The 'GENTLE/SLOW' wash/spin does not work. it is always 'NORMAL/FAST' speed
    President:
  • Washing Mach... Master
  • 2,923 Answers
The problem is isolated with the GENTLE/SLOW wash. The problem could be the rubber tub torque straps. But I'm not sure where it's exactly located in the washer. I would advise you to refer to the user manual of the washer.
Posted on Sep 04, 2009
I have a front loader washer Kenmore Elite Model #796.40311900 that spins SLOW, not FAST as it should on spin. The digital readout works normally.
sounds like maybe drain filter is plugged and unit is not draining fast enough. if you have drain access in front pull it out and clean it.
May 08, 2017 | Kenmore Washing Machines
My washer skips the spin cycle sometimes i turn the dial to another spin cycle sometimes it works other times no
If you timer switch "skips" the spin cycle (passes through it faster than normal) then it is probably your timer switch.
Or it could be your transmission. The transmission is a two speed unit and the wash cycle is the slow speed and the spin cycle is the fast speed. So if the problem is only the spin cycle then it could be transmission problems. BUT since the transmission is normally a sealed unit on the newer machines you will have to replace the entire transmission instead of just the high speed gear.
Aug 14, 2011 | Washing Machines
My washer will not change speed in spin cycle
do you have a speed control (switch fast , slow, gentle )on your backsplash timer console if not your washer spins at one speed
Jan 26, 2011 | Roper Washing Machines
I have a Hoover Zodiac12 2-speed reversible motor i want to use for a home project. Its a Nuova Ibmei with 5 terminals. The wires are L to R and top to bottom; 1. black stripe, 2. blue, 3. yellow, 4. red...
You will destroy the motor by running it with multiple speeds tied together. So be careful. Just try and get it to work with 2 wires and tape the others off away from each other and the frame so they won't short anything out. themobilian_795.jpg
Jan 04, 2011 | Washing Machines
My washer when it goes to spin the motor sounds like starts n stops starts n stops
Check your speed selector switch (fast/slow, fast/fast, normal/fast etc.)first and foremost! Make sure it not set in-between speeds.
If it is ok then my nest bet is that the switch itself is bad.
If your machine does not have a speed selector switch, I'm afraid you may have a bad motor.
Good luck!!
Jun 15, 2010 | Kenmore 22422 Top Load Washer
I have a GE clothes washer, model# WKRE6280D0WW, and the agitator has stopped working. It just spins freely in the drum. The wash setting has always been on normal/fast, but a few days ago, I set it to...
What you have is a bad drive block. Grab the agitator and snatch it off. The block is bolted to the tranny.
54b9ead.jpgWH43X10009 is the part number. Not very expensive nor hard to replace. the agitator snaps onto this block. The block is plastic andit has splines in it. they wear down smooth and cause the washer to do just what you describe.Read more
Mar 07, 2009 | Washing Machines
Kenmore Washing machine spins slow
If it has a speed selection switch than this switch is likely to be bad, other than that are you sure that It once has high spin in the cycle you are using??
Jan 14, 2008 | Washing Machines
Clothes wet, doesnt spin fast
Check the drain spigot, where the drain hose attaches to the drain trap under the sink/tub.There may be a blockage in the spigot which is causing the water to drain very slowly and therefor not allowing the machine to spin at normal fast speed.
Oct 22, 2007 | GE Energy Star WCVH6260F Front Load Washer
Not spinning in high speed
possibly a faulty "off-balance" detector, but not sure...try to purposely make it go off balance during wash...maybe a few pairs of sneakers?
Jun 02, 2007 | Hoover Nextra HNF 3157 Front Load Washer
Gentle Cycle fails to engage
i suggest replacing timer or WATER inlet solenoid
Aug 14, 2006 | GE Profile Prodigy WPSE4200A
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
