Question about Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television
Need to replace lamp
How do I take the lamp out of this model tv to replace? wd62327
  • 556 Answers
On this model the lamp is behind the front grill, pull the grill off and you will find the lamp door in the middle it has two phillips head screws in it taske those out and you can look inside and see the lamp it has two flat head screws in it, loosen these all the way off, they do not come out of the housing, grab the handle and pull the lamp out, after you replace the lamp and before you try to turn the set on make sure the door is back in place and screwed down because it will not come back on if the door is not on.
Posted on Sep 04, 2009
2 Suggested Answers
  • 1153 Answers
SOURCE: WD-62327 Lamp
Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977020 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977020 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977020 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977020 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 934C148001
Posted on Sep 18, 2007
Does the Mitsubisti TV Model number wd62327 have a HDMI port?
hi there.
go to this link and it will show you what an hdmi slot looks like.
what does an hdmi port look like Google Search
Nov 18, 2017 | Televison & Video
Recently the red light is flashing in stand by, is there a common issue with this ? WD62327
This is a common issue for DLP TV's the bulbs they have are made to last 2000-4000 life hours for Osram lamps this is the lamp the Mitsubishi usually uses so depending how old the lamp is this could be your problem I found the lamp you need for a good price
http://cgi.ebay.com/MITSUBISHI-915P020010-LAMP-PHILIPS-WD-52525-WD52525-/330465131739?pt=LH_DefaultDomain_0&hash=item4cf141bcdb
Sep 20, 2010 | Mitsubishi WD-62525 62" Rear Projection...
I have the Mitsubishi WD62327 62". I just changed the bulb which I did last year on my own too. My problem is not replacing the bulb but now the tv does not want to turn on. This did not happen to me last...
You need to reset the timer lamp. On mine it is getting the display to lamp then hold the left and menu button for five seconds.
If that doesn't work go to the mitsubishi site and DL the PDF of your model and it should be in there unless you have the paper manual still around.
Aug 11, 2010 | Mitsubishi WD-62327 62" Rear Projection...
I turn the tv on it stay on for one second then it goes off thats when the lamp button comes on its red. then the red light comes on and it stays on although the tv is off the red lamp light is still on
Your lamp timer may be maxed out which means you should change the lamp and reset the lamp timer. When the timer max's out it won't turn on till it is reset.
Feb 09, 2010 | Mitsubishi WD62327 TV
I have a mitsubishi tv model #wd62327 it was on
Your user manual should give you the diagnosis... it is probably available on line if you don't have it. I would guess the fan is making noise and needs to be cleaned, lubricated or replaced. I hope this is helpful to you.
Oct 26, 2009 | Televison & Video
Tv power light comes on but screen is black. Do I need to replace the bulb. It's model Mitsubishi WD62327
is there sound. first check the secondary filter capacitor and then check for dry join. don't forget to check the HOT transistor.
Sep 30, 2009 | Mitsubishi WD62327 TV
How do i turn off v-chip on my mitsubishi tv model # is WD62327
Let me know brand and model number of your TV to look for its Instruction Manual for you.
Dec 05, 2008 | Mitsubishi WD62327 TV
Lamp Cartridge
Well I bought my about three years ago and that warning was poping on for about a year. The lamp finally went out, I should have got a replacement sooner. But I ran it longer than it should have gone, I think I read the lamp should last about 2 years, I got an extra year out of it. Oh well time for a new one...
May 20, 2008 | Mitsubishi WD62327 TV
Mitsubishi wd62327
where is the lamp housing located?
Nov 09, 2007 | Mitsubishi WD62327 TV
WD-62327 Lamp
OSRAM VS. PHILLIPS
This is about buying replacement bulbs for the WD62327 TVs.I dont know about the other models but I purchased a PHILLIPS replacement bulb and it worked for about a week and then those dumb flashing lights and no TV. I did some research and others were saying that you had to replace some condensers. Shop would do it for 600 dollars..Well i sent the bulb back and bought an OSRAM replaement bulb. The TV is now working perfect.
Sep 17, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television Logo
171 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
