Question about Gb Electrical Electrical Supplies
If I have Hot/neu. reverse on my tester. What problems will that cause?
  • Jyackle5
    Jyackle5 May 11, 2010
    It will not cause a problem at all. The only problem you will have is when you go to sell the house and have it inspected they will want it fixed. To fix you need to call an electrion and have them reverse the hot and neturel wire.
    Good luck and please rate
    President:
  • 704 Answers
The Solution posted by jyackle5 is incorrect. If you HAD a problem with a breaker with Hot and Neutral reversed, you'd have the possibility for a short circuit, and it would adversely affect any electronic device plugged into a outlet on that circuit.
Fortunately, you are describing an issue with your test meter.
If you have the leads reversed on your GB (Gardner Bender) meter/tester, it will provide a negative value/number instead of a positive valve in the readout. Depending on the diagnostics you're trying to do and if you're testing voltage or resistance, you should have the correct orientation of the lead.
It's always best to make sure the red and black leads are in the proper jacks for AC or DC Voltage and in the Ohms sockets when taking resisitance measurements. Always start with the higher setting if in doubt about the voltage you're testing and you can go down one setting at a time until you have a good reading.
Hope you find this helpful and best regards!
Posted on Sep 16, 2009
I would like monitor to only come on in reverse. how do I wire it up?
you or whoever wired it must have done it incorrectly. To get the monitor to come on in reverse, the hot wire needs to be hooked to the wire that causes your backup light to come on. check with a tester to be sure.
Nov 29, 2017 | Computers & Internet
Outlets do not work, circuit tester says Hot/ground reverse but all connections appear correct, circuit is on an arc arrest breaker.
Move wires to different breaker with same amp rating?
Try different tester?
Test wiring box-by-box to locate the reversed connection.
http://waterheatertimer.org/Basic-house-wiring.html#loose-wire
Check each box for Hot and neutral:
http://waterheatertimer.org/Basic-house-wiring.html#test
Gene
Nov 11, 2014 | Electrical Supplies
How to fix hot/ground reverse outlet
The black and the white wires on those plugs are reversed. Turn the power off for those plugs, and swap the wires. The black wires go to the brass colored screw, and the white wires go to the silver colored screws.
Jun 01, 2013 | Electrical Supplies
No power
something is loose or power not correct. ck polarity at outlet. narrow pin is hot wide is neutral and round center is gnd. 120v hot to neu and gnd 0v neu to gnd
Sep 17, 2012 | Whirlpool Washing Machines
I am trying to replace an old spring loaded attic fan timer. The old time simply had a black line in and a black line out. There was both a white and red line capped off in the box along with a bare...
The timer is wired differently than the old spring-loaded timer.
This is because the timer has an electronic clock instead of a spring.
The electronic clock needs power just like an alarm clock.
The white wire powers the clock.
Here's the wiring.
Black-timer wire connects to Hot-wire-from-breaker
Red-timer connects to Load (attic fan)
White-timer connects to white Neutral
In absence of a Neutral, connect white-timer to bare ground.
If you have your black-timer and red-timer wires reversed, it might cause the symptoms you describe.
Simply reverse the black-timer and red-timer.
If you want to test your wires to make certain:
Remove timer.
Separate wires for testing.
Turn on power.
Use ordinary tester.
Tape tester leads to wood sticks to keep hands away.
Power is ON.
Test each wire to bare ground wire.
When tester lights up, that is hot-wire-from-breaker.
Now test hot-wire to each of the other wires (except ground)
When tester lights up, that is Neutral
Not every switch box will has a Neutral
In that case white-timer connects to ground
Nov 08, 2010 | GE 60minute Automatic ShutOff Timer Switch...
What does open neutral on my gb circuit tester also hot/ground reversed mean
An open neutral means that neutral, or common wire is not connected somewhere. If for example you test a outlet in a room, and the tester shows that you have an open neutral, Then somewhere along the circuit the neutral is not connected properly. In rooms most outlets are connected in series to each other, so if you have an open neutral in one outlet, it can affect all the other outlets too.
Hot/ground reversed means that the hot wire and the common wire are installed in the wrong order.on the outlet,you have a hot side (black wire)and a common side(white wire)and the hot wire is installed on the common side instead of the hot side and the common is installed on the hot side.This show up on the tester this way because the common and ground tie into the same bar in the panel.
Fix the open neutral first as this can show incorrect reading on the tester on all outlets after the open neutral.
Aug 03, 2009 | Gb Electrical Electrical Supplies
Grohe Chiara flow and temperature
If this is only happening in the one shower then it sounds like you have some trash in the hot side of the cartridge. With out being out at your house looking at , I would say pull the cartridge and clean it then put it back in. Dont forget to turn the water off to the house first! If this does not work the let me know.
Feb 01, 2009 | Grohe 19-206 206 Chiara Neu Thermostatic...
Understanding Outlet Circuit Test Results
open ground=ground wire (green) is not connected to the circuit box ground or to the earth ground.
(there should have steel rod place in the ground by the local electric company, and gtound wire is connected to that rod).
Open Neutral= same as open ground. unless you are testing 240V, which have 2 hot (110v) and a neutral (0V).
Open Hot= open 110v line (black)
hot/ground reversed= if you understand the above, then this sould be self explaintory.
same a hot/neu. reverse.
if you don't understand how electric wiring works, My suggestion is to stay out.
Dec 27, 2008 | IDEAL MCM TESTER GFI CIRCUIT
Receptacles wired backwards
"Reverse polarity" is the term used to describe the condition where electrical wires are connected to the wrong terminals of a receptacle; it's a common condition that can be hazardous if the "hot" side of your electrical system gets connected to certain types of lamps or equipment. It's common because it's an easy mistake to make when hooking up wires and because receptacles work fine even when the polarity is reversed. You generally don't know the condition exists unless you look for it. If you think you're home's wiring is a bit haphazard or may contain some conditions of reverse polarity, it's a good idea to check for it. You can buy a simple circuit tester for less than $20. Just plug it into all duplex receptacles; test both the top and bottom. If you discover reverse polarity: 1) Shut off the circuit breaker that serves that receptacle (the tester's lights will go out). 2) Unscrew the cover plate from the receptacle, and use a voltage tester to be sure none of the wires in the electrical box are still "hot." 3) Unscrew or release the wires from the receptacle and re-fasten them to the proper terminals--white to the silver (neutral terminal and black to the brass hot terminal. The bare or green wire should connect to the green screw. 4) Put the cover plate back on, turn the circuit back on, and test the receptacle again. Note: If the tester indicates reverse polarity but the wires are hooked up to the proper terminals, call an electrician.
Jan 18, 2006 | APC MasterSwitch Power Receptacle - Power...
Electrical Supplies Logo
498 people viewed this question
Top Gb Electrical Electrical Supplies Experts
Steve
ken skalski
Are you a Gb Electrical Electrical Supply Expert? Answer questions, earn points and help others
