Question about Maytag 24 in. MDBH955AW Built-in Dishwasher
Indicator lights on Maytag dw model mdbh 955 do not light up. Plugged into live plug. Door is engaged and clicked shut. It's like there is no power to the unit but there is. Is there a reset button I need to check or a fuse?
  • dwight_vogt Sep 05, 2009
    Thank you for your response. It is not the power, or the door switch, or the wiring. All work or look fine in the case of the wiring. So must be the last one option. Where are these?
  • 10,515 Answers
Follow the steps :-
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 05, 2009
  • taran_2005
    taran_2005 Sep 05, 2009
    Thanks for your response too!!
    Let me provide you with 2 guides you can use to check whether it's Timer or Selector switch :-
    http://www.partselect.com/repair.aspx?ap...
    http://www.acmehowto.com/howto/appliance...
    Hope i helped you.
Samsung DMT400RHS Leakage error
check you house circuit breakers if you have no lights and the DW is plugged in next check to see that the door switch still locks the DW shut otherwise;call a serviceman
Nov 18, 2013 | Samsung DMR78AHS Builtin Dishwasher
Kenmore DW model #665 16023403 will not turn on. There is power to the DW but the panel does not light up. Checked circuit breaker. Door tightly shut and latches. Just 3 yrs old. Would love to fix myself....
The electronic control panel should be replaced and cost about $240. It is easy to remove and replaced --- pull and plug like a standard elect plug, only its flat.
This definitely works.
Sep 04, 2012 | KitchenAid 24 in. KUDP01IL - Multiple...
Maytag Dehumidifier will not run. Indicator light says "full"
Here is a tip that I wrote to help people with just that dehumidifier2_bing.gif problem..
Dehumidifier Problem It shows Bucket Full
http://www.fixya.com/support/r4688381-dehumidifier_problem_shows_bucket_full
heatman101
May 02, 2010 | Maytag M7DH45B2A Dehumidifier
Door won't unlock
try the cancel button it will drain the water and release the lock
May 30, 2009 | Maytag Neptune MAH9700 Front Load Washer
Water is not coming into my Maytag dishwasher.
Is the door open or unlatched?Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if the door is not latched. Check for obstructions (spoons or utensils), that may be interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure. The lights for cycles selected will flash if the door is opened while running a cycle.
Is there power to the dishwasher?Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.
Does your dishwasher have a rotary timer knob?The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.
Is the control lock option activated?
The indicator light next to the lock graphic will illuminate when the controls are locked. Press and hold the Heated Dry option (button with lock icon) for three seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
Is the delay start option activated?To cancel the delay and cycle, press Start/Cancel twice.
Is the water shutoff valve turned on?Make sure that the water shutoff valve is turned on.
Mar 03, 2009 | Maytag 24 in. MDB6600A Jetclean II...
Water leaking onto the floor
1. If the water is going onto the floor during the drain cycle there is either a hole in the hose or it is completely loose from the DW or a hole in the drain assembly under the sink but if that were the case you would have water under the sink also.
2. If it during the wash or rinse cycle then the seals are not sealing (door is not closed all the way or seals are bad) or the float at the right front of the DW is stuck allowing the DW to overfill with water.(you need to open the door and pull the float up and out as you do so push it up and down and listen for a clicking sound.(which indicates it is making contact with the fill solenoid)..if you here the clicking and the float is full of gunk (old soap and such) clean it out and replace it and run it through a cycle and monitor the DW to see if the fill cycle shuts off before the water reaches the overflow point.
3. the only other option is a possible rust through on the DW and or the drain and motor mount in the center of the DW where the food particles and water are drained...is loose and leaking or rusted through...(how old is the DW).
4. Also check to see there are no large particles around the door seal to prevent complete closure and sealing of the door seal. As well as the door latching properly (when closed can the door be moved or pulled open)?
I hope this helps and let me know if not Please relay model number, age and other specifics you feel are pertinent...thank you and please rate me if this helped...thanks again ...the Fang
Jan 24, 2009 | Maytag 24 in. MDB4000 Built-in Dishwasher
Latch is in lock position and we cannot shut the door
you ll have to order and replace the latch assembly ther are 2 for this model depending on your serial number
Nov 17, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag 24 in. MDBH955AW Built-in Dishwasher Logo
229 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
