Question about Dell Audio Players & Recorders
Sound is very low,it's a new computer&speakers. The speakers are Integrated 5.1 Channel Audio and Dell Speakers.
  • 106 Answers
Check properly that the system sound is properly configured and check that the all the speakers are working or not then see that the setting is 5.1 audio channel then also check the volume controller level in the amplifier. if all these settings doesnt work then download srs soundbox from www.google.com and install it and configure it properly to get a loud sound.
Posted on Sep 04, 2009
Want to connect JBL platunum series speakers to Dell Inspiron 560 with Windows 7. There is no sound coming from theses speakers on this system. They worked with HP compac.
Hello there,
here is the sound card for the DELL
Sound Card Integrated 7.1 Channel Audio up to Creative SoundBlaster® X-Fi Xtreme Audio (D)†
that means you have a sound card and the port should be in the back and should be green.
Audio front panel - one headphone and one
microphone connector
This is for a headset .
Here is what i would try make sure the speakers are powering by turning on the right speaker the LED should light up if it is then it has power, Next i would try the back of the PC speaker port , if you have everything connected correctly we move onto the next step.
Ok go to
Control panel
Hardware and sound
then click on the green sound link that should pop up a window to configure the speakers, you should see the devices in the list and be able to configure them if you do not let me know and i can help you with the next step.
thank you don't forget to Rate
Jan 25, 2011 | HP JBL Platinum Computer Speakers
I purchased a new computer and after hooking everything up, everything works except I have no audio. I believe the speakers are internal to this monitor.
Double check that you have the speaker cable plugged into the proper jack (audio out - green) on the computer. Make sure that the audio hasn't been muted and that it is set for the correct output type (if you have a multi-channel audio option).
Try a standalone set of speakers to check if the audio driver for the on-board audio or sound card is working.
I hope this helps.
(I've found that the integrated speakers will fail before the monitor does. Since the integrated speakers are low-end and similar speakers are fairly cheap, get new speakers of a quality you like. Repairing the speakers isn't worth it.)
May 19, 2010 | AOC LM729 17" LCD Monitor
Speakers are plugged in but there isn't any sound coming out of the speakers, yet i know the speakers work i tried them on my laptop
Things to check:
  1. Ensure you are plugging into the correct port. Some systems have both integrated audio and and expansion sound card. If it has both, the expansion card should be the port to connect the speakers. Generally all desktops use Green as the speaker jack color.
  2. Ensure the volume control is not muted. Set volume for 75%
  3. Ensure if the audio is integrated, that the audio is enabled in the BIOS
  4. in Control Panel, Sounds and Audio devices, make sure the sound card is the default playback device. Also ensure that Stereo desktop speakers are selected as the speaker tyoe.
Mar 28, 2010 | Dell A215 Computer Speakers
No sound on my pc
Go to Control Panel, Sounds and Audio Devices
Ensure that sound card is the default playback and default recording device.
Also, if this is a Dimension 5100, then there is a possibility that the system has a upgrade sound card installed in a PCI expansion slot (Below the video card)
If the system has an expansion card, (Soundblaster) then the integrated on-board audio should be disabled in the BIOS (If integrated is on and an expansion card is installed, you get a conflict and no sound) Normally, if the system has an expansion card, the ports are covered with a black plastic cover. If the BIOS defaults are ever reset, then onboard audio needs to be disabled again.
Mar 28, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
2.1 SPEAKERS NO SOUND. CONTROL PANEL DOESN'T RECOGNIZE ANY AUDIO DEVICE & CANNOT ADJUST SPEAKER VOLUME.HAVE NEVER HAD SPEAKERS HOOKED UP BEFORE.
That's your problem. It could be:
* the audio-device integrated on your computer's motherboard is "disabled" -- Windows cannot use it
* there is *NO* audio-device integrated on your computer's motherboard -- Windows cannot use non-existent hardware.
* Windows has not installed the correct device-drivers for the integrated audio-device.
* you have an add-in PCI audio-device, and Windows has not installed the correct device-drivers for this hardware.
Do the speakers work if the output from an iPod is connected to the input-jack on the speakers?
Do the speakers work if connected to some other computer (laptop or desktop) ?
Nov 11, 2009 | Insignia 2.1 Speaker System (3-Piece)
Left channel will not play
Firstly try swopping over the left speaker to the right channel . If still no sound then either the speaker cable will have a break in it & need replaced or the actual speaker will be open circuit. If you get sound from the speaker on this channel then the the speaker is ok. Check your PC's audio set up... Go to Control Panel/ Sounds & Audio devices/ In volume Tab, click in Device volume area... Advanced & then check the Balance settings are not set to one end.
Jul 22, 2009 | Dell A525 Computer Speakers
Standard speakers to the computer , low volume
You are getting low volume because there is no amplifier in those speakers. Computer speaker sets are powered -- there is an amp in one of them them which drives both speakers -- a computer audio output without an amplifier will only satisfactorily drive headphones.
May 11, 2009 | HP Compaq JBL Pro (401508-001) Computer...
No sound from rear speakers Creative t6100
Try this:
Go to Control Panel >> Sounds and Audio Devices. Click on Advanced button under Speaker Settings and for Speaker Setup select 5.1 surround sound speakers from the options. Click Apply >> Ok and then check.
Mar 29, 2009 | Creative Labs Inspire T6100 Computer...
Boston Acoustics BA7500... Problem
Try installing an old creative driver for digital audio but use system restore to take a backup of your settings first. Also, you may have to update the bios and unselect the AUTO mode for sound.
Feb 18, 2008 | Boston Acoustics BA7500 Computer Speakers
Low sound from speakers.........polk audio speaker
Hello Minikish
well, some DELL models, have an internal audio, and it is cheap sound card, others have problems with this sound cards, and must be replace. or if you want to buy a PCI X-FI from creative, really Rocks the sound to a new level 5.1 surround sound, up to 7.1
Dec 06, 2007 | Audio Players & Recorders
73 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
