I need a wiring diagram for a Dimplex Electric Fireplace Mod#6901860400, Ser#15606D7F424
  • dbarnard910 May 11, 2010
    I looked at another friends fireplace that is pretty much identical and wired minbe accordingly. It now works properly.
    Sergeant:
    Champion:
  • 232 Answers
You can get from www.dimplex.com
Posted on Sep 15, 2009
How do I replace bulbs on model DS5603 Mod G electric fireplace
Do you need to replace the upper or lower light bulbs?
For both, first open the door of the fireplace. For the upper light, locate the upper bulb bracket (above the door). Bend the bracket down. Unscrew the old bulb and replace it with 7 W clear chandelier or candelabra bulb with an E12 base. Bend the bracket back up to its original position. Close the door, if only the upper bulb is out.
You will need a Phillips blade screwdriver to replace lower bulbs. Open the door (if it wasn't already open). Locate the screw that holds the log set in the center of the ember bed. Remove that screw and the log set. Locate the bulbs that are behind the log set and determine if one or both bulbs need to be replaced. Unscrew the bulb(s) to be replaced. Screw in the replacement 60 W clear chandelier or candelabra bulb with the E12 base. Replace the log set and press firmly against the glass. Replace the screw that holds the log set. Close the fireplace door.
The procedure to replace the bulbs is on page 4 of the service manual. It is also on pages 10-11 of the Owner's Manual. The documentation is available from Dimplex: http://www.dimplex.com/en/customer_support/technical_and_troubleshooting . The direct link to the service manual is http://www.dimplex.com/cms/publications/7400650000R04.pdf . The Owner's manual is here: http://www.dimplex.com/cms/publications/7206570100R09.pdf .
I hope this helps.
Jan 12, 2017 | Heating & Cooling
We have a BF8000ST mod C electric insert fireplace. The fan is shutting off once the unit has run for a while. Right now, we are using the fireplace to heat our 5th wheel while we are in this transition...
If you have a Dimplex Fireplace Model # bf 8000st Mod C I can tell this. 1-Yes there is a EC (emergency cutoff) switch when this unit gets too hot. 2-There is a thermostat.These units are usually placed within a wall cavity. These cavities are closed and will build up heat very fast because - there is no vent for cool air intake. RESOLVE: Go to Home supply and buy one or two 2x12 inch register vents. Custom place this new vent(s) in the cavity wall where it may have excess to cooler air from the room.
I completed one vent yesterday and the fireplace runs continually now. I plan to add the second one for balance in the next couple of days. You will be as amazed as I was. IT WORKS NOW...
Oct 05, 2013 | Dimplex Heating & Cooling
Dimplex optiflame remote not working
The DFI2310 uses a simple plug-in remote.
You can either order one from Dimplex, or use an aftermarket solution such as this one from Skytech: Skytech 1315G Electric Fireplace Remote.
Oct 08, 2012 | Dimplex DFI2310 23 Inch Deluxe Electric...
Coil element starts to light up then a small spark and pop noise comes from a small ceramic looking piece in the middle of the element then it shuts off. If I wait for a while and turn on the thermostat it...
You have a PROBLEM that Dimplex USA, Technical Service wants to know about 888-346-7539. In the meantime, turn the Master Control Switch to OFF and unplug the unit. Do not use it again, until you have spoken with them.
Sorry I didn't have better news for you, but safety first.
Please be kind enough to rate my reply to you. Thanks!
Mar 24, 2011 | Heating & Cooling
Hi I have a Dimplex electric fireplace model# CS3311. I had the Remote Receiver plugged into the wall outlet and the Unit Plug was plugged into the side of the Remote Receiver, just like it says to do in...
Lisa, apparently there was an electrical overload in the receiver box. I assume this electric stove is new and still under warranty. In which case, armed with your Proof of Purchase, you need to contact Dimplex USA or the retailer you purchased it from.
Below is a link to Dimplex USA Customer Support.
http://www.dimplex.com/customer_support/contact_us
Feb 23, 2011 | Dimplex Compact Electric Flame Stove...
Need to replace noisy fan motor on Dimplex 6901470100 Not sure how to gett access to blower. Thanks
If you no longer have your Owners Manual go to the Dimplex home page and click on the Help tab. You should be able to download the Owners Manual for your model fireplace there in a pdf format. Also look for a Trouble Shooting tab.
Jan 31, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
15 Amp circuit breaker keeps on tripping , as as
breaker tripping right of way means bad breaker or dead short. which means something has burned out or is wired incorrectly
May 13, 2009 | Heating & Cooling
Remote control working with fireplace.
try www.dimplex.com go to customer sevices they should be able put you on to a local dealer in your area
hope this is of some help
Dec 13, 2008 | Dimplex DS5603 Heater
Heating & Cooling Logo
638 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
