Question about Agfa Easy Pix SP2 Digital Camera
When switched on, indicator light shows green then to red flashing then red continuously - unable to press shutter button or show menu
    President:
  • 2,761 Answers
Your problem may be due to a buildup of corrosion on the battery contacts inside the camera preventing full battery power from flowing into the camera. Remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during the cleaning, then wipe both ends of the batteries and reinsert them into the camera. It's not a cure-all. but this cleaning cures the problem about 90% of the time. I hope it works for you.
Posted on Sep 19, 2009
Danfoss rx1 thermostat shows 'of' ?
Remove batteries from room stat,turn off the electrical supply to reciever unit.
Turn back on the electric to reciever unit,the red light should be on,press the top "manual" button,the green light should come on and boiler should fire (assuming the programmer is in an "on" period)
Press the bottom button,and keep it pressed,then press the top button until the green light flashes,stand about 6 feet away,and refit the batteries to the stat while observing the reciever unit,either the red or green light (cant remember which) should flash to show the 2 units are syncronised.
Another basic test if all seems ok,when turning the stat up or down,when the green light on the reciever unit comes on or goes off,its usually accompanied by an audible "click" ive found,that if this is not happening, the reciever unit does not switch either on or off,may be intermittant.
Replacement is the only cure.
garden led light
Jun 04, 2012 | Garden
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
After a few seconds the lamp light began to blink red, its a panasonic pt-lb10svu, show no pic at all has a new lamp
Hi, Replacing the lamp in a Sharp LCD projector requires the lamp indicator to be reset. When the lamp needs to be replaced, the indicator becomes red. Resetting the counter for the lamp hours to zero will also reset the indicator to green.
  • Attach the power cord to the projector and plug it into an electrical outlet.
  • Step 2Locate the buttons on the top of the projector and simultaneously hold down the "Enter", "Menu" and "down arrow" buttons, then press the "Standby/On" button.
  • Step 3Continue holding all four buttons depressed until the lamp indicator light begins flashing green.The counter is now reset. Zero hours will now be displayed on the screen.
  • Aug 03, 2010 | Panasonic PT-LB10SVU Multimedia Projector
    Flashing green light on base unit BT Studio 3500
    The flashing green light is the in use indicator on the base. Click the scroll button down on the handset to show the call list, then press the x or secrecy button, then press the tick or menu but to confirm, the call list is now empty and the green light has stopped flashing, You need to repeat this for each handset until complete
    Oct 11, 2009 | Dual Lands Phones
    I have a canon mp830 that is has trouble code 5c00 on the lcd. the power light and trouble light flash alternately green and yellow respectively. I've cleaned the print head. How can I reset the printer to...
    Canon MP170, MP450, MP530, MP600, MP610, MP800, MP810, MP820, MP830, MP960, MP970
    MX700, MX7600, MX850
    1. Switch off the printer the button Power
    2. Holding button Resume (the red triangle in ring), include the printer (press the button Power ) - an indicator fires green cvetom.
    3. Holding button Power , release the button Resume
    4. Not releasing button Power , two times press the button Resume and release both button.
    5. After indicator of the cut-in/readiness flashing.. and fires constantly, fall into service mode.
    6. Four times press the button Resume , under each striking Resume indicators are switched: green-yellow.
    7. Once press the button Power for acknowledgement of the selected action (the unset of the counter абсорбера). For switching off the printer button Power press once again.
    Jul 09, 2009 | Canon Office Equipment & Supplies
    Flash won't shoot
    does the red bulb show when the flash is ready to shoot ? you can press the button that lights red or green to test the flash on itself.
    Mar 10, 2009 | Canon Speedlite 550EX TTL Flash
    Thomson DT!6300-16 has stopped working
    Usually to fix most odd problems on the Thomson digi box you should do a hard disk format every couple of months, select menu, setup, help,
    press green button on remote
    this shows advanced menu, press blue button, warning should show,
    press green button to proceed
    takes about 2mins you lose all recorded programs
    If the problem is the box stays at red, and won't switch on,
    pull the mains plug wait a few secs then push and hold the the standby
    button on the main box (not remote) then insert mains plug, as soon as the
    red light flashes release the standby button and very quickly press
    menu and OK in that order, don't hang about, it has to be done very quickly
    I had to do it several times before I got it right, this loads a preloaded firmware
    and the box will come alive again the box will upload new firmware in a couple of hours.
    good luck from Ron.........
    Dec 04, 2008 | DTK PRM-0031I Motherboard
    Flash doesn't fire
    Should fire from test button. If not flash tube is blown.
    Jul 08, 2017 | Digital Concepts 952AF for Pentax Flash
    PS3 won't turn on
    hi Torgsrus.
    PS3 Light sequence
    The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
    No lights are on:
    When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
    If the PS3 does not turn on:
    · Make sure the power cord is not frayed or damaged
    · Try using another power cord, if available
    · Make sure the main power switch on the back of the PS3 system is turned on
    · If you continue to have issues contact our Technical support.
    Solid Red:
    When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
    Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
    If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
    Solid Green:
    When the power status light is solid green, this means that the PS3 is turned on.
    You should be able to navigate the XMB, play games, access the Playstation store,etc.
    To turn of the PS3, simply press and hold the power button for two or more seconds.
    If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
    Flashing Red:
    When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
    This may be caused by poor ventilation or the vents may be blocked.
    If this happens:
    · Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
    · If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
    · Leave the ps3 system off for 30 minutes to let it cool down.
    · If you continue to have issue, you may need to send the console in for service.
    Flashing Green:
    When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
    If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
    If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
    Flashing Green, Yellow and Red:
    When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
    When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
    Solid Blue:
    When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
    If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
    Flashing Blue:
    When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
    If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
    Dec 02, 2017 | Sony Playstation 3 (PS3) Console
    Changed ink jets alarm flashing number 5800 showing
    Hello Saron Girl,
    its not 5800 its 5B00
    7 times LED Blink Waste ink absorber full [5B00] - Ink absorber (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864 / 4221 / 4257)
    <Service mode operation procedures>
    1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The LED lights in
    green to indicate that a function is selectable.)
    2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
    3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the
    Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.)
    4) When the LED lights in green, press the Resume/Cancel button the specified number of time(s)
    4 times LED Green Waste ink counter resetting
    5) After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes,
    the printer returns to the menu selection mode automatically.)
    Regards,
    May 14, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
    Agfa Easy Pix SP2 Digital Camera Logo
    43 people viewed this question
    Top Agfa Cameras Experts
    Larry Stiles
    Larry Stiles
    Tony
    Are you an Agfa Camera Expert? Answer questions, earn points and help others
