Question about Canon DR-9080C Path-Through Scanner
It constantly says there is paper jammed in scanner - there is none yes we have blown air multiple times across/around every single sensor.
  • rileybeebs
    rileybeebs May 11, 2010
    This could be a problem with the roller or just the Firm ware. Have you done a full power off of the scanner? Check to see if the rollers are intact and seem to be functioning correctly. You should also be able to find in your user manual the procedures for a hard reset of the firmware.
Almost every time it is dirt (toner from laser prints) on the three lenses on the bottom. Really Work these with a damp rag. Otherwise is is probably paper dust in the top 3 transmitters. Open the lid and remove the 6 or so screws around the three transmitters (there are two inside the top roller area as well) with a little effort the plate should slide out. Clean the plate well and run a damp rag over the transmitters.
Posted on Sep 15, 2009
    President:
  • 3,085 Answers
Make sure the feed switch on the feed tray and eject assembly is not knocked out of position.
Posted on Sep 04, 2009
How to clear scanning paper jam on the scan feeder? It keep on rolling and rolling then paper jam message appear but there is no paper
This can be tricky. First of all only try to fix a scanner when you're in very good mood, otherwise you'll brake the parts. Trust me on this.
Have a good flash light, disconnect the power cord (very important), open every place where the paper runs. Go easy because you're dealing with cheap plastic parts that can easily break. If a door doesn't open don't push it.
With the flash light inspect every single inch where the paper runs. Probably you did this before, doesn't matter, do it again. You are searching for small piece (s) of paper that is entangled around the rollers. When you find one grab it with long tweezers. Be gentle, try not to tear it apart, and keep your fingers out of there. If the paper is between rollers and doesn't move try to rock the roller like paper passing through. Again, be gentle, don't force anything.
When you are sure every part is clean, repeat the operation one more time (I told you to be in a good mood).
If this doesn't work take the machine outside - or place at the garage. Open the paper tracking places and blow compressed air. I use a yard blower.
Good luck.
Dec 28, 2014 | Brother MFC 7840W Printer
2575 paper jam
You could try gently shaking it and see if anything falls out.
You should also try cleaning it, first maybe with some compressed air, you may have a dirty sensor or something
Another thing you should try is unplugging it and allowing it to reset.
Please let me know how the above work out and I can give you further options to try if none of them work.
Thank you for using Fixya and Have a Great Day!
Apr 18, 2008 | HP Photosmart 2575 All-In-One Printer,...
Clp-510 constantly gives paper jam error, although none exists.
Hello and Welcome
If you are facing this error their may be small bit paper jam in side
There are some "micro-sensors" that detect a paper jam. There will be tiny piece of paper, or a lump of dust, inside those sensors, thus "tripping" the sensor and saying you paper jam.
To solve it :
Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
If you become sure that now really there is no paper, dust or foreign objects then
Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.
If problem still exist then best option to contact Samsung Printers Service Provider, Your problem will be solved,
I hope this solution will be helpful for you
Anymore help, I am here to help
Thanks
Mar 26, 2011 | Samsung CLP-510 Laser Printer
ADF paper jam, when there is none
If you are receiving an Error Code 103 or a Paper Jam error, but there are no pages in the ADF (Automatic Document Feeder), follow the steps below:
  1. Close the scanning application (such as PaperPort)
  2. Turn off the scanner and the computer
  3. If you have a combination ADF with a Flatbed scanner, unplug the ADF cable from the base of the scanner
  4. Plug the ADF cable back in
  5. Turn on the scanner power
  6. Turn on the computer
  7. Try scanning again
For a Paper Jam or Error Code 103, make sure that the ADF cable in the rear is connected to the scanner base. Check the flatbed to make sure that it is clear. A page incorrectly placed on the flatbed may interfere with a page feeding through the ADF.
If your scanner stops scanning due to a paper jam in the Automatic Document Feeder (ADF), a warning dialog box appears after a few moments.
To clear a paper jam:
  1. Open the Automatic Document Feeder cover.
  2. Remove the jammed paper and close the cover.
If you are receiving a paper jam error, or if the scanner is running continuously, check to make sure the paper sensor arm is not stuck down.
  2. Look for the small black plastic arm
  3. When you press on this arm, it should move freely up and down
  4. If the arm is stuck down, please contact Technical Support for troubleshooting options
  5. Close the ADF cover.
May 26, 2009 | HP Scanjet 8350 Flatbed Scanner
The scanner wont scan, everytime i add papers it will act like its about to scan but then says there is a jam.
These scanners have multiple sensors, that can check if there is a double feed or paper jam. May be one of them is faulty or a small piece of paper is stuck there. Remove/clean this and the scanner will be fine.
S. Mohan, Chennai, India
Jan 02, 2009 | Panasonic KV-S2046C Pass-Through Scanner
Error P00 on display, no paper jam found
There may be a samll shred of paper stuck in the sensor, Search thoroughly.
S. Mohan
Dec 17, 2008 | Canon DR-7580
HP paper jam
That is usually caused by the paper feed rollers being cover with paper dust. Take a clean cotton pad and alcohol and clean the rollers :turninig each roller as you clean it. if it has a rear dor, open it to get better access to the rollers.
Please remember to rate all users who assist you for free :)
Sep 03, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
Blank Pages
The scanner's paper sensor may be jammed. IT is sensint there is paper and hence scanning!. Try and fix it. Sensor may be optical or mechanical. If optical remove shreds of paper or dust. If mechanical ensure it moves forward and backward.
S. Mohan. Chennai
May 09, 2008 | Fujitsu fi-5750C Flatbed Scanner
IDoc scanner Canon DR-9080C has a P00 error when not paper jam found?
There are sensors in the paper path. Just blow air to ensure that there is no shreds of paper is blocking the sensor.
S. Mohan, Chennai
Mar 13, 2008 | Canon DR-9080C Path-Through Scanner
Canon DR-9080C Path-Through Scanner Logo
154 people viewed this question
old marine
old marine
