Question about Jack Lalanne Power Juicer 250 Watts
Can't get the wrench in to tighten blade - Jack Lalanne Power Juicer 250 Watts
    President:
  • 3,433 Answers
Use a socket with an exyension and rachet.
Posted on Sep 04, 2009
The blade wont spin even though the mothor is on. I can hear the motor engage but the blade will not move...it has not been used in awhile.
Have you ensured that the blade is securely screwed into the drive motor? Using the two-pronged tool that came with the juicer (or, if you've misplaced it, a DIY solution like two small screwdrivers), make sure that the blade unit is screwed clockwise onto the drive motor. There should be two holes on the inside of the blade unit, at the bottom of the "bowl." That's where you remove the blade unit for cleaning and reattach and tighten it.
Mar 01, 2011 | Jack Lalanne Power Juicer 250 Watts
Who might sharpen the shredder blade???
This is a good one because a worn blade
actually causes less vibration. You can
sharpen the blade using a drill. Use a drill
bit about the same width as the cutting burrs
and drill into the face of each one ever so
slightly, almost perpendicularly. Assemble
the juicer and unlock the adjust screw on
the center of the bottom. Turn it clockwise
until the blade contacts the chute, then back
it off a half turn. Don't forget to tighten the
lock nut. I've been using the same blade
for years.
Oct 02, 2010 | Acme 5001 Supreme Juicerator Juice...
I do not know how to clean and take it apart
I did some research here on Fixya and this is what another expert had to say.........pull the metal bar forward and down to open up into the blade compartment. your juicer should have come with a handle type key wrench thing that you stick on top of the blades into holes to unscrew blade holder, while unscrewing that hold the blade still.
Hope this helps you......best wishes.
Oct 05, 2009 | Jack Lalanne Power Juicer 250 Watts
How do you take apart the jack la lannes juicer for cleanning
I had the same problem because I bought it used. After reading that I needed a key that fit in the holes I used a pair of chop sticks and it twisted right off.
Sep 15, 2009 | Jack Lalanne Power Juicer 250 Watts
The pusher to push the food into the blade is coming into contact
The blade maybe was not screwed in right. Screw out the blade using the blade tool and screw it back again making sure it is screwed in and fitted in right. Do not tighten too much. It breaks easily.
Jul 10, 2009 | Jack Lalanne Power Juicer 250 Watts
I need to buy a blade tool to remove and to tighten the blade in my Jack Lalanne juicer. Where can I get a replacement?
Just find a big wire bend it and insert both ends on the blade holes. Use leather gloves or cover the sharp blade with a piece of cloth.
Mar 15, 2009 | Jack Lalanne Power Juicer 250 Watts
Jack lalane juicer
All in the name of health I said a lot of bad words, except that I know I never toss out my owner's manuals. I finally went to find my juicer model number when I noticed that the box said that it came with a recipe book (!) so I ran to my recipe book cupboard and sure enough the owner's manual was with it. (Maybe yours is there..)
Anyway, the key is this "crescent wrench." Doesn't look like a normal crescent wrench at all, but the handle is shaped like a crescent moon. It has two little pegs that stick out and fit into the two holes in the top of the blade, Then it twisted counter-clock-wise, the blade **still screwed into the piece underneath it, then it easily comes out, as do the other parts inside. It was just that rotten little "wrench" piece WHICH, I might add, is unique to my model. If you download the other owner's manual that's online, it doesn't mention any such tool for their model. (sorry, I can't find a model # for mine. There is a "V3 52803" on the back of the manual if that's the model.) Good luck. Hope this helps you. Happy, and healthy juicing.
p.s. in the end...it's all about Jesus.
Oct 19, 2008 | Jack Lalanne Power Juicer 250 Watts
Tighten bolt is frozen
WD-40 and let it sit for a few hours and it came loose. Had to wash it good before using it.
Jun 11, 2008 | Back to Basics NS1000 Nutri Source Juicer
Take apart and clean the juicer
ok so i am tryin to take apart my juicer to clean it but i can't find a way to do it. Can u help me?
Dec 04, 2007 | Jack Lalanne Power Juicer 250 Watts
Jack Lalanne Power Juicer 250 Watts Logo
Top Jack Lalanne Juicers Experts
Starnley Johnwells
Starnley Johnwells
Cory Koby
Cory Koby
Are you a Jack Lalanne Juicer Expert? Answer questions, earn points and help others
