Question about HP PSC 1315 All-In-One InkJet Printer
How to print cardstock on hp psc 1310 series
It printed one page correctly then the 2nd page keeps getting jammed
Spooling error
Right click My Computer > Manage > Services and Applications > Services > Print Spooler. Try stopping and starting. Make sure it is set to Automatic and Login is Local System.
If this is in office network, then IT needs to handle. GL
May 31, 2013 | HP psc 1310 series
Hp psc 1310 series will not print
please 1st re instalation of driver and 2nd change the cable
Mar 09, 2012 | HP PhotoSmart Office Equipment & Supplies
No problem iwant install hp psc 1315 all-in-one printer-scanner-copier
Hi There,
Please follow the below link to install the HP PSC 1315 All-in-One Print/Scan/Copier on to your computer.
Link:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=374568&lang=en&
Please download the user Guide which reads " HP PSC 1310 series all-in-one - (English) User Guide "on the page.
Enjoy your installation and enjoy printing......
Thanks
Please vote for me if you think your issue is resolved....
Oct 28, 2010 | HP PSC 1315 All-in-One Printer
I downloaded HP PSC 1315 All-in-One Print/Scan/Copy Device Printer but on my pc it is showing HP psc 1310 series .is it the same ?.i am not able to print a word document ,when i click print it goes to...
1.Download from here the correct driver
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=374569&lang=es&cc=mx&taskId=135&prodTypeId=18972&prodSeriesId=360489
2.Uninstall all about hp printer software that you have
3. Power cycle the Pc
4. Reinstall the new downloaded driver
5. Finally plug in the printer and turn it on
Aug 15, 2010 | HP PSC 1315 All-in-One Printer
How to print borderless 5 x 7 pictures using an HP psc 1310 series printer I'm using 5.0" x 7.0" hp premium glossy photo paper and a hp psc 1310 series printer and i cannot align the paper properly to...
Open printers window, right click on the psc printer icon , select printing preferences, click on paper\quality tab, select the paper size as 5x7, check the option as borderless printing and click on apply and then oK...
Try to print ,,,
Dec 07, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1310 reads paper jam in control panel. There is no paper i
Click this link to solve your paper jam problems with your HP printer:
http://bit.ly/9ShIi2
Mar 12, 2009 | HP PSC 1315xi All-in-One Printer
I have an HP printer scanner 1310 series. Have trouble with printing. It will run about 3 blank pages through before it will print. Then it will run a page part way through so have to open back to get it...
Hi Audrey-
There are many things that will effect how your printer handles paper. The most overlooked being the size of the document or image to be printed. If the image or text bleeds over the edges (left, right, top, bottom) of the document, several sheets can be ejected before the "visible" printing takes place. Often those first few pages look blank, but actually are the outer edges of your picture or text. If you are printing a large picture or large text document, this may be your situation. Try printing a document with just a few words on it (like a small email) as a test.
The second most common culprit is dusty, dirty feed rollers in the printer. Consult your HP 1310 series manual for instructions on cleaning the feed rollers, or consult this general cleaning article on HP.com. HP PSC 1310 All-in-One Printer series cleaning
The type of paper can also effect how many sheets are pulled into the rollers. Is the paper new?, Thick?, Very thin?, or is it the same ol' printer paper you've always used? Either way, remove the stack of paper from the feed tray, "fluff" it by fanning it (like flipping through a book very quickly, or the way Superman counts a stack of money!) and replace. Print a test page.
Let me know if this helps!
Dec 29, 2008 | HP PSC 1315 All-In-One InkJet Printer
Need to reinstall hp psc 1310 series all-in=one printer/scanner/copier
I just got a new Dell with windows 7 and my HP 1310 printer will not work with it what do I do
Nov 23, 2007 | HP PSC 1315 All-In-One InkJet Printer
Printer
Could be that you're out of black? If you print blue text, will it show? Here's another troubleshooting guide on font problems - http://word.mvps.org/FAQs/AppErrors/CommonFontProbs.htm Good luck
May 17, 2006 | HP PSC 1410v All-in-One Printer
HP PSC 1315 All-In-One InkJet Printer Logo
310 people viewed this question
Seeker5211
Seeker5211
