Question about Kirby G6 Bagged Upright Vacuum
Replacing brush roller on my KIrby g6 limited edition
I bought a new brush roller but when I put it back together the little green is okay for a while and then it flickers and goes away when you lower the unit to the carpet.
  • 357 Answers
You need a new belt. When the green light goes out, that means your brushroll has stopped spinning. Here's how to change it....
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Even if you just replaced the belt, this guide will help you make sure that you got the brushroll back in the right way.
Hope it helps....
Marci
Posted on Dec 27, 2007
I need to put the neutral pedal back together
will need to get Kirby engineer to repair, should cost 39 callout+28 for new pedal
Jan 11, 2013 | Kirby G6 Bagged Upright Vacuum
How do i replace the belt
take 2 screws out of the recessed hole on the bottom plastic cover and unsnap it from the front and sides the pull off and and remove the brush roller put new belt around the motor shaft and roller and slide back in the socket
Jan 19, 2010 | Kirby G6 Bagged Upright Vacuum
Kirby g6 will not pic up dirt. Belt is on and bag
check for blockage or impeller if vacum makes loud noise the impeller is the part that gives it suction
Oct 15, 2009 | Kirby G6 Bagged Upright Vacuum
Roller brush not spinning?
THIS GEEN LIGHT MEANS THAT THE BELT HAS COME OFF. THE REPLACEMENT IS AS FOLLOWS: FLIP THE BRUSH (RUG RENOVATOR) OVER AND REMOVE THE SCREWS ON THE SILVER GUARD THAT KEEPS THE ROLLER IN PLACE. SLIDE THE ROLLER UP OUT OF THE SLOT, TAKING NOTE ON THE HALF MOON SHAPED SIDE. REMOVE THE OLD BELT(OR WHAT'S LEFT OF IT). PLACE THE BELT AROUND THE MOTOR SHAFT FIRST. THEN AROUND THE WOODEN BARE SPOT ON THE ROLLER. PUT THE ROUND(CIRCULAR) SIDE OF THE ROLLER IN FIRST, THEN CAREFULLY STRETCH THE ROLLER WHILE HOLDING IN THE ROUND SIDE IN ONE SIDE AND ROTATE THE ROLLER UNTILL THE HALF MOON LINES UP TO THE SLOT. PUSH IT DOWN INTO THE SLOT AND PUT THE ROLLER COVER BACK IN PLACE AND RE-INSTALL THE SCREWS. AND THERE YOU HAVE IT. HOPE THIS HELPS. PLEASE KEEP ME POSTED. THANK YOU FOR THE HONEST RATING AND FOR USING FIX-YA.
May 04, 2009 | Kirby Heritage II Vacuum
Dont know how to put the shampoo system together on my kirby g6..
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Copy and paste the above link to the address window of your browser for the Kirby Shampooer instructions.
Hope this helps :)
And thank you for using Fixya!!!
May 02, 2009 | Kirby G6 Bagged Upright Vacuum
Kirby G6 attaching fluffer brush on shampooer
Sure can,
You have two choices,
1.) To use your shampoo attachment, you'll need the fluffer shield, To set up the attachment seperate the tray assembly (the part that holds the roller brush) from the nozzle assembly (the part that attaches to the machine). Now seperate the roller brush from the tray (easiest way is to pull the belt). Insert the roller brush into the fluffer shield (it only goes one way). Insert the fluffer shield with the roller brush installed into the nozzle assembly the plastic shield will be faced towards the front of the machine. Turn belt lifter to where the red arrows match and attach to the front of the machine. Turn belt lifter to where the green arrows match and you should be in business.
2.) Your using the floor buffing attachment it the easiest method just put on like the floor nozzle (thing you vacuum with).
Jul 21, 2008 | Kirby G6 Bagged Upright Vacuum
My Brush Roll Stops when lowered
Hi There,
            It sounds like you ready for a new belt, It needs to be a Genuine Knurled belt which has dimmples on this inside for extra grip.
Many Thanks
Chris
www.elidistribution.co.uk
Oct 22, 2007 | Kirby G6 Bagged Upright Vacuum
Kirby G6 Bagged Upright Vacuum Logo
293 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
