Question about IBM Wheelwriter 30 Typewriter
Activating the keyboard
I have an old Wheelwriter that I recently tried to use again. This unit has the optional printer accessory and when that is used the keyboard is turned off.I have forgotten the keystokes that activate the keyboard. Do you know what it takes to activate the keyboard?
    Problem Solver:
  • 11 Answers
Ibm wheelwriter 1000 1 & 2 lights come on and
It sounds like a bad keyboard, you can try my tip under WW1000 or contact Geo. Beyers Co. for a keyboard rebuild @ 800-392-8085 tell them O'Reilly sent you.
DickyO
May 19, 2010 | Lexmark Wheelwriter 1000 Typewriter
I have recently moved. When I send a fax, the printed report has my old phone number on it. I have been unable to find the settings in the menu to fix this problem. Cheers. Derek.
so try these steps
1st press menu key and choose with up down keys
0.Initial Setup then
3.Station ID and choose option Fax:orName:
the keyboard use change contents
Jan 29, 2010 | Brother MFC-260C All-In-One InkJet Printer
Dell Inspiron 6000 keystroke ''blip'' setting
Kids :) To solve your problem first you need to find out if there is any key that is broken or loose. What you could do is 1) turn off the laptop and wipe the keyboard hardly with a towel to release one of those broken keys. 2) if this doesnt work, you need to unplug external keyboard, and then goto start-> right My Computer -> Manage -> device manager -> keyboards -> rightclick standard keyboard and disable it.
Now put in your external keyboard and test your keyboard. Dont worry your mouse is still working and you can enable your onboard keyboard again. Try this and let me know if your problem is solved or detected. If your external keyboard works, i guess there is a problem with your onboard keyboard. you would require to service it. cheers.
Sep 14, 2009 | Dell Computers & Internet
Wheelwriter 1000 beeps when I try to type!
Could be a few things, board, power supply, keyboard or printer.
But there are some things you can check, remove the printwheel and look for debris in that area, unplug and replug the keyboard, if you are really adventurious remove the cover and keyboard and look for paper clips or staples on or under the pc board.
DickyO
Aug 18, 2009 | Lexmark Wheelwriter 1000 Typewriter
Canon MF8170C
First a WW3 has to have the printer option. If it does a generic daisy wheel printer driver will usually work.
DickyO
Aug 24, 2008 | IBM Wheelwriter 30 Typewriter
IBM WheelWriter 30 Series II Operator Manual
The delay print and justify are both on the far rt. of the keyboard pressing these keys turns the features off and on. if this dosen't do it you're keyboard is bad.
DickyO
Aug 01, 2008 | IBM Wheelwriter 30 Typewriter
Reset Tabs on an old IBM Wheelwriter 6 Typewriter ?
Tab to the tab you want to clear press tab clear (t clr) lower left side of the keyboard, to clear all tab all the way to the rt. press and hold tab clear and touch return.
DickyO
Mar 24, 2008 | IBM 3500 Typewriter
? or ?
Double check that everything is US-english for the keyboard. go to START>>>control panel>>>regional and language options. Make sure everything in the first screen is correct...now go to the LANGUAGE tab go to DETAILS. look to see what the keyboard language is. If set on US change it to something else...save the settings go back in and change it to US then save again. Check everything else make sure its US.
Nov 27, 2007 | Acer NSK8458AN Keyboard
MARGINS
Move carrier to left margin press margin release, top left hand side of keyboard, back space to desired position and press L Margin key.  Margins will reset to default if batteries are dead.   Right margin simply space to whever you want the margin and press R Margin.
Oct 24, 2007 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 Typewriter Logo
87 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
