Question about McCulloch Garden
Need to know the petrol/oil mix for timber bear 842 chainsaw
  • 53 Answers
Do not get me confused i just need to purchase a chainsaw magneto, get me to the point.
Posted on Sep 04, 2009
Do you have to mix oil and fuel before putting in the fuel tank if so what oil and petrol do i need to use
Yes. You need to purchase two-cycle oil and mix it with petrol according to the chainsaw manufacturer instructions (this information is in the manual). It will specify the appropriate mix for your chainsaw.
Apr 23, 2015 | Garden
What type oil does this chain saw take?
You use 2 stroke oil and mix it with the petrol at usually 1 part oil to 25 parts petrol. And use chain oil to lubricate the chain
Jul 22, 2014 | McCulloch Garden
How do I mix two stroke engine fuel
Put oil in your petrol can add the exact amount of petrol put the cap on shake well use and store out of sunlight
Jul 17, 2014 | Trueshopping NEW 2 STROKE OIL FUEL PETROL...
Excessive oil from bar on 842 is there anoil flow screw
The oil pump is not adjustable, it is controled by the engine speed, it will keep oiling at idle due to the pump drive gear being fixed to the crank, not driven by the sprocket, so it is not good to leave the machine idling whilst moving timber around, the acid test is wheather the fuel runs out before the oil. this is quite correct
Apr 05, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
What is proper gas mixture?
fuel mix ratio is 50:1 using good quality 2 stroke oil
ie if you mix 20 mils of oil for every 1 litre of petrol that you mix
that is 50:1
or if you want a 5 litre mix put in 100 mils of oil into a clean petrol container 1st then put in 5 litres of fuel only and give good shake
cheers paul
Aug 13, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I inherited a Rancher 50 20" chainsaw from my uncle only noone know the oil gas mixture.
using good quality 2 stroke oil use ratio 50:1
that is 20 mils of oil per 1 litre of petrol that you mix
put oil in can 1st then add petrol and give good shake
so if mixing 5 litres pour in 100 mils of 2 stroke oil and add 5 litres of fuel only
cheers hope it helps
Aug 07, 2010 | Husqvarna Garden
Homelite chain saw --first time user--do you mix oil and gas--two compartments--is the first compartment for bar oil
In the compartment closest to the chainsaw bar, you need to fill this with chain and bar oil. Any good name brand will work fine.
In the other compartment you need to add a mix of petrol and oil in the ratio specified for your saw. If unsure, 25:1 petrol/oil ratio should be ok.
Jul 21, 2009 | Homelite Garden
Need to know the correct levels of oils in a chainsaw
Most McCulloch saws use a 40:1 oil ratio if using McCulloch branded 2-stroke oil. They state 20:1 for other oils, but this is probably overkill as most name branded 2-stroke oils these days are pretty good. I would probably go for a 30:1 or 35:1 mix to err on the side of caution. This will not affect performance, it may just mean you need to change spark plugs a little earlier than usual, but the cylinders will at least be well lubricated.
Please rate my response on FixYa.
Mar 24, 2009 | McCulloch Garden
Garden Logo
105 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
