Question about LG enV3 VX9200 Cell Phone
LG VX9200 env3 LOUD ringer volume even when set to LOW
I'm not sure if this is a bug but the low volume is not very low and in fact it is downright LOUD. Any fixes for this?
Ringer is set at max but is hard to hear
If the ringout volume is very low, then try not to select a soft, silent or low ringing tone. Try to choose a ringing tone that is loud so that you can hear your phone ringout.
Hope that was helpful?
Mar 18, 2011 | One Touch Jitterbug One-Touch Cellular...
On my LG ENV 3 phone somehow it swiched to "Alarm
Hi there:
Here is the solution:
1.Go under Settings and Tools
2.Go under Sounds Settings
3. Go under Master Volume
4. Bring up the Master Volume level UP at least 2 bars
Voila!
Jan 14, 2011 | LG enV3 VX9200 Cell Phone
How can i unlock my phone
Go to http://www.iunlockit.com/
Unlocking Instructions for LG enV3 Qwerty VX9200
  1. Insert a not accepted SIM Card and turn ON your LG enV3 Qwerty VX9200.
  2. Your LG enV3 Qwerty VX9200 will display "phone restricted".
  3. Select Cancel
  4. Your LG enV3 Qwerty VX9200 will display "phone restriction code".
  5. Enter the Unlock CODE you received from iUnlockit.com
  6. Select OK
  7. Your LG enV3 Qwerty VX9200 is now unlocked!
Dec 15, 2010 | LG enV3 VX9200 Cell Phone
How to set up voicemail for LG env3 Vx9200 when I do not answer
well your service provider has to add the voice mall feature to your account in order to activate. once activated you must press and hold the one key which will walk you threw the voice mall set up process.
Jan 13, 2010 | LG enV3 VX9200 Cell Phone
I recently sent my LG ENV3 through the washing machine, after following the advice of the Verizon employee I talked to, I took out the battery, opened the phone and put in bag with rice for 3 days. Is now...
The ringer & ******** part might be corroded.
go to a repair shop & let the technician troubleshoot the problem.
The ringer & vibrate might be bad & needs a replacement or the connection is bad.
Dec 15, 2009 | LG enV3 VX9200 Cell Phone
LG env3 alarm clock vibrate
Yeah, I had that problem too. I thought my phone was broken. -_- My old phone from Verizon is like 4 years old and I JUST got my enV3. On my old phone, I'd have to set the alarm's ringtone to "no ring." But, on my enV3, "no ring" literally means NO ring, no vibration, no notification, no nothing. On the enV3, in order to set your alarm clock to vibration mode, all you have to do is make sure you "master volume" is in vibration mode, but you have to set your alarm's ringtone to something other than "no ring."
Oct 20, 2009 | LG enV3 VX9200 Cell Phone
EnV3 Ringer Volume TOO LOUD
There is a bug with this phone. All of them do this. The V05 firmware that came out 10-2-09 does not fix this. Sorry. I hate this too.
Oct 06, 2009 | LG enV3 VX9200 Cell Phone
LG EnV3 ringer volume is LOUD even when set to LOW
I have the same issue. I know this is a roundabout solution, but I love the phone in all other ways, so I handled it like this:
I make my own ringtones with audio editing software anyway, so I just made versions of my original ringtones that were "volume-cut" by 6dB or 12 dB. Then to get these .mp3 files installed as ringtones, first I save them to the "my_sounds" directory on the micro-SD card (either via USB cable and "USB Mass Storage" mode, or by taking the card out and plugging it into my PC with an SD card adapter,)
This puts them in as "sounds" but not yet ringtones. Then, on the phone itself, I send a multimedia message of each sound to myself (i.e. to this same phone, "from me to me") Once each message is received, you will get an option to "Save as Ringtone", and once you do that, the sounds become available as ringtones.
I just use ALL of my own "volume-cut" ringtones for the different ring sounds in my phone, and it makes it quieter. Note that if you then use any "standard" ringtones, they will seem particularly loud by comparison.
Oct 05, 2009 | LG enV3 VX9200 Cell Phone
I agree ringer volume is too loud
Same problem here. If you can handle the technical stuff and edit your own audio files, I have a solution, outlined in this thread.
Sep 15, 2009 | LG enV3 VX9200 Cell Phone
LG enV3 VX9200 Cell Phone Logo
606 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
