread while holding to pull thru, turn bobin around to turn in oposite dirrection, bobins usually turn in 1 correct dirrection
Sep 28, 2009 | Sailrite Sewing Machines
Upper thread not being picked up by bobin thread
Is the under thread getting all bunched up?
Mar 23, 2009 | Sewing Machines
Brother sewing machine vx1120 Ithink won't pick up bobbin thread
have you tried other thread and a different bobbin?  The tension screw on the bobin case could be too tight.
Mar 11, 2009 | Brother LS-1217 Mechanical Sewing Machine
Lower thread tension is too loose but no adjustment seems to work
From your description it appears that you have tried tension settings on the upper tension control adjustment knob without success.
Check that the bobin tension is adjusted correctly by taking out the bobin complete with the spool.
Pull the cotton thread and it should be a smooth light pressure if the tension is correct. If it is tight to pull or pulls freely then adjust the tension screw which is found on the outside of the bobbin. The screw is very small and requires a minature size screwdriver. The adjustment will only be a slight turn of the screw one way or the other to obtain the correct tension(depending if it was loose or tight).
Once this is set reinstall the bobin and tread up the machine, hopefully with the upper tension set at approx."2" the machine will sew correctly.
Nov 28, 2008 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
